Old May 17th, 2012, 07:28 AM   #1
aweesner
Motorcycle(s): 2004 Ninja 250
Loose Hardware...
Is it relatively common for some hardware to loosen up? I found one of the the screws that secure my handlebars to the fork coming out as well as loose rear footpeg bolt.
aweesner is offline   Reply With Quote
Old May 17th, 2012, 07:30 AM   #2
Not common.
Those bolts were not torqued properly.
Old May 18th, 2012, 06:07 AM   #3
On an eight year old bike? Sure, it's certainly not uncommon. Checking key nuts and bolts periodically is a part of motorcycle ownership, especially as they get on in years.
Old May 18th, 2012, 06:41 AM   #4
dubojr1
dubojr1's Avatar
Seems to be few of these type of threads lately. I think it's time I start checking the torque on some of these important bolts. Maybe some blue locktite too. Didn't I see a compressed version of torque values for this on here somewhere. An excel spreadsheet maybe?
Old May 18th, 2012, 07:05 AM   #5
I'm not sure, but that would be a good find. They are all in the service manual, for folks who have tracked down a copy (no - that doesn't mean post links here ).
Old May 18th, 2012, 07:09 AM   #6
dubojr1
dubojr1's Avatar
Would it be ok Alex to put a copy of the 4 pages from the SM that includes those specs? I'm working on a copy for myself that will have the hardware we use most often or that is easily checked during routine maintenance high-lighted.
Old May 18th, 2012, 08:22 AM   #7
Skippii
Milkshake Drinker
Skippii's Avatar
Every freaking screw/bolt/nut/etc comes loose on my bike. I've had the battery connections fall off mid turn at full lean, I've had the coolant pipe (not the radiator hose, the one that goes on the side of the engine) come loose and dump all the coolant, I've had the mirrors fall off, all the fairing screws vibrate loose, and several other things in the last few months.
You shouldn't worry about things coming loose, you should expect it. Torque everything correctly and apply a removable threadlocker.
I replaced my front brake rotor recently, and even those bolts, with the crazy orange "we don't want you ever to remove this" loctite came off with just a normal ratchet.
The one exception is the bar-end weights. Those things will never, ever vibrate loose. Kawasaki considers it to be of critical importance that these never come loose. They are not removable without at least a blowtorch. Judging by Kawasaki's use of threadlocker, it's okay if the handlebar falls off, apparently, as long as the bar end stays with it.
"What a sweetheart."- ninja_sleeper to me
Old May 18th, 2012, 09:09 AM   #8
@dubojr1 - Yes, I think I'd be OK with that. Like you - I think there's a thread here somewhere with that info already, but hasn't come up for me in a few obvious searches.
Old May 18th, 2012, 10:14 AM   #9
greg737
Motorcycle(s): -
Blue Loctite is the EX-250 rider's friend.
(Loctite Threadlocker Blue 242, for the locking and sealing of threaded fasteners which require normal disassembly with standard hand tools)
Old May 18th, 2012, 10:29 AM   #10
Wow, Skippii, you have a real shaker there
Maybe the engine is not solidly bolted to the frame.
Those would be the first ones too get loose, I guess.
My personal experience with my Ninja has been completely opposite,....and without using any thread locker.
Old May 18th, 2012, 10:33 AM   #11
dubojr1
dubojr1's Avatar
I'll post something that we can continue to improve on. It will vary some for those that don't have certain parts like an air box or different kinds of exhaust. Maybe we can color code it too to indicate importance.
Old May 18th, 2012, 10:41 AM   #12
Also - keep in mind that right now we're posting in the pre-gen area, and I assume you want this for the new-gen area.
Old May 18th, 2012, 10:45 AM   #13
lol. you sound like me.
Old May 18th, 2012, 11:11 AM   #14
dubojr1
dubojr1's Avatar
True. It would be helpful for both gen's. It shouldn't vary too much should it?
Old May 18th, 2012, 11:24 AM   #15
You're probably right.
Hardware Size Spreadsheet? TBC 1986 - 2007 Ninja 250R Tech Talk 3 August 16th, 2014 05:54 PM
Seat Cowl Hardware AZninja 2008 - 2012 Ninja 250R Farkles 3 February 8th, 2013 07:20 PM
Misc Hardware atomicrm Items Wanted 1 July 18th, 2012 06:12 PM
JIS screwdrivers - Why do we damage some of the hardware? Motofool General Motorcycling Discussion 6 July 14th, 2012 11:53 AM
Where do I get all the fairing bolts/screws/hardware? Purspeed 1986 - 2007 Ninja 250R Tech Talk 10 May 17th, 2009 03:26 PM
