Old September 20th, 2019, 12:09 PM   #1
lroedal
Motorcycle(s): 250r
08' 250r EFI does not start
I have an 08' 250r with injection that was running when I parked it three weeks ago. When it was parked I took off various covers for cleaning, the battery was taken out etc, and it was put back together. The last weeks we have had horrible weather, and as I have no garage where I live now the bike has been left out in the rain.
When trying to start it a few days ago, it would not start. The starter cranks, but the bike shows no signs of starting. Not sure what could be the cause of it, or where to start trouble shooting. The bike went on the side a few years ago, so I basically have no plastics except for the back of the bike, and the only instrument is a speedo. Also, the sensor for the stand broke a year ago, so I shorted the wire for this, so this should not be the reason it is not starting.
lroedal is offline   Reply With Quote
Old September 20th, 2019, 01:06 PM   #2
I'd start by making sure the battery is fully charged.
Try cranking while slowly opening the throttle.
Check for water in the plug holes. If that's all good, start checking electrical connections and fuses.
Old September 20th, 2019, 01:18 PM   #3
lroedal
Motorcycle(s): 250r
All lights are fully on after trying to crank though, and it wouldn't start when I tried to push-start it either. Will try to charge the battery though, couldn't hurt! The trottle is tried. How do I remove the spark plugs on this one though? The plastic covers for the plugs looks like they will break if I use force, and they are really stuck. :/
Old September 20th, 2019, 01:48 PM   #4
Pull straight up on spark-plug connectors (in direction of cylinder slant). Might take some force as rubber seal can stick to engine.
Measure all interlock switches and verify their state (open/closed):
- run/kill switch
- clutch switch
- sidestand switch
- neutral switch
- all wiring in between these switches and diodes
These are part of AND/OR logic test that tells ECU if it's safe to run engine. If a single component is incorrect, engine won't start. Starter circuit is separate and independent from EFI system.
Old September 20th, 2019, 01:54 PM   #5
lroedal
Motorcycle(s): 250r
Will the starter still crank if one of these are off? The run/kill is disengaged at least, and the sidestand switch is removed (there is a wire between the two connectors). The bike is in neutral, but how can I check the clutch switch?
- run/kill switch
- clutch switch
- sidestand switch
- neutral switch
Old September 23rd, 2019, 11:27 AM   #6
GAU-8
Socially inept. Yet FUN!
GAU-8's Avatar
Motorcycle(s): Current machines- 1992 SECA II 600, 2006 Ninja 250, 2008 Ninja 250
Typically, if any of the safety circuits are open, the starter will not engage. But yours is cranking. So with that in mind...
Do you hear/feel any compression , or egagement when thumbing the starter? If so, it could be battery, plugs, or EFI unit.
If the starter just spins ( zzzzzz zzzzzzzzz) and no compression felt, then either the starter isn't engaging, or starter clutch is out. ( if you heard a nice clang/ing at one start, that's a good telltale sign.)
GAU-8 is offline   Reply With Quote
Old September 27th, 2019, 03:45 AM   #7
lroedal
Motorcycle(s): 250r
Hey! Sorry for the late reply - there was hardly any engagement when thumbing the starter, but loads of compression when trying to push-start it.
However, after charging the battery for a full night as well as leaving the bike inside my house, there was a slight hint of engine noise when trying the starter. So I did as I tried earlier, thumbing the starter and popping the throttle, and after 20 good seconds it started - blowing a **** storm from the exhaust in the process. Not sure what was the initial problem, but I'm assuming it could have been water in the exhaust pipe perhaps. In either case, it works now - so I am a happy camper. Thanks for all suggestions.
Old September 27th, 2019, 01:54 PM   #8
GAU-8
GAU-8's Avatar
A storm of what? Water, smoke...? If smoke, was it more of a thick white/blueish or black?
How old are the plugs? Know recent condition of them? I'm not trying to bust on you. I had an epiphany, that I might need to bring to another thread for my ..or others knowledge update or understanding.
Old September 27th, 2019, 02:28 PM   #9
Hmm, could be possible rain got into muffler after bike was left out in rain. Depending upon how full muffler and exhaust was, that would add resistance to cranking. If not stored in garage or bedroom, bike should have cover.
Old September 29th, 2019, 11:19 PM   #10
lroedal
Motorcycle(s): 250r
Grey smoke with all kinds of small dirt particles inside - my floor was covered after. The spark plugs are a probably +- 4 years old, they have not been changed since the last time it was serviced in a shop.
Old September 29th, 2019, 11:19 PM   #11
lroedal
Motorcycle(s): 250r
Yeah, I think that could be it as well.
Old September 30th, 2019, 04:29 AM   #12
GAU-8
GAU-8's Avatar
Originally Posted by lroedal View Post
The spark plugs are a probably +- 4 years old,.
Between weather issues of rain, humidity, cold/hot temperature cycling, exhaust taking on water,( and possibly the plugs wet too) I would change those out. If not that, at the very least, clean them up.
A new simple/stock plug, is better at performance, and reliability, than an aging high dollar plug, at this point in age, and use.
DIY EFI KIT for our 250r forbitel 2008 - 2012 Ninja 250R Tech Talk 331 January 30th, 2024 07:03 PM
Efi... How many installed it sidekick10121 1986 - 2007 Ninja 250R Tech Talk 6 June 30th, 2014 02:52 PM
Push start EFI? Jiggles General Motorcycling Discussion 8 July 17th, 2012 01:10 PM
Snorkel Removal on EFI Ninja 250R? hackeron 2008 - 2012 Ninja 250R Tech Talk 16 February 2nd, 2012 10:43 AM
EFI kit Racer x 2008 - 2012 Ninja 250R Tech Talk 138 May 15th, 2011 01:47 PM
