Old May 28th, 2010, 03:10 PM   #1
Guinss
Guinss's Avatar
Motorcycle(s): 2008 250R (Black)
Low oil pressure during braking
If i brake hard(practising emergency stops for example) the oil pressure light will come on for several seconds when i come to a stop. Doesn't matter if i use only front brake or both front/rear.
It seems to me, all the engine oil is gathered up at the front of the engine, not in reach of the oilpump. The oil level is fine, theres been done 4 oil changes so far, and i have been having this issue all the way since the bike was new.
Anyone solved this or have ways of avoiding this happening?
Guinss is offline   Reply With Quote
Old May 28th, 2010, 03:22 PM   #2
ScorpionNinja
ScorpionNinja's Avatar
What kinda OIL FILTER do you use?
It might be restricting the oil flow enuff to cause your oil light to come on!
I use the WIX one. NPs at all.
Old May 28th, 2010, 03:42 PM   #3
Guinss
Guinss's Avatar
I use the filter with "kawasaki genuine parts" on the box, green/black paper box.
Only useful info on the box is: "Y28 P/No. 16099 - 003". On the filter itself it says "9V11".
I can go to 60mph, pull clutch in, brake as hard as i can without tires slipping and the light will come on.
If i leave the clutch out, it doesn't happen as often, but the engine will bog down ofcourse, if i dont pull clutch in at full stop.
Old May 28th, 2010, 03:45 PM   #4
what is your idle speed set to? if it's below 1500rpm, try raising it and see if that helps.
Old May 28th, 2010, 03:48 PM   #5
I've had it happen on our bike. If the oil level is a smidge low, it's more likely to show up. In my case it was still very much showing in the sight glass, but a little below the halfway point; putting it a little above the halfway point means the low oil light is unlikely to pop on anymore.
Old May 28th, 2010, 03:51 PM   #6
Guinss
Guinss's Avatar
I have set it on purpose to 1100-1300 or something, low as possible, and that could be the reason indeed. I think we got a winner, i'll check it out.
My oil level is at the top line, checked many times. Now i have to check again
Old May 28th, 2010, 03:53 PM   #7
http://faq.ninja250.org/wiki/My_oil_..._heavy_braking
Old May 28th, 2010, 03:58 PM   #8
Guinss
Guinss's Avatar
Interesting. My oil light can stay on for 3-4 seconds, it feels like forever. I rev it instantly to get pressure back up. I guess its no harm done as long as i don't practice emergency stops for many continuous hours.
I'm guessing the low idle rpm is causing my light to stay on that long, and not 1-2 seconds.
Old May 28th, 2010, 04:01 PM   #9
increase it and let us know if that makes a diff.
Old May 28th, 2010, 05:08 PM   #10
HKr1
IC2(SW)
HKr1's Avatar
Have you cleaned/checked the oil screen? If not, check it next oil change. The oil pump gets its feed from/thru that.
Old May 28th, 2010, 09:50 PM   #11
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
downshift while braking! Keeps the revs up, and you can brake as hard as you want without the light coming on. You can bottom out the front suspension and start chattering the rear tire while braking and the light wont come on.
Rexbo is offline   Reply With Quote
Old May 29th, 2010, 08:47 AM   #12
randomwalk101
self wrencher
randomwalk101's Avatar
That should not happen. If oil level is adequate, check connection of oil sensor...then test or replace oil sensor if bad.
Posted via Mobile Device
oil pressure light contact148 2008 - 2012 Ninja 250R Tech Talk 28 June 21st, 2018 06:54 AM
Low tire pressure on new bike? IF13 General Motorcycling Discussion 7 October 10th, 2013 07:50 PM
Oil Pressure Light on Startup quicklooker 1986 - 2007 Ninja 250R Tech Talk 28 July 19th, 2013 07:16 AM
Oil level -- how low is too low? adouglas 2008 - 2012 Ninja 250R Tech Talk 8 October 18th, 2011 06:51 PM
Oil pressure switch randomwalk101 2008 - 2012 Ninja 250R Tech Talk 13 February 23rd, 2011 06:58 PM
