Old October 7th, 2019, 05:35 PM   #1
Darksik
Darksik's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R, 99' Suzuki Katana 600 (RIP)
130/70/17 Or 140/70/17
Hi guys i have a question about the size of the tires, my rear tire is old and i want to buy a new michelin pilot street, but i saw time ago some post of another users telling that they put a 140 rear tire, you guys know what is the difference about a 140 from a 130?
Lose speed?
better grip?
have more speed?
sorry for this poor post
Darksik is offline   Reply With Quote
Old October 7th, 2019, 06:14 PM   #2
Ralgha
Ralgha's Avatar
It'll be a little less maneuverable with a 140. Otherwise, pretty much no difference.
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old October 8th, 2019, 12:37 AM   #3
No difference. Maybe heavier steering and not as responsive.
Squeezing wide 140mm radial onto narrow rims causes some nervousness at limit. You'll end up with 5-10mm unused stripe on edges of 140 tyre, so effectively you'll be using only 130mm of it anyway. You'll want to retrofit Ninja 300 4.0" rear wheel in order to make most use of 140 tyre.
Many, many reports of Ninja 400 racers going from 150 to 140 tyre for improved handling. That's because Kawasaki didn't upgrade 400's rear-wheel from Ninja 300's 4.0" width. So 150 tyre just doesn't work on that narrow of rim.
Last futzed with by DannoXYZ; October 8th, 2019 at 02:22 AM.
Old October 8th, 2019, 06:18 AM   #4
Another oddity is that if the wider tire is made for a wider rim and you put it on the rim size for the narrower tire, it may not end up any wider at all. I had that happen once when I tried a 130 tire in place of a 120 on my Guzzi, and measuring it with a caliper they were within a few thousandths of an inch of the same.
Old October 8th, 2019, 12:22 PM   #5
GAU-8
Socially inept. Yet FUN!
GAU-8's Avatar
Motorcycle(s): Current machines- 1992 SECA II 600, 2006 Ninja 250, 2008 Ninja 250
To cut to the chase on installing a wider rim tire, onto a thinner rim is SAFETY. The air pressure you need to get it to seat, is much, MUCH higher, than what the tire is rated. (Maybe not every single time, or application. ) I used to run a 150 tire for a 4.0 rim, onto a 3.5 rim. (Stock tire was 130) No shop would mount it for me. Was never told why. (I wish they did.) So I did it myself, at my job, after hours.
I did this often. Had I been aware of the danger, I wouldn't have done it. Not worth the risk.
I get the conversation about going to a wider tire, for same rim width. Just alerting you that, you really don't want to squeeze a wider rim tire, to a thinner rim.
Last futzed with by GAU-8; October 8th, 2019 at 01:47 PM.
GAU-8 is offline   Reply With Quote
Old November 6th, 2019, 01:12 PM   #6
Net-Tech
I liked the 140 on my 2009 250r.
Shop put it on without any special notes or warnings. Previous tires were the IRC Winners and the Pilot streets took a little getting used to. The pilot streets seemed to me to respond quicker than the IRC so at first it felt loose. Turned out I was putting more input into the IRCs and the pilot streets didn't need it. I also lost that feeling of wind trying to blow bike from under me. Really like the pilot streets and only went to the 140 because no one seemed to stock the 130.
Net-Tech is offline   Reply With Quote
Old November 6th, 2019, 02:46 PM   #7
AwDang
Motorcycle(s): 286, 296, 599, 799
IIRC; the IRC Road winner is a bias tire and the Pilot Sports are radial. That alone will change the feel of the bike.
AwDang is offline   Reply With Quote
Old November 6th, 2019, 10:02 PM   #8
JFMNINJA400
JFMNINJA400's Avatar
Motorcycle(s): GSXR 750, GSXR 600, Ninja 400, Ninja 300
Question 140 Michelin RS
I have a 2011 250R and I was planning on going with the Michelin RS front and rear. The Michelin RS works awesome on my Ninja 400, I have the 150 on the rear. A few of my track friends have the 140 rear on the 400 for even quicker steering. Do I need to pick up a used 300 rear for the 250 in order for the 140 to fit and work properly? Does the 300 rear bolt on without issue on the 250?
JFMNINJA400 is offline   Reply With Quote
Old November 6th, 2019, 10:21 PM   #9
yes
Old November 7th, 2019, 11:27 AM   #10
BoBO
BoBO's Avatar
Motorcycle(s): SC28 Fireblade
For reference, here is a picture of my 08 250 with N300 rear wheel and it's direct bolt on. I got the wheel from Ebay and went ahead and bought new bearings, axle, and tire to complete the wheel conversion fresh.
File Type: png Screen Shot 2019-11-07 at 10.21.03 AM.png (508.4 KB, 11 views)
94 900RR
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
BoBO is offline   Reply With Quote
Old November 7th, 2019, 05:10 PM   #11
JFMNINJA400
Thanks, I will def get the 140/17 and probably the n300 rear as well!
140/70 Tires kawasakidude 2008 - 2012 Ninja 250R Tech Talk 4 November 6th, 2016 03:03 PM
140 80 17 tires ZeroGravity360 2008 - 2012 Ninja 250R Tech Talk 255 August 14th, 2016 05:32 PM
bt45 140-70 H eddiekay 2008 - 2012 Ninja 250R Tech Talk 2 August 5th, 2013 02:33 PM
140/80/17 anyone? dragonboy 2008 - 2012 Ninja 250R Tech Talk 3 October 22nd, 2011 10:11 AM
140 and 110?? IndyTwoFiddy 2008 - 2012 Ninja 250R Tech Talk 8 June 7th, 2011 01:26 PM
