Old February 9th, 2012, 04:02 PM   #1
fyv0h
fyv0h's Avatar
Motorcycle(s): 2008 250r, of the blue variety (bestowed to Ninja_Duck22), 1998 CBR Smokin' Joe
In the dark
Literally. I turn the ninja on today, no headlights. All other lights are fine. Check fuse, it's fine. Throw the voltmeter to the fuse, nothing. no power to it at all. What gives? I searched here and google, neither of which offered relevant info...
Halp....
fyv0h is offline   Reply With Quote
Old February 9th, 2012, 04:03 PM   #2
fyv0h
fyv0h's Avatar
might add that the bike, otherwise, runs splendidly. the key is brand new too. cant imagine that playing a factor though
Old February 9th, 2012, 04:04 PM   #3
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Does the high beam work? If so I believe you can switch the high and low beam lights so at least you have a working headlight. Mine mysteriously went out as well. Luckily I was actually having a valve adjustment done and my mechanic replaced it for free =]
They could both be blown, take them out and check them.
AFM #676
Supersports are for n00bs
Old February 9th, 2012, 04:08 PM   #4
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
Maybe a solenoid or relay
Old February 9th, 2012, 04:11 PM   #5
flynjay
flynjay's Avatar
Did you check the plug at the back of the headlight?
Old February 9th, 2012, 04:12 PM   #6
fyv0h
fyv0h's Avatar
no, no headlights at all. and i just did some detective work. I taught my lady to drive Monday. I took a video. Looking at the vid, there were no lights there either. Now, on Monday, while she was putting around the yard (light working in this vid) the bike died. no power and dead battery. Light flickered before it lost power. I found the battery connection loose. Tightened and battery-tendered until it was charged. At that point, no light (says the next set of vids). So, post hoc ergo propter hoc. Any ideas?
Old February 9th, 2012, 04:13 PM   #7
fyv0h
fyv0h's Avatar
no power at sockets, but then i wouldnt expect there to be. fuse isn't powered. my voltmeter shows nada at the fuse. where the hell is the relay for that mofo?
Old February 9th, 2012, 04:38 PM   #8
fyv0h
fyv0h's Avatar
found relay. power to relay, not to fuse. relay sucks balls.
Old February 9th, 2012, 04:49 PM   #9
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
Test the coil circuit
Trust me, I'm a banana!
Felipe the Ant is offline   Reply With Quote
Old February 9th, 2012, 07:05 PM   #10
fyv0h
fyv0h's Avatar
went out and jumped the relay (Gray to Blue/Yellow) with bike running. lights came right on. I can't quite figure why my voltmeter didn't pick up voltage at the fuses, but I know power was rolling through. All other fused items work, but my meter isn't reading anything from the fuse block. Dead fuse should keep voltage from one of the two powers at the relay, right? I have both hots showing power. I dunno. Too cold to enjoy a ride now anyway.
Old February 10th, 2012, 07:43 AM   #11
flynjay
flynjay's Avatar
With just key on you shouldn't have power past the relay. There is something that triggers once the bike is started that powers up the light, check that.
Old February 10th, 2012, 07:28 PM   #12
fyv0h
fyv0h's Avatar
you're correct.
Old February 10th, 2012, 07:44 PM   #13
Scattcatt
Scattcatt's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR
If I find a solution I'll let you know. My headlights die all the time when I hit a bump or something. It's a problem I've had ever since I bought the bike. Only way I've found to turn them back on is to key off/on which is kind of sketch on the freeway at night but hey, gotten pretty good at it by now. Granted, my bike came with purple Luminez HID bulbs in it which may be the problem.
ATGATT
Scattcatt is offline   Reply With Quote
Old February 11th, 2012, 10:07 AM   #14
Felipe the Ant
http://www.mickeywebpages.com/users/...e_Dia_v1.1.gif The coil side of the relay gets its power from the oil pressure switch. Turn the bike on and test for power on the coil circuit, if you have power replace the relay. Don't forget to test the ground too
Unless you happen to have an easy source of 12V that you can connect the relay to, connect the coil and listen for a click then test continuity on the switch side.
Old February 11th, 2012, 09:37 PM   #15
Colezombie
Colezombie's Avatar
Hey,
My low beam has been of for a few weeks now, and tonight I noticed (on my way home from a friends in the dark) that the high isn't working now.
I am wondering how to solve this, as my little ninja is my only mode of transportation right now haha..
My friend has a 2011 that does the same damn thing.. guess kawi cheaped out on something?
'09 250R
woodcraft clip-ons
2 bros slip-on
Colezombie is offline   Reply With Quote
Old February 11th, 2012, 10:28 PM   #16
Could be as simple as a new bulb, they do burn out over time.
Old February 12th, 2012, 11:20 AM   #17
Colezombie
Colezombie's Avatar
Pretty short time for a bulb, I assume.
'09 250R
woodcraft clip-ons
2 bros slip-on
Old February 12th, 2012, 12:23 PM   #18
Scattcatt
Scattcatt's Avatar
Have the bulbs been replaced before? I've heard that touching them with your fingers dramatically shortens their life. (touching the glass part of the bulb) not sure if it's true or not, but if they have been replaced before and really are dying, then it might explain why they could be going out so quickly
ATGATT
went to dark side polokid699 The Ex-Ninjetters Lair 5 August 13th, 2014 09:11 PM
[superbikeplanet.com] - And Now It's Dark ... Ninjette Newsbot Motorcycling News 0 November 19th, 2012 10:40 AM
Morons in the dark Toly Ride Reports 2 October 27th, 2012 04:27 PM
Off to the dark side... etiainen The Ex-Ninjetters Lair 23 May 16th, 2012 04:38 PM
Dark Oil? paterick4o8 2008 - 2012 Ninja 250R Tech Talk 14 August 5th, 2009 04:01 PM
