May 21st, 2014, 09:45 PM | #1 |
WOT WOT WOT
Join Date: Jul 2013 Motorcycle(s): '12 Ninja 250R Posts: 421
Radiator hose into metal tube, why?
Can anyone explain to me why this is the chosen design? Is it because they needed the threaded portion of the tube?
I was in a crash and it's slightly dented. I'm opting to cut up to the bend and replacing the silicone hose with one that's longer. Is there any downside to this?
May your roads stay clear.... |
May 21st, 2014, 11:21 PM | #2 |
it will be hard to get a seal on it without a lip to clamp onto. but if you put rtv on it will probably work. maybe. the reason is you don't want a floppy rubber hose down there where if something nicks it, it could cut it open. metal doesn't care if its getting hit by branches or crashed on as you can tell. it might have sprung a leak but it didn't rip it out did it.
May 22nd, 2014, 09:19 AM | #3 |
It provides some rigidity (metal) so it does not collapse and just enough flex (rubber) for expansion/torsion. On the Australian model the metal coolant pipe connects to a coolant valve and damper. The coolant valve connects to the carbs to keep them from icing.
May 24th, 2014, 02:38 AM | #4 | ||
WOT WOT WOT
May 25th, 2014, 07:07 PM | #5 |
May 29th, 2014, 04:52 AM | #6 | |
Board Member
Based on how everything connects to the 250 motor, one could not just use hose. |
Anyone try these radiator hose kits? | garth285 | 2008 - 2012 Ninja 250R Tech Talk | 4 | November 6th, 2014 08:48 AM |
Koso radiator hose adapter | JanqeD | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 18th, 2014 12:51 PM |
radiator hose size? | mikedabike64 | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 12th, 2014 11:14 PM |
Radiator coolant dumped from overflow tube | Aman13 | 2008 - 2012 Ninja 250R Tech Talk | 9 | April 20th, 2013 10:57 AM |
radiator hose burst :( leaking coolant | h0yitsdom | 1986 - 2007 Ninja 250R Tech Talk | 11 | June 3rd, 2011 11:06 PM |
