Old November 29th, 2012, 07:21 AM   #1
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
Brake fluid on paint...
How damaging is it really? I heard it'll eat way your paint, but say if you spill a few drops will it start stripping the paint right away or does it need to sit a while? Can it also penetrate the clear coat? I plan on changing the fluid over winter but having never done it myself I'd rather not risk ****ing up my paint...
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound
LoneRonin is offline   Reply With Quote
Old November 29th, 2012, 07:29 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Put rags around the painted parts or just remove them. Keep a spray bottle with soap water on hand. If you drip on a painted surface just wipe it up. Waxing the bike before is also a good idea.
It is very important to change brake fluid. It absorbs water from the air. The moisture will eat brake parts. But the moisture will boil at 212 deg and brakes hit 1000 deg in normal use. This will affect the breaking.
If the brake fluid sits on paint it will mostly leave a shadow water type mark. It takes a while to eat the paint.
Worlds fastest 250 ninja
Old November 29th, 2012, 07:32 AM   #3
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
It needs a little time so you can easily wipe it up but the problem is that it's thin so it tends to travel and get into hard to reach places that you may miss some when cleaning up only to find pain peeling later. A few drops on the paint are no big deal as long as you have a clean rag handy with a little bodywork cleaner. If you leave it on paint for a day or so it will look like there was never any paint in that spot to begin with.
Old November 29th, 2012, 02:08 PM   #4
Whiskey
Rinse it off as soon as it gets on the paint & it shouldn't do any noticeable damage, rubbing it will make it worse.
Old November 29th, 2012, 03:06 PM   #5
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Don't wipe the fluid off if you get some on there. Spray it down with water and dab at the area. Wiping it will just spread it.
The www.ModMy250.com guy
Old November 29th, 2012, 03:43 PM   #6
Jono
Jono's Avatar
If it touches the paint you have exactly 10 seconds to get it off. Get the garden hose and start spraying away!!! And if you get any on your hand, well... you are already out of time. Your hand is going to start dissolving.
You are over-thinking everything. Just get a towel and toss it over the tank/fairing. Problem solved. It's not a messy job if you know what your doing.
Old December 1st, 2012, 02:19 AM   #7
Monkeytofu
I told you bro
Monkeytofu's Avatar
Polyurethane clear coat.
Old December 1st, 2012, 03:58 AM   #8
Apex
Livin' the Minimoto Life
Apex's Avatar
Oh no....now you need to repaint the whole bike. Your life is ruined.
Brake fluid Islandmax 1986 - 2007 Ninja 250R Tech Talk 11 June 22nd, 2013 04:28 PM
2010 Ninja 250r Brake fluid bleed/Replacement and brake caliper cleaning RandomPhantom 2008 - 2012 Ninja 250R Tech Talk 1 May 30th, 2013 08:13 PM
Replacing brake pads and brake fluid Bones85 2008 - 2012 Ninja 250R Tech Talk 4 April 28th, 2013 06:25 PM
How much brake fluid ? GiGs 2008 - 2012 Ninja 250R Tech Talk 5 December 31st, 2010 06:06 PM
Brake Fluid? ASecretNinja 1986 - 2007 Ninja 250R Tech Talk 4 January 20th, 2010 03:02 PM
