Old June 9th, 2012, 10:29 PM   #1
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
Can thinner oil cause engine ticking??
I have noticed a new tick tick tick noise recently which is only there when the engine is cold. I recently switched to synthetic 5W40 oil and another rider told me the thinner oil could be a cause for this.
He said the oil probably isn't sticking to the internal parts as well when its cold due to thiness and it sounds like the noise is a dry cam chain...
Any ideas? At first I though CCT but its fine when warm and at operating temperatures...I think I will switch back to 10W40 and see how that goes.
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound
LoneRonin is offline   Reply With Quote
Old June 10th, 2012, 01:11 AM   #2
use the correct oil.
unless you want this:
Old June 10th, 2012, 09:50 AM   #3
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
Why did you switch to 5W30?
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Old June 10th, 2012, 12:26 PM   #4
flynjay
flynjay's Avatar
While 5W40 is thinner than 10W40 at cold temperatures (hence the 5W vs 10W), it is never thinner than the specified SAE40 is at hot temperatures.
Our engines tick, it's normal.
Old June 10th, 2012, 01:31 PM   #5
LoneRonin
LoneRonin's Avatar
rotella T6 synthetic was on sale and I had credit with the store I got it from, also I've heard its a good oil in bikes...previously I was running 10W40 Motul 5100 and will switch back to that...
I understand the cold part thats why I emphasized the ticking is only occuring when cold...
Also its not the normal consistent ticking we get, I've been hearing that noise for over 10k miles...its a different noise and the fact that its really hot here leads me to believe the oil which is supposedly rated for colder temps.
I'm in Toronto so its cold enough, but in the summer we get crazy hot days too. I ride the bike in the winter months too and was worried since my ride to school was only about 7-12 minutes the 10W40 probably wasn't warming up quick enough...
Old June 10th, 2012, 03:44 PM   #6
flynjay
flynjay's Avatar
I don't believe the oil has that much to do with the ticking. Temperature of the motor, maybe, but not the oil. Rotella T6 can handle the high temperatures just fine.
When was your last valve adjustment?
Old June 10th, 2012, 04:40 PM   #7
common maybe. correct? no.
I'm curious why you think it has nothing to do with the oil?
he changed his oil to a thinner cold weight oil. afterward, the bike ticks when cold. seems pretty obvious to me. like a previous posted said, why did you switch to 5 weight cold? just put the correct oil in it and be done with it. the engine was designed to work with a specific weight oil. putting the wrong oil in will cause damage. it could be that his bearings arent lubricated enough. it could be the cylinder wall is not staying lubricated. basically what it means is yoour engine isnt being properly lubricated because the thinner oil flows out more easily and doesnt stay up top in the head
Old June 11th, 2012, 11:25 PM   #8
headshrink
headshrink's Avatar
I get a bit of slide-slap in the carbs. It drove me crazy trying to figure out what was causing that sound.... try grabbing a stethoscope (or screwdriver) and see if you can isolate the location.
2009 ninja 250r engine ticking & knocking noise ubxssangz 2008 - 2012 Ninja 250R Tech Talk 47 January 26th, 2017 12:15 PM
Engine Oil Mrudloff 1986 - 2007 Ninja 250R Tech Talk 24 March 23rd, 2015 08:59 AM
Engine ticking sound Nosajong 2008 - 2012 Ninja 250R Tech Talk 4 May 21st, 2013 07:57 PM
Where Did My Engine Oil Go? Francis 2008 - 2012 Ninja 250R Tech Talk 12 May 1st, 2011 10:15 PM
Engine ticking at idle? JMcDonald 2008 - 2012 Ninja 250R Tech Talk 14 December 17th, 2010 10:11 AM
