June 26th, 2010, 07:28 PM | #1 |
2009 SE Build
All-in-all, I am super happy with how the bike turned out. Thanks to all the folks here (kkim, Alex, ninja250, Vex, and countless others) who helped me from their many DIY posts to answering my forum questions and messages, specially to Matt of Sportisi, Tony of Cycle Control, and Kerry of Area P who are top notch when it comes to customer service. They are amazing to work with.
Last futzed with by Betlog; August 12th, 2010 at 12:00 AM. |
June 26th, 2010, 07:34 PM | #2 |
Looks awesome.
June 26th, 2010, 07:48 PM | #3 |
Great pics and good looking bike.
June 26th, 2010, 07:57 PM | #4 |
never mind how it looks... how does it run?
June 26th, 2010, 08:27 PM | #5 |
July 18th, 2010, 07:07 PM | #6 |
Join Date: Jul 2010 Motorcycle(s): Black '11 ZX-6R Posts: 209
anyway i could request picture of backside of bike highltighting tire and instrument panel so i could take look at clip ons on the added angle
My 250 is mine and mine alone, you may see better you'll definitely see worse but mine, she's one of a kind!!!!btw, SHE'S SEXY!!! |
July 20th, 2010, 12:24 AM | #7 |
July 20th, 2010, 05:12 AM | #8 |
how much higher doe bike sit cause of tires and has there been ne problem runn w that big a tire
July 21st, 2010, 09:59 PM | #9 |
Not sure how much higher it sits. I lowered the front an inch so to me it is lower overall. As far as problems with the 150 tire size, it is pinched. This means, you will not be able to use the full tire. The ones I am using, BT-016 is not as bad as some of the other tires, such as the BT-003. You will find a lot of info on this if you search for the 150 tires on this forum. Good luck.
2009 Race Build | MikeRoot | 2008 - 2012 Ninja 250R Tech Talk | 14 | June 29th, 2014 12:27 PM |
My Blue 2009 Build | thisisbenji | Pictures | 39 | June 18th, 2014 09:24 AM |
another Rabies build. | rabies | 1986 - 2007 Ninja 250R Tech Talk | 76 | February 22nd, 2014 03:16 AM |
90 build up | justin_ninja | 1986 - 2007 Ninja 250R Tech Talk | 4 | January 12th, 2013 03:53 PM |
Build Your Own T-REX? | nickjpass | General Motorcycling Discussion | 26 | October 27th, 2011 09:51 AM |
