Old August 4th, 2014, 08:46 AM   #1
vmax
Motorcycle(s): ninja 250
Pod or replacement filter
Hi all,
Appreciated all info which better if I change pod filter or replacement filter if I using stock exhaust. For now I am running stock exhaust with remove snorkel a love that sound. I intend to using pod filter because of sound woarghhh.....but don't know it reduce power or not.
vmax is offline   Reply With Quote
Old August 4th, 2014, 08:53 AM   #2
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
you'd be better off with a good quality replacement filter, not much gain from pods, other than a slight HP increase and noise. If you are a daily driver and ride in the rain, then stay away from the pods. You can get some pretty decent numbers with the stock air box and a good exhaust system.
also, search function is your friend. theres a alot of info here on the subjects.
Old August 4th, 2014, 09:05 AM   #3
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
^ this, just stick with the airbox unless you plan on doing other odd ball mods or plan on messing with your jetting a lot.
Not having the box really makes changing the jets a snap and it also gives you more room for gsxr shock swap or similar but other than that I don't see any other point to removing the stock air box kinda wish I kept mine in but now that it is out I won't put it back in for various reasons.
But most people don't seem to touch their jetting more than once and the shock swap is not for everyone so just keep it IMO
Old August 4th, 2014, 12:20 PM   #4
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
As mentioned there are other benefits to removing it. The extra room is really nice, everything is easier to do without it in the way.
If you plan on keeping the bike pretty simple you should probably leave it in.
Old August 4th, 2014, 09:30 PM   #5
vmax
thanks for all info guys. I think I will use replacement filter
K&N Pod filter mwirrick Ninjettes At Speed 13 January 10th, 2014 05:57 PM
K&N Pod Filter Peanut_EOD 2013 - 2017 Ninja 300 Tech Talk 23 November 15th, 2012 08:35 PM
POD filter question lstat 2008 - 2012 Ninja 250R Tech Talk 13 August 28th, 2012 07:42 AM
K&N Filter or Pod jonthechron 2008 - 2012 Ninja 250R Tech Talk 6 February 17th, 2010 12:07 PM
Which pod filter do you use? null0 1986 - 2007 Ninja 250R Tech Talk 13 December 1st, 2009 12:36 PM
