Old May 14th, 2013, 01:12 PM   #1
wsrussell7
Motorcycle(s): ninja 250r
Bike Won't Idle below ~2500rpm
Hey guys, I'm having a problem getting my 08 ninja running properly. I bought it recently and it has problems starting up and idling. It has ~2000 miles on it and a K&N R-0990 Oval Filter.
When I start the bike up, I have to apply the choke halfway and turn it over for at least 5-7 seconds before it'll start. Then the bike may either rev out to 7krpm or die out. Sometimes it'll run fine and i can turn the choke off after riding a block or so. After its warmed up it won't idle much below 3k rpm and definitely not anywhere close to 1250-1500.
I just went in today and bumped up to a 110 main from a 100 main jet. The carbs were extremely clean and so was the stock pilot jet. The clip is on the 4th spot from the top of the needle.
Any ideas on why it won't idle?
wsrussell7 is offline   Reply With Quote
Old May 14th, 2013, 01:15 PM   #2
Joshorilla
Bass Master General
Joshorilla's Avatar
You need to play with your jetting, you are probably not getting enough fuel as these bikes run lean at low rpm ranges.
Look at other people with similar setups here, ask what they did in terms of jets.
Old May 14th, 2013, 01:18 PM   #3
lgk
check your idle screws, and all the vacuum hoses are connected properly.
what pilot jet do you have?
Old May 14th, 2013, 01:21 PM   #4
Joshorilla
Bass Master General
Joshorilla's Avatar
I believe he has a stock pilot jet
Old May 14th, 2013, 01:25 PM   #5
first of all, put the airbox back in. theres no benefit to pods outside of sheer laziness. no power benefit. nothing. in fact the best tune you'll get on pods will be worse than the best tune you'll get with a box. if you want more flow, take out the snorkel... use a higher flow filter or no filter if you must. but keep the airbox. the airbox smooths the air flow giving you the potential for more power vs a pod filter or straight vstacks (without a box)
secondly, the pilot jet controls the amount of fuel going into the system at idle. only the pilot. (well and the choke which is a fuel enricher) so if it has trouble idling, the pilot jet is likely the piece that needs to change.
Old May 14th, 2013, 01:32 PM   #6
wsrussell7
After reading posts here, I would agree, but I bought the bike like this so that's not really an option. I went off of what others were posting in the jetting database hoping to get close, but I'm still having the problems so I was just wondering if something else could be wrong.
And yes it has the stock pilot in.
Old May 14th, 2013, 01:50 PM   #7
wsrussell7
I've just been adjusting the idle mixture screws. Now I've got it to the point where it will idle at 2500 rpm and from there if I give it gas it will rev great. If I lower the idle any, it barely idles and if I give it gas it bogs and dies immediately.
Should I try a 40 pilot jet?
Old May 14th, 2013, 02:04 PM   #8
lgk
if everything else looks good then yes.
Old May 14th, 2013, 02:17 PM   #9
DaBlue1
DaBlue1's Avatar
Are you in Charleston, WV (mountains) or Charleston, SC (sea level)?
How many turns out on the idle mixture screws did you go?
Can you adjust the idle speed with the idle adjustment knob at all?
What type of exhaust do you have?
Idle speed should be set when the bike is completely warmed at 1300 +/- 50 rpms.
A 40 pilot jet is unnecessary. You should be able to get it to idle fine with the stock 38. Have a good read and look at the link below. Should offer you some good insight for your jetting needs
Motorcycle Carburetor Theory 101
http://www.motorcyclecarbs.com/carbs101.pdf
Old May 14th, 2013, 02:23 PM   #10
wsrussell7
SC at sea level. I started at about 2.5 turns out and went .5 turns each time until they were all the way turned out. If I adjust the idle knob any below 2500 rpm, the motor just dies. It has the stock exhaust.
Old May 14th, 2013, 02:55 PM   #11
DaBlue1
DaBlue1's Avatar
How long have you had this bike and how long had it sat before you got it?
Did you physically clean(blow compressed air, poke fine wire thru) the pilot jets at all?
Did you synch the carbs?
Old May 14th, 2013, 03:12 PM   #12
cuong-nutz
cuong-nutz's Avatar
Were the diaphragms tear-free when you opened carbs? Like dablue1 suggested. Remove the jets and clean them out so that way you know they're good instead of guessing. Also, make sure your rubber boots that connect the carbs to the engine is on snug and not loose.
110 mains sounds rich to me with a stock exhaust.
HalfFast Racing Team
Old May 14th, 2013, 03:19 PM   #13
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
There's an easy way and hard way to do this, hard way is continue to try matching the jetting to your setup.
Easy way is to find some other retard who believes the airbox is for noobs(or something) and doesn't need his so you buy it and install it. No guess work, just work proven to work.
If you continue down the hard path I wish you the best of luck because you are a more determined soul than I.
Old May 14th, 2013, 03:20 PM   #14
lgk
just install an EFI kit, lol.
Old May 14th, 2013, 06:03 PM   #15
wsrussell7
Im not sure how long it sat, but it was for a while since it only had a few hundred miles on it when i bought it.
I pulled the pilot jets and checked, they were spotless, as was the rest of the inside of the carbs. I was surprised actually. After reading on here, i thought for sure that was part of the problem, so I was ready to clean the hell out of everything. I sprayed most of the insides down anyway though.
I have yet to sync the carbs. I guess that's my next step. What kind of problems would you experience with out-of-sync carbs?
Old May 14th, 2013, 06:05 PM   #16
wsrussell7
Yeah as far as I could tell when I was looking at the needles, the diaphragms were in good shape. And the carbs were on there pretty well too. The 110 pulls much better throughout the upper range of the rpms now, where as before it felt like the bike would fall flat on its face after lik 8k.
Thanks for all the help so far guys!
Wahhhh!!! My Bike Won't Start/Run/Idle... Can Someone Help!!??? kkim 2008 - 2012 Ninja 250R Tech Talk 71 February 3rd, 2023 08:19 PM
Valve adjustment and now bike won't stay idle har0ld 2008 - 2012 Ninja 250R Tech Talk 13 December 16th, 2012 06:16 PM
Bike won't idle! Halp plox! SemperFudge 1986 - 2007 Ninja 250R Tech Talk 24 September 29th, 2012 09:09 AM
Changed plugs, bike won't idle.. pixelpete 1986 - 2007 Ninja 250R Tech Talk 9 April 20th, 2010 11:22 AM
Help! Dewinterizing But Bike Won't Idle Without Choke azia 2008 - 2012 Ninja 250R Tech Talk 46 March 8th, 2010 01:28 PM
