Old February 18th, 2012, 03:31 PM   #1
planet-beaver
Motorcycle(s): Ninja 250, Vulcan 500
All dark, no juice
So I disconnected my trickle charger. Turn the key, everything lights up. Hit the ignition switch, everything goes black. Swapped the battery from a second bike. Same, nothing lights up. Checked all the fuses, all good. Never had anything like that before. Any Ideas.
planet-beaver is offline   Reply With Quote
Old February 18th, 2012, 11:22 PM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Push start it, see if it works
AFM #676
Supersports are for n00bs
Old February 19th, 2012, 07:00 AM   #3
Skippii
Milkshake Drinker
Skippii's Avatar
Do the lights come back on when you release the button? If so, jump start it.
Posted via Mobile Device
Old February 20th, 2012, 04:01 PM   #4
planet-beaver
The bike would not jump start. Started flowing the wires and found the wire that runs from battery with a bad spot. The rubber jacket on the wire was good but the wire inside was broken.
Old February 21st, 2012, 06:00 PM   #5
Skippii
Milkshake Drinker
Skippii's Avatar
Glad you figured it out. Get it fixed yet?
"What a sweetheart."- ninja_sleeper to me
Need Help! Dropped juice straw inside clutch cover kael0206 2008 - 2012 Ninja 250R Tech Talk 18 June 16th, 2011 03:20 PM
Garbage truck juice rockNroll General Motorcycling Discussion 13 May 1st, 2011 09:31 PM
[hell for leather] - Vectrix runs out of juice Ninjette Newsbot Motorcycling News 0 April 14th, 2009 09:40 PM
[tilted horizons] - GPS Juice Ninjette Newsbot Motorcycling News 0 June 12th, 2008 01:11 PM
