Old August 17th, 2018, 11:28 AM   #1
nixter
Motorcycle(s): 2099 ninja 250
Purchased used 2009 250. lights issue
Hey guys, first post. I helped a friend buy her first bike a couple days ago and rode it home for her. It ran great even having sat for a year. Got a good deal on it but none of the signals work and also the high beam doesn't work. Fuses are fine. Main headlight, horn, fan, all good. Where to look next? relays?
Thanks,
n
nixter is offline   Reply With Quote
Old August 17th, 2018, 11:49 AM   #2
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
do you have a test light, or multimeter? you could check for voltage at the light sockets. also check bulbs, unlikely that they are all blown, but i have seen an alternator on a truck overcharge and blow almost every bulb on the entire vehicle.
make sure turn sig's are connected, behind the fairings and under the rear seat.
with a way to check for voltage, you can see where the voltage is, and where it is not, allows you to pin point what area or component is at fault
gantt is offline   Reply With Quote
Old August 17th, 2018, 11:59 AM   #3
nixter
Thanks Gantt! is there a way to test the relay with out replacing it?
Old August 17th, 2018, 06:11 PM   #4
gantt
gantt's Avatar
If your bike has more than two relays, say the fan relay. If the fan works, the relay works. Swap the known good relay to the suspected relay. See if the fan still works with the suspect relay. And the turn signals work with the known good. You can test a relay, but requires hooking 12v to one pin, ground to another pin. And checking ohm's at the other two pins with a multimeter. That's the "correct" way. But I can tell you as a diesel mechanic, swapping with a known good is the fastest way to check your relay.
Has anyone purchased this? zhuuka 2013 - 2017 Ninja 300 Farkles 12 June 1st, 2016 09:23 PM
Purchased my 300! Arbatrix 2013 - 2017 Ninja 300 General Discussion 15 December 16th, 2012 12:02 PM
Added lights to the rear pods - now having issue iplante 1986 - 2007 Ninja 250R Farkles 5 July 24th, 2012 12:47 PM
Purchased used ninja... what now? 47ninja 2008 - 2012 Ninja 250R Tech Talk 7 March 30th, 2012 11:28 AM
Friend's newly purchased 2005 250R: Neglected battery issue CZroe 1986 - 2007 Ninja 250R Tech Talk 16 March 17th, 2011 05:59 AM
