Old November 11th, 2014, 01:18 AM   #1
SwagenGTI
Motorcycle(s): 09 250R
Oil and coolant leak
So I had to quickly go for my last ride and winterize my bike since it decided to suddenly get cold and snow. Anyways, I didn't notice until today that my bike is leaking oil. I didnt have time to get more pictures but pretty much it seems like theres a like right behind the fairing...any ideas on what is leaking? Everythings just covered in sludge
Also, I am leaking coolant
I am assuming its all coming from this hose clamp and running down the rest of the tube...possibly from the other end of the hose/hose clamp.
I turned the bike on and couldn't see any leaks (from either the coolant or the oil) but obviously somethings leaking. Ill try to get more pictures tomorrow, just didnt have time since it was a spur of the moment ordeal and had to go to work.
SwagenGTI is offline   Reply With Quote
Old November 11th, 2014, 02:13 AM   #2
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
The oil leaks is most likely from chain lube on the chain dripping down from the front sprocket.
Tighten both hose clamps on the hose and clean it up as best you can and see if the leak has stopped or if the radiator has a pinhole leak where it exits the radiator at the hose.
Old November 11th, 2014, 10:10 AM   #3
SwagenGTI
It does feel super sticky like lube and would make sense as its not dripping. I just cleaned and relubed the chain a week ago and it wasn't there so you're probably right.
Old November 11th, 2014, 11:06 AM   #4
garth285
KAWASAKI GURU
garth285's Avatar
Yeah looks like chain lube to me!
As far as the coolant there could be some corrosion under that hose, now might be a good time to flush your coolant, clean off the connections, and tighten those clamps.
Old November 11th, 2014, 02:21 PM   #5
Foxrider64
Hello Moto
Foxrider64's Avatar
Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F
Be careful tightening these clamps. You can over tighten them and cause a small slit in the rubber.
I would drain the coolant, pull the hose and inspect the pinch points to ensure it isn't damaged first. Might as well.
Foxrider64 is offline   Reply With Quote
Old November 16th, 2014, 11:47 PM   #6
SwagenGTI
This is the first time I lubed without going for a ride first. I've always warmed up the chain, cleaned with kerosene, rode again then lubed. This time it was cold and I was in a pinch and ended up lubing after cleaning and letting it air dry. Learned my lesson.
Anybody have suggestions of the best way to clean the fairing? Shits sticky as hell and I cant just wipe it off...not sure what to use that will not melt the paint.
Old November 16th, 2014, 11:49 PM   #7
Cat-Man
Motorcycle(s): 2008 Ninja 250, 1974 RD350, 1996 CBR1000F
Citrus degreaser? It'll strip off wax but I doubt it would damage the paint. Re wash and wax after I'd imagine. Test on an inconspicuous spot first.
Cat-Man is offline   Reply With Quote
Coolant leak ttassinari48 1986 - 2007 Ninja 250R Tech Talk 4 December 23rd, 2012 11:59 AM
Coolant Leak ?? Redsvt 2008 - 2012 Ninja 250R Tech Talk 3 October 20th, 2012 08:24 PM
coolant leak 93etgocart 1986 - 2007 Ninja 250R Tech Talk 4 July 5th, 2012 11:21 AM
Coolant Leak? CaliGirl 2008 - 2012 Ninja 250R Tech Talk 12 July 11th, 2009 12:54 AM
Coolant Leak Rawr 2008 - 2012 Ninja 250R Tech Talk 12 May 11th, 2009 12:07 AM
