April 18th, 2014, 04:42 PM | #1 |
dirty boy
MOTM - Apr '14
new springs, emulators, springs sound noisy?
I did springs and emulators today, everything went text book.
After i got the forks back on other things back on, clip-ons, front wheel ect... I bounced the front end as much as i could with out front brakes as i have not put that back together yet. The compressing rebound feels good but i can really hear the springs in there against the fork tubes? IDK, maybe it is just me, because i am listening so closely
April 18th, 2014, 04:45 PM | #2 |
... did you put oil in?
usually if you hear the fork scraping inside it means your stanchions are bent.
April 18th, 2014, 04:55 PM | #3 |
dirty boy
MOTM - Apr '14
definitely put in oil. nothing bent.
I will take the caps off tomorrow and take a look. Perhaps the top of the springs isn't well lubricated which would make sense from the way i did things. Perhaps my cut spacers are not 100% square and they are pushing springs to one side?
April 18th, 2014, 05:08 PM | #4 |
i would think it is an issue with the spring not being centered over the bottom valving assembly stuff... it would need to be off center at both ends to bind much and be making any noise
April 18th, 2014, 06:35 PM | #5 |
dirty boy
MOTM - Apr '14
yeah, i will double check tomorrow to make sure the springs are seated correctly down at the bottom.
April 19th, 2014, 04:14 AM | #7 |
dirty boy
MOTM - Apr '14
^ actually 2, tried a small one didn't work..... moved to the 10lb sledge and all is well
edit: caps off, everything out and back together, things look good. must be me.
I love the smell of burning pre-mix in the morning I don't think I'm a lot dumber than you thought that I think that I thought I was once. Last futzed with by subxero; April 19th, 2014 at 09:16 AM. |
Emulators worth the money or are springs good enough? | LoneRonin | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 10th, 2014 07:34 AM |
Hello From Colorado Springs | curiousrat | New Members | 10 | July 24th, 2014 08:24 PM |
clutch springs | John D | 2008 - 2012 Ninja 250R Tech Talk | 28 | May 24th, 2013 12:58 PM |
My New Front Springs ... | Jim Moore | 1986 - 2007 Ninja 250R Tech Talk | 7 | August 31st, 2012 08:00 PM |
WTB: PREGEN cartridge emulators/springs | espacef1fan | Items Wanted | 0 | July 12th, 2012 10:11 PM |
