Old October 13th, 2018, 06:38 PM   #1
hilli_micha
2006 Ninja 250 Engine ticking between 2k-4k RPM
Hello all,
I have a 2006 Ninja 250 that I have had for about a month now. Sitting at 10,333 miles. I got the bike at just around 9,900 miles, give or take.
On my last ride, I noticed a ticking sound coming from the front side of the engine that I had not noticed before. This sound only seems to come on between 2k-4k RPM and will 'typically' go away once it gets back to idle, some times it takes a moment.
Beyond the sound, the bike runs just fine as far as I can tell, but I'd certainly like to make sure it stays that way.
Here is a video of the sound in action - https://streamable.com/8mmwz
Edit: Here is another video, emphasizing the noise - https://streamable.com/4fid8
Edit: I see in the video that the idle appears to be above 1,500 RPMs, bad camera angle. I have it dialed in at 1,400-1,500.
For what it is worth, I have not adjusted the valves yet, I know that is recommended at 10,000 miles and I will be getting around to that. However, given the sound, anything else I should be looking at when I do that?
hilli_micha is offline   Reply With Quote
Old October 13th, 2018, 07:46 PM   #2
greg737
Motorcycle(s): -
You've definitely got a "ticking sound" there, although I would say it's more of a "clatter". Good job on the videos, often people post cell phone videos that are so bad you can't hear the noise they're talking about.
It sounds like something's up with the engine's Cam Chain. In the video it sounds like the Cam Chain isn't being properly tensioned which means it will lash when the engine RPMs decelerate. When you rev the engine the Cam Chain gets pulled into an smooth, organized form, but when the engine slows it sends a shock through the Cam Chain and it gets disorganized and lashes for a while, then slowly smoothes back out.
I think your first troubleshooting step should be to remove, clean, re-grease and properly re-install the Cam Chain Tensioner (following the Service Manual, base manual, procedure Chapter 4, pages 4-7 to 4-8, instead of just guessing at how the thing is supposed to be handled).
It could be as simple as a tensioner thats not doing its job.
Old October 13th, 2018, 08:20 PM   #3
hilli_micha
Thumbs up
Greg,
I think you are right. After I posted this I did some research, the sound from my end definitely sounds like a chain moving around so my research lead to the CCT causing a bit of a fuss, evidently it's a super common issue with these bikes. So I lead
I popped off my CCT, cleaned it, lubed it up real nice (with engine oil), and reinstalled as per procedure and the sound has disappeared. Fortunately the CCT looked to be in good shape, no burring or scoring, just the oil that was on it looked a bit old and gummy, which is strange the oil in the engine is only a couple of months old.
Oh well, I know now that this is something to keep a constant eye on.
Thanks for the reply!
Old October 13th, 2018, 08:29 PM   #4
greg737
Motorcycle(s): -
Originally Posted by hilli_micha View Post
Greg,
Good job. Yes, when the CCT goes for a long time (like years and years and years) without any maintenance it does get gummy/sticky. It gets this way because it hangs from up at the top of the crankcase which means it doesn't get regularly bathed in engine oil. So when it gets really good and sticky the normal backlash that the Cam Chain experiences on RPM deceleration it will "pack" the tensioner pushrod/plunger backwards up into the CCT body and there it will stay (until you come along and service it).
I use Lucas Engine Assembly Lube when I refurbish the CCT on my '05 EX250.
Infrequent engine ticking at low rpm ThePursuer 2008 - 2012 Ninja 250R Tech Talk 7 July 22nd, 2018 06:28 PM
07 250r ninja Engine ticking strickcharles5 1986 - 2007 Ninja 250R Tech Talk 5 May 4th, 2017 08:36 PM
Ninja making ticking noise from engine area zaknifein 1986 - 2007 Ninja 250R Tech Talk 42 May 4th, 2017 08:28 PM
2006 Ninja 250 High Idle RPM GunnaBoyEB 1986 - 2007 Ninja 250R Tech Talk 4 September 4th, 2014 10:30 AM
