Old June 29th, 2010, 09:09 PM   #1
///NR
///NR's Avatar
Motorcycle(s): x
Power loss at high rpm
2009 Ninja 250R completely stock with under 3,000km. The motorcycle has no issues starting and idles fine. Driving in the city it seems fine except when pushed to higher rpms the power seems to cut out. On the highway it's very noticeable as the bike struggles to get up pass 110km/h (65mph). This is with throttle completely open but if rolled back a bit bike seem to run smoother. If pushed harder then it seems to rock on the highway slightly like gaining and losing power. So far I've run a couple tanks with Seaform added but the issue hasn't gone away. I was hoping someone may have some insight into the problem.
///NR is offline   Reply With Quote
Old June 29th, 2010, 09:16 PM   #2
is this something that has recently developed or is it something the bike has always done?
Old June 29th, 2010, 09:24 PM   #3
///NR
///NR's Avatar
Motorcycle(s): x
2nd owner on the bike which pretty much sat for it's first year as the owner didn't get a chance to really drive the bike. I was primarily driving it within the city for the 1st month but then noticed the issue when I finally took it on the highway. Called the dealer and they suggested running a couple tanks with Seaform but issue hasn't gone away.
Old June 29th, 2010, 09:28 PM   #4
pop the air box cover and have a peek at the air filter to see if it's dirty.
Old June 29th, 2010, 09:34 PM   #5
I'm guessing pinched fuel line somewhere. It's not spark, so it's starving for air or fuel. Lift the tank, make sure all lines are free and clear, and perhaps the problem goes away. A plugged vent hose could do it as well. To confirm that it's not just bad venting from the gas tank, leave the gas cap open, take it up to 65 and see if the power still tails off. If it is now fine, it's a venting issue with the tank that is keeping the fuel from flowing out as it needs to.
Loss of Power, Won't go past 7k RPM denshidereku 1986 - 2007 Ninja 250R Tech Talk 38 March 17th, 2015 08:18 PM
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
High handle bar vibration, hard to get into high RPM, is this normal? jackliu239 1986 - 2007 Ninja 250R Tech Talk 24 September 19th, 2013 09:04 PM
Loss of power at certain RPM The_big_dill 1986 - 2007 Ninja 250R Tech Talk 21 July 14th, 2013 01:32 PM
power loss - mid to high rpms/bike newb sparmek 1986 - 2007 Ninja 250R Tech Talk 9 December 16th, 2011 08:02 PM
