Old March 16th, 2014, 01:10 PM   #1
[motorcycle.com] - Church Of MO First Impression: 1998 BMW K1200RS
It’s big, it’s heavy, and it’s undeniably BMW. In this week’s Church of MO, we’re going back to 1998 to see how Billy Bartels got along with BMW’s autobahn burner, the K1200RS. Today the K bikes are known as sport-touring machines known more for their touring abilities, but capable of handling a twisty road or two if needed. Before the K12 however, the K bikes had a reputation for being big porkers with incredible reliability being its main redeeming quality. Truth be told, K bikes are still rather portly, but BMW has found a way to turn that into a positive. Read on and you’ll see that Bartels agrees.
Autobahn Baby
By Billy Bartels*Feb. 20, 1998
Photos by BMW and Bartels
BMW put together a $400 accessory package, including heated grips, luggage rack, and saddlebag supports.
“What do you choose to ride,”we pondered in our original Open Sportbike Shootout “if you need to be in Denver tomorrow? If you need a bike that will travel highway miles, but still leave a smile on your face in the twisties, and leave everyone else in the weeds?” BMW thinks they have a solution for that dilemma. The new K1200RS.
Although supported by a fanatical core of enthusiasts, BMW’s famed K-bike was flawed. It was obvious that in order to grab a bigger share of an increasingly competitive market, the quirky — yet reliable — K was going to need a major redesign. Key complaints against the “flying brick” were threefold: 1) It Buzzed 2) It was slow 3) The handling wasn’t so great. Why the fanaticism? Simple, they were great long-distance tourers that tended to be more exciting than riding a Winnebago (Goldwings, FLTs, etc…). They also tended to last 200,000-plus miles.
K12′s complex adjustable footpeg/shifter setup.
BMW’s new K1200RS was designed with the goal of fixing the K-bike’s shortcomings while still respecting the model’s legendary sport-touring status. BMW informed us that above all they would not compromise the touring ability of the RS for sporting prowess.
BMW succeeded, with such touches as adjustable clip-ons, footpegs and shifter, and an improved two-position seat. Carried over from elder Beemers was BMW’s patented Paralever Shaft drive, as BMW refuses to blend into the sportbike crowd with a chain drive. Contributing to the even feel is BMW’s first six-speed transmission. Smoother than its five speed predecessor, it’s also equipped with a higher top gear ratio.
K1200RS is the first Beemer to have its motor isolated from both rider and suspension.
That fabled K-bike buzz is gone. A rubber isolated engine/tranny combo still buzzes, perhaps more than the old one, but none of it ever reaches the rider. Only in a small section of rpm between 4200 and 4700 does the chassis harmonize with the motor. As you might expect, isolating the engine required a significant weight penalty in the form of a complex and heavy (53 pound) aluminum frame.
While BMW’s chassis technicians were tuning out the buzz, their engine-eers were adding shovel-loads of horsepower. The result? ‘Slow’ is not in this bike’s vocabulary. BMW claims an awesome 130 rear wheel horsepower for the RS.
K1200′s adjustable windshield in the lowered position – where it stayed.
Impressive as that figure is, its torque figures are even more outstanding. There is a hearty 65 ft-lbs of torque at 3000 rpm and 85 ft-lbs at 6750, and that means unparalleled passing power and acceleration. During impromptu top-gear runs, we were able to bump 145 mph and it was still pulling hard. Clearly, there was plenty more to be had.
With an engine capable of effortless triple-digit cruising, BMW knew their ‘bahn-burner would need effective bodywork. The windtunnel-designed unit fitted to the 1200 offers excellent wind protection, even at higher speeds. In fact, it may even be overkill for travel in the U.S., as speeds under 70 mph tend to place a bit too much weight on your wrists.
Our mount came in “Arrest Me” red.
While on the topic of speed, this thing is Stable (capital intended). Trying to induce headshake is futile, as the RS refuses to shimmy. BMW claims this innate stability is partially due to a two-stage steering damper (more on that later), and also to the Metzeler tires and their “zero ratio” construction.
An unusual design choice was a 5mm right offset of the rear wheel. According to BMW engineer Berthold Hauser, this makes up for a slight weight bias to the right. Conventional engineering would expect the bike to shimmy in corners, but we can attest this is not the case.
The blue metallic model was very appealing.
The trade off for such stability is that the K12 is not a quick steerer. Flickability is significantly slowed by the steering damper and the lengthy (61 inch) wheelbase. The two-stage damper is not noticed when diving into a turn, but you’ll feel it during a full-lean transition. BMW never intended this bike to be a canyon strafer. Instead it excels on those long sweeping corners that are so abundant in South Carolina.
Pulling the claimed 630-pound (wet) beast down from speed you’ll find tried and true four-piston Brembos, equipped with BMW’s Anti-Lock II. It’s been said before – this system works. Don’t worry, just grab a handful of brakes and the bike will do the rest. You feel odd doing it, but it’s easy to get used to. Anti-dive rates have been increased, reflecting the K12′s sportier focus and further contributing to the bike’s confidence-inspiring ride.
The flamboyant yellow and grey checkered-flag design comes as a $500 option.
Time for a reality check. The new K1200RS is first and foremost a touring bike. It’s just that this touring bike goes really, really fast.
What could be a major drawback in the touring department is the fact this thing sucks gas. Ridden aggressively, it will only return about 30 mpg, although one BMW staffer was happy to loaf along in sixth, netting over 40 mpg. Range as tested came in around 200 miles.
At $15,999, BMW’s K1200RS is high compared to its Japanese competition. BMW officials were quick to point out though, that the K1200RS is less than four percent higher than their old K1100RS. When you crunch the numbers that way, their new and improved RS is quite reasonably priced.
The usual four piston ABS Brembos, with trick floating discs attached directly to the wheels.
700 miles later we wish we had more challenging twisties to test the bike in. What we discovered in the long, sweeping curves of South Carolina was a good touring bike with a real serious engine – not some watered-down liter bike. BMW’s new K1200RS is a genuine performance-tuned, big-bore tourer that’ll have you looking forward to that next bend in the road.
Specifications:*
Manufacturer: BMW Model: 1998 K1200RS Price: $15,990 Engine: Liquid/oil cooled inline four-cylinder Bore x stroke: 70.5mm x 75mm Displacement: 1171cc Carburetion: Bosch Motronic fuel injection Transmission: Six speed Wheelbase: 61 inches (unladen) Seat height: 30.3/31.5 inches Fuel capacity: 5.5 gallons Claimed dry weight: 586 lbs. Claimed wet weight: 628 lbs.
Church Of MO – First Impression: 1998 BMW K1200RS appeared first on Motorcycle.com.
Click here for full story...
[motorcycle.com] - Church Of MO 1998 Polaris Victory V92C Ninjette Newsbot Motorcycling News 0 April 5th, 2015 04:50 AM
[motorcycle.com] - Church Of MO 1998 Yamaha V-Star 650 Classic Ninjette Newsbot Motorcycling News 0 May 25th, 2014 07:50 AM
[motorcycle.com] - Church Of MO First Impression: 1997 Honda 750 Magna Ninjette Newsbot Motorcycling News 0 May 11th, 2014 07:11 AM
[motorcycle.com] - Church of MO – 1998 Honda CBR900RR Review Ninjette Newsbot Motorcycling News 0 March 31st, 2014 04:10 AM
[motorcycle.com] - Church Of MO First Impression: Honda Pacific Coast 800 Ninjette Newsbot Motorcycling News 0 March 2nd, 2014 10:40 AM
