Old August 13th, 2020, 04:33 AM   #1
Kev
Motorcycle(s): 2012 EX250
Hello from Penang, Malaysia
Hi,
Just recently picked up and started riding a 2012 ex250 fi with 3500kms on the clock. Having great fun as I haven't really ridden a bike for 25yrs.
Had to replace the brand new looking tyres as they were the originals with a date stamp of June 2012
Obviously changed the oil and filter straight away and the air filter which had literally turned to oily dust (2hrs to clean the air box). Also completely changed the front and rear brake fluid.
I'm guessing the bike has probably had 1 service in its first year of existence, and never been serviced since.
Fork seals are leaking, so new ones are on order and I'll get the fork oil completely changed when they are fitted. Anything else I should be considering doing to this low milage but unserviced bike before I put too many miles on it?
Thanks!
Kev is offline   Reply With Quote
Old August 13th, 2020, 04:51 AM   #2
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Kev! Glad you found us...
Old August 13th, 2020, 05:25 AM   #3
Hello Kevin, welcome to the board!
You sound like you're good at doing mechanical stuff, so I'm sure you'll take a good look at everything. What is the condition of the chain and sprockets, for example?
Old August 13th, 2020, 11:39 AM   #4
Ceeloo Yello
Motorcycle(s): 250
Welcome
Old August 13th, 2020, 11:48 AM   #5
Hi Kev and welcome to Ninjette!
Old August 13th, 2020, 07:33 PM   #6
Kev
Thanks for the welcomes...
To answer Jim's question, chain was dry. Very dry. I've lubed it and it seems to look OK and the sockets look OK too, thankfully.
Old August 14th, 2020, 04:13 AM   #7
Welcome!
Old August 14th, 2020, 09:58 AM   #8
It's amazing how many riders think that having a sealed chain means you don't need to lubricate it regularly. When I got my 2005 Ninja a few years ago the chain was rusty and the seller said he didn't understand why. I told him it was because no one had lubed it. He looked confused.
He was a nice guy though, and he included a new chain and sprocket set with the bike.
Old August 14th, 2020, 05:50 PM   #9
Originally Posted by Triple Jim View Post
He looked confused.
What you don't know you don't know!!!
Doesn't O-rings just seal between plates, therefore between pin and inner bushing? But what about between rollers and bushings???
Old August 18th, 2020, 06:08 PM   #10
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome
Old August 20th, 2020, 10:20 AM   #11
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Old August 27th, 2020, 01:27 PM   #12
rstnick
rstnick's Avatar
Motorcycle(s): 2011 250R, 2000 ZRX1100C4, 1978 KZ650C2
Welcome Kev
rstnick is offline   Reply With Quote
Old November 16th, 2020, 06:55 PM   #13
Snake
Snake's Avatar
I’m a little late but ....hello and welcome !
Old November 17th, 2020, 11:49 AM   #14
SibSerge
I would also replace the antifreeze, and while you are in it replace all the orings except the one in the head as you need to take the cover off. St 8 years you are might be ok for a bit wbut soon it might start leaking. I do not trust orings that are that old. They are cheap and easily accessible save for that one in the head
Not sure about 2012 my 2007 has the PCV hose connecting the case with the air box. That gets hard overtime and might lead to air leaks. Its easy to access and I would replace that too
Greetings from Malaysia turtle956 New Members 7 November 13th, 2019 12:38 PM
[topix.net] - Penang BN aims for no motorcyle toll at Penang Bridge if it wins electi Ninjette Newsbot Motorcycling News 0 June 25th, 2012 01:50 AM
Hello from malaysia kevinkit New Members 23 August 25th, 2011 12:01 AM
Hello from Malaysia crocked_knee New Members 11 August 16th, 2011 07:50 PM
hello from malaysia. din10 New Members 10 August 16th, 2011 07:49 PM
