Old June 10th, 2011, 03:09 PM   #1
Archerzz
Motorcycle(s): 2007 Ninja 250r
Raising Idle RPM
So I noticed today on the way home from work after about 20 minutes into my ride that when I stopped my bike would only settle to about 2000 RPMs instead of its usual 1200-1500 idle. It was a crazy hot day and it had been in the sun all day dont know if that makes a difference or not but I figured I would throw it out there.
So what are the possible causes of this? Is it cause for concern?
Archerzz is offline   Reply With Quote
Old June 11th, 2011, 12:08 PM   #2
M
Motorcycle(s): Ninja 250 x2, Ninja 650R
Probably debris in the jet(s), which will cause the RPMs to 'hang'. You can try chemicals, such as Seafoam, or pull the carbs and inspect all the jets.
The Rally - Oklahoma
M is offline   Reply With Quote
Old June 14th, 2011, 12:05 PM   #3
seanski41
Motorcycle(s): 2007 Ninja 250R
Is seafoaming a bike recommendable? Got any quick tips on the process? Do you replace plugs like you would in a car?
seanski41 is offline   Reply With Quote
Old June 14th, 2011, 12:29 PM   #4
Lou
Lou's Avatar
Motorcycle(s): GreenSE 09 250R
Same thing here. On hot days when im out for a ride or coming home from work, my rpms stay higher up too after only about 10 mins into it. Not only at a stand still but on the road, @ 70mph im almost a full 1K up from usual. Any ideas why???
Lou is offline   Reply With Quote
Old June 14th, 2011, 12:51 PM   #5
DaBlue1
DaBlue1's Avatar
Air temperature can have an affect how an engine runs. Air density increases as air gets colder. This means that there are more oxygen molecules in the same space when the air is cold. When the temperature drops, the engine will run leaner and more fuel is needed to compensate. When the air temperature gets warmer, the engine will run a little richer.
6000 RPM Idle Dies with Throttle garman 1986 - 2007 Ninja 250R Tech Talk 3 August 9th, 2014 01:29 PM
High Idle RPM (during/after riding) Maielstrom 2008 - 2012 Ninja 250R Tech Talk 6 October 23rd, 2013 07:05 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
Return to idle RPM troubleshooting Momaru 2008 - 2012 Ninja 250R Tech Talk 11 June 12th, 2011 05:35 PM
High Idle RPM... wayanlam 2008 - 2012 Ninja 250R Tech Talk 4 July 20th, 2010 09:59 PM
