Old May 10th, 2011, 05:07 PM   #1
jenndiggity
jenndiggity's Avatar
Motorcycle(s): Black 2011 Ninja 250R
another neutral gear?!
I know enough about manual transmissions to know there is no neutral gear between 5th and 6th, but on a few occassions after I upshift out of 5th it revs as if not in a gear! I just bought it friday so I'm sure a clutch adjustment might help me hit 6th more firmly, but anyone else have this problem?
jenndiggity is offline   Reply With Quote
Old May 10th, 2011, 05:12 PM   #2
rockNroll
rockNroll's Avatar
Motorcycle(s): black
If you're hitting a false neutral when clicking up from 5th you most likely need to check out your shift linkage for bent/worn parts or adjustment. Being yours is a 2011 I'd think maybe linkage adjustment.
Old May 10th, 2011, 05:16 PM   #3
1994Ninja250F
‘94 Rider
1994Ninja250F's Avatar
Motorcycle(s): 1994 Kawasaki Ninja EX250F
Either that or the OP needs to fix his shifting technique. When shifting up, keep pressure on the shifter when letting out the clutch. This will force the transmission to engage that gear and virtually fixes false neutrals all together. Unless like the above poster said, something is bent or out of alignment.
1994Ninja250F is offline   Reply With Quote
Old May 10th, 2011, 05:19 PM   #4
rockNroll
rockNroll's Avatar
She could be just not used to shifting yet, perhaps just not clicking up hard enough, but If you have to keep pressure up on the shifter while engaging the clutch there's something wrong.
Old May 10th, 2011, 05:23 PM   #5
jenndiggity
Next tech day I'll adjust my shifter and rule that out first-thank u thank u thank u!
Old May 10th, 2011, 05:29 PM   #6
1994Ninja250F
‘94 Rider
Well sure you don't have to do it, but it's one way to eliminate getting a false neutral. Personally, I don't do this, I've just heard of it. I used to have problems with false neutrals every now and then but like you said, just kick up nice and hard each time and it's a non-issue.
Old May 16th, 2011, 08:05 PM   #7
jenndiggity
So that didn't work. Adjusted the shifter down (thanks Kevin!) and it still doesn't catch the 6th gear. THEN TODAY I was at a stop sign and thought I was in first but when I went to take off it revved as it would in neutral, then the Neutral light came on! I'm still under manuf warranty and was going to take it in to Kawi dealer; I don't want to do any DIY that would negate the warranty.
Old May 16th, 2011, 08:09 PM   #8
yep, take it back and have them check it out. is it something that happens with consistency? They will want to see what you're talking about and be able to reproduce your problem when you take it in.
it does sound like you may have a transmission problem, but let the dealer sort it out.
Old May 16th, 2011, 08:32 PM   #9
DaBlue1
DaBlue1's Avatar
When shifting up or down, you have to left off of the shift lever a lil' bit after the shift. So shift up, relax the ankle, let the lever naturally drop back down, shift up again. Same thing going down, makes things a lot smoother.
Old May 16th, 2011, 08:42 PM   #10
MrEmmortal
MrEmmortal's Avatar
Motorcycle(s): 2011 250r pearl se
This happens to me some of the time. I believe it is me not making a complete shift, as it tends to happen thru out the gear box, from time to time.
MrEmmortal is offline   Reply With Quote
Old May 16th, 2011, 08:46 PM   #11
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
Jennifer, I dont know if it really is a problem with the bike When I rode it, it didnt seem to do it as you described. Just make sure you shift harder. Next time we meet up take my bike out and see if you can reproduce it on my bike
Old May 16th, 2011, 08:52 PM   #12
ungluck
sleeper
ungluck's Avatar
Motorcycle(s): '10 250r, '10 690 duke
same thing with 3-4 for me..but it's me going waayy to fast with my foot and not following through in my shift...been happening since day one..my last bike was so notchy when shifting you knew if it was a false shift.
Last futzed with by ungluck; May 17th, 2011 at 04:34 AM.
ungluck is offline   Reply With Quote
Old May 16th, 2011, 09:02 PM   #13
Kevin2109
KThanksBye
Kevin2109's Avatar
http://www.ninjette.org/forums/showthread.php?t=15944
Old May 16th, 2011, 09:26 PM   #14
Vampyre
Vampyre's Avatar
Motorcycle(s): 2011 250R Black, 2005 ZX-6R Blue
I have had this happen a couple of times. I am pretty sure that I am just not completing the ankle move completely. It usually happens when I am lazily going into 6th just puttering along, and I don't use as much force. Just rolled over 100 mi today on my bike.
Or maybe it is just the black ones. They gave us an extra neutral....lol
Vampyre is offline   Reply With Quote
Old May 17th, 2011, 04:33 AM   #15
ungluck
sleeper
ungluck's Avatar
usually it's my 3-4 shift..but i beat on my bike...i've always been hard on bikes.
the down to first thing i understand..it's normal..but i only go down first if i truly have to..but i get a pretty regular(2/3 times a week) but not too often where it'll go in for a hot second then pop out of 4th...it's scary man..to suddenly not be accelerating with all the dumbasses here... i prepare for impact while quickly getting things straightened out lol
Neutral count as a gear? agentbad 1986 - 2007 Ninja 250R Tech Talk 16 March 14th, 2014 12:47 AM
1st Gear or Neutral when at a red light? ajcadoo General Motorcycling Discussion 27 April 21st, 2012 09:32 PM
Neutral Light islander 2008 - 2012 Ninja 250R Tech Talk 8 March 22nd, 2012 08:16 PM
slipping from second into neutral...? clintalmighty 2008 - 2012 Ninja 250R Tech Talk 8 March 21st, 2011 08:43 AM
False neutral SteveL 2008 - 2012 Ninja 250R Tech Talk 6 March 26th, 2009 09:14 AM
