Old October 2nd, 2019, 09:38 AM   #1
JRay
Motorcycle(s): 2008 Ninja 250
Throttle cable Re Install after putting carbs back
Hey guys.
I totally forgot how I disconnected the throttle cables to the carb. I looked for videos on you tube. Couldn't find any good ones.
Does anybody have some good photos or videos that they could share?
Thx in advance!
JRay is offline   Reply With Quote
Old October 2nd, 2019, 10:50 AM   #2
Posts #8 and 11 in this thread have some photos of the cables connected to the carbs -
https://www.ninjette.org/forums/show...ht=carb+cables
Basically you can hook up one cable and twist the grip to wide-open to confirm it is opening the butterflies. The other closes it.
Old October 2nd, 2019, 12:24 PM   #3
1. determine which cable-end is throttle-pull/open vs. throttle-close. Twist grip in towards open-throttle position and find cable-end that gets shorter as you open throttle.
2. put that cable-end on carb-opening side of throttle-cam.
Although due to access & clearance issues, I prefer to put closing-cable on carb-closing side of throttle-cam first since it's slightly behind opening cable.
Old October 2nd, 2019, 12:40 PM   #4
JRay
Thank you!!
It appears that my return cable is just wires on the bottom....there isn't a little round piece to clip into carb. Since the previous owners really messed up a lot of things on this. I'm not even sure there was ever one in it. I for sure don't have it. Is this a piece that can be bought. Or do I have to buy a new return cable?
Thx again for all of the help while I try to get this bike back in shape!
Old October 2nd, 2019, 12:58 PM   #5
You're welcome!
Those barrel cable-ends are typically moulded on. Something like this may work. Measure diameter of other cable end to find exact size needed.
http://www.myronsmopeds.com/category/cable-parts/
https://store.bevelheaven.com/Cables...rew-5.4mm-DIA/
https://www.ebay.com/itm/132337617406
Here's innovative way to re-mould cable-end using solder.
Last futzed with by DannoXYZ; October 2nd, 2019 at 03:37 PM.
Can not re-install carbs on ninja 250r chibit89 2008 - 2012 Ninja 250R Tech Talk 7 September 28th, 2016 03:07 PM
please help with throttle cable on carbs gantt 2008 - 2012 Ninja 250R Tech Talk 4 March 28th, 2015 06:58 PM
about self install clutch cable NinjaNinja35 2008 - 2012 Ninja 250R Tech Talk 6 August 14th, 2014 12:21 PM
Throttle went while riding -> need new throttle cable? AndrewMack 2008 - 2012 Ninja 250R Tech Talk 13 September 8th, 2013 06:17 PM
Throttle & Throttle Cable Smoothness paterick4o8 2008 - 2012 Ninja 250R Tech Talk 3 December 1st, 2009 01:50 PM
