Old October 6th, 2019, 02:39 PM   #1
robbaz0
Motorcycle(s): Ninja 250 2009
Cooling fluid going crazy
https://drive.google.com/file/d/14MX...ew?usp=sharing
I let the bike run for a couple of minutes then it starts spraying out fluid as you can see in the video above any help, please? I also got the thermostat replaced
robbaz0 is offline   Reply With Quote
Old October 6th, 2019, 03:04 PM   #2
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
That looks like you either don’t have the cap on properly or it’s not got a seal on the spring plate or Inside the cap. The alternative is a blown head gasket which would be bad, but the Leak should be from the expansion bottle, NOT the rad cap.
You know the cap has two positions right !? The cutouts dictate where the cap can be applied, then turn clockwise (righty tightly) the first step is like 1/8 of a turn, light pressure. The second step is another 1/8 (for a 1/4 turn in total) this second step has more resistance & sets the spring pressure on the pressure seat seal. I suspect you are only at step one !
Old October 6th, 2019, 04:10 PM   #3
Snake
Snake's Avatar
I agree with Mohawk. It looks like the cap is either not fully seated or you may need a new cap.
Old October 6th, 2019, 04:41 PM   #4
Maybe it’s my bike, but radiator cap only seats fully in one direction. Even though there’s two fingers on cap and it appears it can go on in one of two rotations 180-degrees apart, only ONE of those positions will allow full clicking into 2nd final fully seated position.
After bike cools off, try unscrewing radiator cap, note its position, remove, rotate 180-degrees and reinstall and see if it goes to 2nd-stage to fully seal.
Old October 7th, 2019, 09:22 AM   #5
robbaz0
Hey, I apprentice all the info I will try it out once I get home.
Also, could it be a possibility the radiator neck filler is broken or cracked?
Old October 26th, 2019, 01:31 PM   #6
JohnC
Motorcycle(s): 2012 Ninja 250, 2012 Ninja 1000, 2004 TTR-230 (2 of 'em)
Possible? Sure. But I'm with everyone else on this one - either a bad cap or you don't have it seated correctly.
JohnC is offline   Reply With Quote
Cooling system help acook3323 1986 - 2007 Ninja 250R Tech Talk 24 April 10th, 2017 05:54 PM
Cooling issue... braaap 1986 - 2007 Ninja 250R Tech Talk 42 May 5th, 2014 10:14 AM
Cooling Issues FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 158 July 11th, 2013 06:45 AM
Cooling System Issues AlfredoGonzalez 1986 - 2007 Ninja 250R Tech Talk 8 January 4th, 2013 02:14 PM
anyone have experience with cooling vests? oblivion007 Motorcycle Gear 24 July 21st, 2012 08:04 AM
