Old September 12th, 2018, 06:03 PM   #81
Huh? I just installed pulled 30mm carbs from my new-gen. Slides are definitely metal.
Also I'm with HoneyBadger on this one. Same incomplete experiment as the entire jetting-DB with absolutely zero before & after comparisons. Vast majority of people have dirty clogged carbs, thus need to send them to ducatiman for refurbishing. Of course, they'll run better afterwards. The improvement is in the thorough cleaning, not in actual larger bore of carbs.
Besides, majority of restriction is in head anyway. You gotta do some porting clean-up to get more flow through. Then perhaps larger carbs may improve power.
Old September 12th, 2018, 07:18 PM   #82
Ceeloo Yello
Motorcycle(s): 250
Didn't know new-gen slides were metal as I have a pre-gen but still wonder why the difference.
Old September 13th, 2018, 04:51 AM   #83
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
i'm pretty sure the vacuum diaphragm slides are plastic on my 2009 model
gantt is offline   Reply With Quote
Old October 1st, 2018, 05:43 PM   #84
Ceeloo Yello
Motorcycle(s): 250
I guess it will remain a mystery.
Old October 2nd, 2018, 12:41 PM   #85
gantt
gantt's Avatar
seems plastic to me, its not ferrous, and i used a pick and produced a small scratch with ease. pretty sure they are plastic. @DannoXYZ possible your carbs are different than mine? your bike is a US model correct?
Old October 2nd, 2018, 01:05 PM   #86
Yes, I'll have to take closer look. Appears to be aluminium.
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
fs refurbed 86-87 250 32mm carbset ducatiman Motorcycle-related 11 September 2nd, 2016 05:11 PM
1986-87 32mm carburetor jets and needles Yamahawk 1986 - 2007 Ninja 250R Tech Talk 17 March 21st, 2016 06:18 AM
Valve adjustment, carb clean, carb sync? amad1972 1986 - 2007 Ninja 250R Tech Talk 2 July 29th, 2014 09:42 PM
A thought experiment on carb syncing thru-out the rev range headshrink 2008 - 2012 Ninja 250R Tech Talk 7 July 15th, 2011 02:01 PM
