Old September 13th, 2012, 12:14 AM   #1
Tiane
Motorcycle(s): NINJA300
Question Pod air filter vs drilled airbox ???
Looking for the best performance out of my 250 FI, Leo Vince recommends drilling 2 50mm holes on the airbox, but what works best pods or drilled airbox?
Also, can I even install a pod filter on a 250 FI
Tiane is offline   Reply With Quote
Old September 13th, 2012, 12:34 AM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
I would imagine pods but I have no experience with drilling the airbox. It seems like a drilled airbox would yield less airflow than pods so idk. Is it a full leo vince system? And yes you should be able to put pods on the FI
AFM #676
Supersports are for n00bs
Old September 13th, 2012, 01:24 AM   #3
psych0hans
psych0hans's Avatar
Yes, I have pod filters on my FI 250... K&N0990
Old September 13th, 2012, 05:31 AM   #4
Tiane
Cool, I found your thread that asked the same:
http://www.ninjette.org/forums/showthread.php?t=101440
What did you do with the sensors?
Do you have any pictures to help me mod mine?
Did you installed the pod straight to the throttle body? It looks like the runners are attached or part of the airbox
Thanks
Old September 13th, 2012, 05:41 AM   #5
psych0hans
psych0hans's Avatar
Thanks
Honestly, I got mine done at the service center. I'll take a few pics for you tho. I believe they tied the sensor to the frame and left it at that. Also, the filter is attached to the runners, not directly to the throttle bodies. I believe they got it out the back, by removing the wheel and pretty much stripping everything after the gas tank... lol I was considering doing it myself, but the last time I removed my under tail, I landed up breaking my rear cowl fairings.
Old September 13th, 2012, 05:51 AM   #6
Tiane
Sounds good,
Thanks
Old September 13th, 2012, 06:16 AM   #7
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I don't know about the FI bikes. But I would say for street riding,drilling the air box is a good thing. I would also remove the fire screen from inside the air box. That makes it easyer to remove. The snorkel can also be removed.
Worlds fastest 250 ninja
Old September 13th, 2012, 06:23 AM   #8
Ricmon
Motorcycle(s): '10 Ninja 250r FI
Is that LeoVince a slip-on? You NEED a PCV or something like that right?
Ricmon is offline   Reply With Quote
Old September 13th, 2012, 06:35 AM   #9
Racer x
Racer x's Avatar
The only vent from the crank case is the hose nipple that comes up from the block under the air box. Most people just put a small filter on it. If you run a full system you need to block off the top of the valve cover.
Old September 13th, 2012, 09:41 AM   #10
psych0hans
psych0hans's Avatar
Pictures
Pics of my install...
Old September 13th, 2012, 09:41 AM   #11
On my pregen, I ran a full exhaust and an airbox that was cut open. It ran really well with one size larger main jets. It was still reliable, but had a little throatier sound, and was a little more responsive. I imagine that a full exhaust, opened airbox, and a high-flowing drop-in filter would pull and respond quite nicely.
Old September 17th, 2012, 03:27 AM   #12
Tiane
Yes, I recommend a PCV or any fuel management system, I bought the Bazzaz with autotuner.
Old September 17th, 2012, 03:28 AM   #13
Tiane
Great, do you have a FI light?
Thank you
Old September 17th, 2012, 05:05 AM   #14
psych0hans
psych0hans's Avatar
Thank you
Yes sir, the Indian ninja's are all FI...
Old September 17th, 2012, 05:07 AM   #15
Racer x
Racer x's Avatar
I found on the dyno that the 0990 or pod filters kept some torque. I run wide open velocity stacks with no air filter. I is worth almost 1 hp but gives up some torque. A well desined air box should have better midrange.
Old September 17th, 2012, 05:17 AM   #16
Tiane
I mean, the FI light on? (because of the sensors that are hanging off)
Old September 17th, 2012, 05:20 AM   #17
Tiane
Yes, the bike still for street use... If I decide to keep the airbox I'll remove the fire screen and the snorkel is being remove since day one
Thanks
Old September 17th, 2012, 06:41 AM   #18
psych0hans
psych0hans's Avatar
@Tiane no, the FI light is not on.
Old September 17th, 2012, 06:41 AM   #19
psych0hans
psych0hans's Avatar
Pod or replacement filter vmax 2008 - 2012 Ninja 250R Tech Talk 4 August 4th, 2014 09:30 PM
K&N Pod filter mwirrick Ninjettes At Speed 13 January 10th, 2014 05:57 PM
Anyone know an air filter I can replace the OEM filter with? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 5 July 22nd, 2012 09:34 AM
FI Bike Remove Airbox or performance air filter menno 2008 - 2012 Ninja 250R Tech Talk 3 October 5th, 2010 02:01 PM
Which pod filter do you use? null0 1986 - 2007 Ninja 250R Tech Talk 13 December 1st, 2009 12:36 PM
