July 27th, 2011, 08:04 PM | #1 |
Join Date: Aug 2010 Motorcycle(s): Bike-less, Can I ride yours? Posts: 318
Carb Broken
Long story short the carb got cracked, and now the rubber diaphragm is not sitting properly due to the circle in which it sits in is missing an edge. Now when the engine is revved it sounds like there is an air leak ( a puff puff puff sound) which wasn't there before. I have the option for picking up a carb for $180 shipped, should I just buy it and put that one in?
July 28th, 2011, 07:00 AM | #2 |
Long Time Rider
July 28th, 2011, 08:48 PM | #3 |
The Sportisi Master
Ive got one you can have for less.
Sportisimoto USA is born. |
August 28th, 2011, 06:12 PM | #4 |
So I bought the Carb from Ztrack. But heres a link to the sound I am talking about. I know its related to the carb, more specifically the right carb diaphragm not sitting right. Would this being ridden on hurt the engine?
August 30th, 2011, 11:22 PM | #5 |
I would say potentially yes, you could harm the engine riding it like this. 3 reasons:
1) Your engine is now running a lot more lean than it's designed to, and they're already almost too lean from the factory. 2) Add to that the fact that you're sucking in unfiltered air, so dirt and road crud is going straight to your combustion chamber... 3) Your pistons are now getting significantly different combustion ratios, so one of them is doing most of the work Personally, I'd avoid riding it like that. You may be able to get away with it provided rides are very short, but is feeding the addiction worth possibly overheating and fubar'ing the engine? Up to you.
August 31st, 2011, 12:35 AM | #6 |
CVMA #74 WSMC #750
I replaced a diaphragm once and those things are expensive!
Agreed, get that thing fixed before you ride it. |
August 31st, 2011, 08:12 AM | #7 |
we put the cap back on and sealed it, so hopefully its not sucking anything in. I believe its defiantly running lean. I don't think the engine is running that hot, the ambient temperature in Washington is pretty cold, so hopefully its not over heating.
Hopefully the carb will be today or tomorrow so I can change it out. |
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped | menikmati | Motorcycle-related | 4 | April 8th, 2020 12:39 AM |
Valve adjustment, carb clean, carb sync? | amad1972 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 29th, 2014 09:42 PM |
Possible Broken Piece | Brocked | 2008 - 2012 Ninja 250R Tech Talk | 13 | September 26th, 2013 05:44 PM |
Is this cowl broken? | Brian250R | 2008 - 2012 Ninja 250R Farkles | 28 | July 30th, 2010 04:09 AM |
