Old January 31st, 2014, 12:11 PM   #1
mikedabike64
Motorcycle(s): 2008 ninja 250
budget rear shock upgrade ?
Hi I was wondering about any upgrades to the rear excluding the 1100.00 race tech shock,
I am getting my 250 ready for the track here in NJ.
I will be doing front springs and emulators.
Thanks Mike H.
mikedabike64 is offline   Reply With Quote
Old January 31st, 2014, 12:17 PM   #2
oblivion007
"scandal!"
Motorcycle(s): 2011 250R(Crashed 2/26/2014), 09 ER6n
I've read good about a GSXR 750 shock swap. Not sure where the link is.
oblivion007 is offline   Reply With Quote
Old January 31st, 2014, 12:29 PM   #3
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
http://www.ninjette.org/forums/showthread.php?t=106929
http://www.ninjette.org/forums/showthread.php?t=59486
these threads should help
TEAM ALFALFA
www.apexassassins.com
Old January 31st, 2014, 12:32 PM   #4
mikedabike64
ok thanks
Thanks for pointing me in the right direction
Old January 31st, 2014, 12:37 PM   #5
i've used gsxr shocks and r1 shocks. you can get them for cheap on ebay
Old January 31st, 2014, 12:44 PM   #6
mikedabike64
r1 shocks too?
Ok wow I didn't think I had 2 options nice !
Old January 31st, 2014, 12:49 PM   #7
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I got the GSXR 600 shock with rexbo dog bones.
TEAM ALFALFA
Old January 31st, 2014, 01:07 PM   #8
mikedabike64
ok
I will check out the dog bones as well thanks
Old January 31st, 2014, 01:26 PM   #9
Bigballsofpaint
Rexbo doesnt seem to be doing the dogbones anymore, after i put my gsxr shock on im going to see if i need to make a pair of my own.
Old January 31st, 2014, 02:03 PM   #10
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Does the R1 shock lower the ride height as well?
Old January 31st, 2014, 02:10 PM   #11
Bigballsofpaint
depends on year, springrate, mounting bolt distances etc. One of those threads has a table on all that info
Old January 31st, 2014, 09:23 PM   #12
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
shouldn't be too hard to replicate them if you know someone with the right tools.
TEAM ALFALFA
Old January 31st, 2014, 09:33 PM   #13
mgentz
Board Member
When using a gsxr or r1 shock, the length, spring and valving are all setup for a heavier more powerful bike. Thus it will never act as it should.
You can pick up 250r specific shock for less than $1000.....
Old January 31st, 2014, 09:52 PM   #14
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
or you could pick up the GSXR/R1 shock for $50-$100 and get another spring for you liking for maybe another $100. I got the GSXR 600 shock and it made great improvements, once i got different dog bones, it was even better. i doubt there is any rider on this forum that is the level of rider where that would make a difference for a 250R special shock vs. gsxr shock.
TEAM ALFALFA
Old February 1st, 2014, 07:29 AM   #15
Bigballsofpaint
i program CNC machines all day and all we run is 6061 aluminum. Im sure i could pop in on a saterday and run some off. I have a project for another member im trying to do first though, i just need to get off my butt and go to my friends to measure his pregen
Old February 1st, 2014, 08:25 AM   #16
mgentz
Board Member
You're right. What do I know. Proceed.
Old February 1st, 2014, 09:10 AM   #17
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Maybe you miss read him when he wanted a "budget" shock, you may have just under $1000 to throw around, but maybe he doesnt. i mean what would i know about budgeting anyways...
TEAM ALFALFA
Old February 1st, 2014, 12:36 PM   #18
mgentz
Board Member
Sportsimoto had 3 shocks for under $500. Others are out there as well. One for like $200.
Buying a $60 shock, a new spring, new dog bones, making mods to make it fit AND still have ^^#& valving is not my idea of "budget." Maybe you cannot tell the difference between proper suspension and not but I can.
To each their own....my opinion is over.
Old February 1st, 2014, 02:53 PM   #19
Bigballsofpaint
A GSXR swap obviously is not the best solution, but so far ive spent 30 bucks, and i doubt ill spend 20 more. So for 50 bucks or less, it is better than stock. Not near the same level as a penske or racetech, but it does the job.
Old February 1st, 2014, 03:16 PM   #20
The geometry of the suspension linkages is much more important in determining the valving of a shock than the weight of the bike. So while you are right that the valving won't be perfect for this bike (different linkage geometry than the 250, therefore different damping characteristics are required from the shock), your reasoning is wrong. It has nothing to do with weight of the bike.
You can pick up a used GSXR shock from ebay for $30-40. Then get it revalved/resprung/serviced for somewhere around $200 (this is a total guess) or do it yourself if you have an idea of what you're doing.
http://www.ninjette.org/forums/showthread.php?t=126734
Not everyone has money for a Penske or Ohlins and let's face it, the quality/serviceability of a no-name shock from overseas is going to be a bit suspect when you can pick up a used shock from another bike for 1/4 the price that has tons of readily available replacement parts and a bank of documented knowledge available.
Old February 1st, 2014, 03:48 PM   #21
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I notice a huge difference between the stock shock vs. gsxr shock. the whole set up cost me less then $125 for bolts, spacers, shock and dog bones. but you are the expert here...
i am also curious what you mean by "weight" of the bike gsxr weight is 161kg 250R is 150kg so a difference of 11kg. now we need to consider "unsprung weight" ie wheels/tires. not sure exact weights there, but when changing tires on the 250R vs ZX6R there is a noticeable weight difference. now lets take into consideration that motorcycles are sprung to the weight of a 150 pound rider, I weigh 180 pounds or 13 kg more then the spring rate, now the combined rider weights are 2 kg different.
TEAM ALFALFA
Old February 1st, 2014, 07:35 PM   #22
mgentz
Board Member
I kept it to weight of the bike to be simple. I could mention horsepower, swingman length and angle, linkage type and ratio, unsprung and sprung weight, rider weight, riding style, surface characteristics, bike geometry, frame and component rigidity....the list goes on.
To the OP, yes there are options out there. Heck, try the gsxr shock...you may like it. In all honesty, our stock shock is not THAT bad depending on your weight.
Old February 1st, 2014, 08:21 PM   #23
old3
It might not be the best option but I have a second one on the shelf that I was planning to revalve when I sorted and tested the one I have on my 300.
Tell ya what, I cant think of anything I'd change after working over the adjustments.
It is damn good out of the gate if you take the time to test and tune it.
old3 is offline   Reply With Quote
Old February 2nd, 2014, 12:11 AM   #24
simook
I'm in the same boat as op. except the gsxr/r1 mod is against my race organization's rules so I'm planning to run just my stock rear shock for now. Unless anyone knows a good $200-500 shock for a dedicated race bike.
- OMRRA Racer #83 -
-- OMRRA Media Group Editor/Producer --
simook is offline   Reply With Quote
Old February 2nd, 2014, 02:02 AM   #25
mania
mania's Avatar
Motorcycle(s): 2013 250
I have no first hand info but I did read about a group buy on their older 2 way shock that never happened
here on this site with this RPM brand.
I am still looking for info but anyway they have this new RPM GII 3 way adjustable shock
sells for $300 in Indonesia
I do see Sportisi lists it as $465 special order too
I have not found other avenues to buy yet & have sent a email to the Taiwan manufacturer
Anyway looks interesting & if I find more info I will post
File Type: jpg 217193_509822842365215_1259469249_n.jpg (105.9 KB, 3 views)
File Type: jpg 1003060_684348091579355_667602937_n.jpg (77.8 KB, 4 views)
mania is offline   Reply With Quote
Old February 2nd, 2014, 10:27 AM   #26
simook
Thanks for the Sportsi link, that's exactly what I'm looking for. But why would I want a 3 way adjustable shock over the 2 way?
I mean, I understand the 3 way provides more control for fine tuning, but does it really make that much different over the 2 way on a dedicated race bike? Keep in mind I'm on a budget and a novice.
- OMRRA Racer #83 -
Old February 2nd, 2014, 01:45 PM   #27
old3
Depends on how close the valving and spring rate are to your ideal settings. The wrong valving with 3 adjustments isn't as good as the right valving with none.
I'd choose the 3 if you can. Why not? And yes, when you get to know what the differences are you will appreciate the extra adjustments. Each affects the others to a degree.
Old February 2nd, 2014, 02:15 PM   #28
simook
Sound wisdom but I already pulled the trigger on the G-Plus 2 way. Ideally I'll upgrade to something better later on in the season.
- OMRRA Racer #83 -
Old February 2nd, 2014, 07:25 PM   #29
old3
I don't know these shocks but I'm sure it is rebuild-able and the valving can be changed so it is still a great upgrade.
Old February 3rd, 2014, 11:33 PM   #30
mania
mania's Avatar
There is another shock here too made by YSS
model# MX366-320TRCL-13
a bit more pricey than the RPM as even here it runs $450
GSXR rear shock upgrade psych0hans Ninjettes At Speed 17 June 17th, 2014 11:47 PM
300 rear shock upgrade and front suspension agentbad 1986 - 2007 Ninja 250R Tech Talk 1 January 22nd, 2014 12:07 PM
GSXR shock upgrade, complete kit for 250r/300 Dark Motorcycle-related 16 August 21st, 2013 03:15 AM
Anyone tried a '09-'11 ZX6R rear shock upgrade? Nemesis 2008 - 2012 Ninja 250R Tech Talk 2 April 21st, 2011 11:22 AM
'J Shock' Upgrade komohana 1986 - 2007 Ninja 250R Tech Talk 20 August 15th, 2009 09:01 AM
