December 1st, 2016, 10:08 PM | #1 |
Join Date: Dec 2015 Motorcycle(s): Thruxton R, R6 450 triple, EX300 (sold) Posts: 263
Number of Cans for Painting a 300
Does anyone know how many cans of rattle can (10.5oz cans) it would take to paint a 300? With or without inclusion of the gas tank.
My winter project is to give my 300 track fairings a paint job for next year. I will be keeping my gas tank color, so I'm looking to spray the upper, lower, and tail. Also, does anyone have experience with the USC/Eastwood 2K single stage rattle cans? I'm leaning towards playing around with those (pricey at $27/can, in order to get the harder automotive urethane finish. Since this is a track bike, I'm not expecting amazingness. If it can pass the 5 feet/photographer test and look better than my current primer grey, I'll be happy. I figure spending $200 on supplies and rattle canning it still saves a significant amount over the $500 I've been quoted for pro paintjobs. |
December 2nd, 2016, 04:08 AM | #2 |
Join Date: Dec 2015 Motorcycle(s): 2008 Ninja 250 Posts: 210
I did my entire fairing set for my 250 plus gas tank with about 10 cans.
I bought 2 cans of primer, 4 cans of paint, and 4 of clear coat It was all krylon maxx and held up pretty well for about a season. I had to do some repair work to my fairings (epoxy and such) which lengthened my process but even with that it only took me about a week working a couple hours each day after my shift. I believe I did 2 light coats and a heavy with the primer, about 7 or 8 coats of color, and at least 6-7 coats of clear. I did minimal wet sanding and such in between due to it being only a rattlecan job. I can't really give you the most accurate price point as my other expenses (sand paper, plastic epoxy, other prep materials) were available where I work but I would say just the rattle cans with set you back about 60-85$ iirc maybe a little more. Definitely more if you use the 27$/can urethane paint, but I have no experience with that stuff. |
December 2nd, 2016, 06:38 AM | #3 |
Join Date: Feb 2016 Motorcycle(s): 2007 ninja 250, 14 ninja 300, 09 1125CR Posts: A lot.
MOTM - May '17
I did my entire 750 last winter with single stage and ran the same amount of cans as RG, still think I should've done more than ten cans.
December 2nd, 2016, 07:40 AM | #4 |
Some of it will depend on the color you choose and the color you are covering. A dark color over a light color will cover easier and require less paint. Some lighter colors like yellows and oranges cover poorly, and will require more paint. Covering uneven colors will take more paint.
Using a 2K paint is a good idea. It sounds like you will be using a solid color, which will eliminate the need for clear. With a solid color that covers well, I would think 4 to 5 cans may do it. I'd be really surprised if it took 10 cans of a solid color to do the bodywork. |
December 2nd, 2016, 08:14 AM | #5 | ||
I was hoping the 4-5 cans number would work.. I'm thinking of going a medium blue and black, so they should cover fairly well. I was hoping I could get it done with 6-7 cans and have enough of a safety margin. |
December 2nd, 2016, 08:26 AM | #6 | |
But I think I'd get a couple quarts of the 2K and use a cheap HVLP gun. It would be cheaper, including buying the gun, if you compare it to ten cans of 2K. |
December 2nd, 2016, 08:43 AM | #7 | |
December 2nd, 2016, 08:55 AM | #8 |
MOTM - May '17
THE ONE ON THE RIGHT IS THE ONES I USE DIDN'T HAVE ANY PRIMMER AND IF IT WASN'T FOR GETTING THEM FREE FROM WORK I WOULD OF WENT WITH THE LOCAL ABS SHOP FOR PAINT. ALSO LOOKING BACK AT IT IT MIGHT OF BEEN MORE LIKE 6-8 CANS, BUT 2 OF THEM WHERE NOT EVEN FULL TO START WITH. BUT LIKE I SAID BEFORE I THINK I SHOULD OF AT LEAST DONE 1-2 MORE CANS TO GET IT BETTER LOOKING.
December 2nd, 2016, 09:04 AM | #9 |
MOTM - May '17
Here is a pic of before and then after, and if your thinking of doing it in your apartment, well i wouldn't, you need a good ventilation.
December 2nd, 2016, 09:07 AM | #10 |
No problem there. My Guzzi was painted white with no decals or clear when I got it. The paint was many years old. I did a quick 400 grit wet sand, applied decals, and put one can of Spraymax 2K clear over it. The improvement was amazing.
December 2nd, 2016, 09:12 AM | #11 |
Join Date: Apr 2011 Motorcycle(s): 2015 636 ABS - 69 Honda 305 Posts: A lot.
I use like 2 cans of krylon from lowes and call it a day. Its just my track bike...
Current - 2015 30th Anniversary Ninja 636 ABS - 1969 Honda 305 Scrambler Previously - 2011 Ninja 1000, 2008 Ducati 848, 2011 Ninja 250 SE |
December 2nd, 2016, 10:03 AM | #12 |
Join Date: Apr 2014 Motorcycle(s): 1978 Z1R, 1999 EX250 Posts: A lot.
MOTY - 2018, MOTM - Oct '16
I used 2 cans of red and 1 of gray, had about 1/2 can of each left over. Just used Rust Oleum at about $5 a can, for me it's plenty good for a track bike, and cheap to touch-up. It took 2 coats to cover the black that PO had sprayed on. I've discovered that Krylon, in the hardware spray cans, takes at least double the coats as it doesn't cover nearly as well. Surface prep means at least as much as the type of paint used.
December 2nd, 2016, 02:44 PM | #13 |
Totes forgot aboot this thread. I was covering a light purple with a dark burgundy satin so 4 cans of color was good for me. Just use painting techniques you would use if you were shooting urethane from an air gun and it should turn out fine. I got plenty of compliments on my paint job, just know that it doesn't hold up well even with a ton of clear coat over top.
December 2nd, 2016, 09:12 PM | #14 |
No worries. Haha. I'm planning to go somewhere outside and just spray it over newspaper. I have beige carpet inside, so spray is a definite no. Haha
December 2nd, 2016, 09:13 PM | #15 | ||
Last futzed with by Mechanikrazy; December 3rd, 2016 at 04:29 AM. Reason: late night typing that made no sense. haha |
December 3rd, 2016, 11:45 AM | #16 |
Happy to help. Just make sure to spend lots of time doing prep work. O and get the little plastic attatchment for the top of the spray can that looks like a pistol grip, best 5$ I ever spent.
Am I the only one who loves multiple exhaust cans? | IF13 | General Motorcycling Discussion | 5 | October 18th, 2013 01:55 PM |
Cheap universal exhaust cans? | peterpayne | 1986 - 2007 Ninja 250R Tech Talk | 9 | August 23rd, 2013 06:56 AM |
[superbikeplanet.com] - Not a MotoGP Rider's Favorite: Number Six, Number Six, Number | Ninjette Newsbot | Motorcycling News | 0 | September 28th, 2011 07:10 AM |
anyone cut their stock cans before? | crackerjack | 1986 - 2007 Ninja 250R Farkles | 2 | February 12th, 2011 05:30 PM |
Cans - Slip On Mods | addy126 | General Motorcycling Discussion | 21 | July 29th, 2009 07:15 AM |
