Old July 15th, 2013, 03:03 PM   #1
SafetyPaws
SafetyPaws's Avatar
Motorcycle(s): Ninja 250r
Chain and Brake Pads - Opinions
52xx Mile maintenance
Hey guys - so to start out I know I either have to clean the chain or replace it. See pics - it is hella rusted - I drive her every day and when it rains at work I can't cover her =/ Also at home she is parked outside covered when it rains when I have to get to work. Let me know what you think, if I have to replace it where can I buy one from / is there different brands one would recommend / maybe one that kan handle elements bit better? Same for maybe the sprockets - I watched @TheDuck video on the DIY - it was fast but I think I can change it out myself - may need to purchase a pitbull stand.
While I was down there I thought I would inspect my brake pads and rotors - due to what I thought was a squeek like two weeks ago. I noticed that my rear brakes are almost completely worn out. Front looks brand new - but both rotors have some decent indentation. I think I have to replace those as well - as if I were to get new pads they would prematurely deteriorate due to forming to the rotor (correct?). I also watch TheDuck in under 10 min DIY and I can definitely change Pads easy - but then when it comes to the rotors I may have to do more research. I searched the form and found that most used EBC and lots had problems with them - can anyone also recommend a brand for pads / rotors? Also maybe a good DIY for changing rotors as well.
Front Wheel
Rear Wheel
It is probably best to replace both front and rear at same time correct or to save a few bucks do front when its needed?
I also thought since I am working in same area to possible change brake lines to the spiegler - but I did not quite understand what the bleeding is / does fully from the DIY stickies. I know I have to do a bit more research on that. Is that probably a good idea to do at the same time?
Also on a side note (he has an RX8 and was going to repaint his calipers Red) - we were going to do mine but then I noticed pads upon inspection)- also since I am working in same area, I wanted to paint my calipers green - friend found Synergy Green Camaro caliper paint and thought I may give it a shot - it's expensive though. Anyone attempt this?
Also have no cage atm so when I do this will have to be probably on an upcoming holiday weekend or over the winter.
www.SafetyPaws.org
SafetyPaws is offline   Reply With Quote
Old July 16th, 2013, 02:44 PM   #2
SafetyPaws
SafetyPaws's Avatar
no love this time? =*(
www.SafetyPaws.org
Old July 16th, 2013, 02:52 PM   #3
krolinked
Nerd
krolinked's Avatar
For Sure New Pads!
As for the chain. Find A Grunge Brush i think its called. The brush to clean the chain. Then get a large can of wd-40 and a hose and spray, scrub, rinse, repeat until that chain is silver colored again. Spray the chain with Bel-ray Super CLean Lube. Its a white colored lube that doesnt fling off and lasts a long time.'
I've restored a worse looking chain and it has been 7500 miles since then and its fine.
So to wrap it up you need:
New Brake Pads,
Bel Ray Super CLean Chain Lube
Grunge Brush.
Water Hose.
WD-40
As far as whether or not to use EBC, I've used ebc HH and theyre good. However I've recently tried out Vesrah Race pads, and they're the BOMB.
IDK how long they will last compared to ebc though.
Old July 16th, 2013, 02:56 PM   #4
krolinked
Nerd
krolinked's Avatar
I wouldn't put vesrahs on the back though.... I'd put my current front pads on the back, and put new vesrahs onto the front.
Old July 16th, 2013, 11:01 PM   #5
Dark
Simple kind of man
Dark's Avatar
Motorcycle(s): 2013 Ninja 300
That chain is garbage and you should never let it get that bad. The rust particles will destroy the o-rings if they haven't already.
Get a new chain and keep up with cleaning and lubing it. Don't use WD-40, buy actual chain cleaner and lube at your local motorcycle shop.
Dark is offline   Reply With Quote
Old July 17th, 2013, 02:15 PM   #6
SafetyPaws
SafetyPaws's Avatar
Originally Posted by krolinked View Post
For Sure New Pads!
New Brake Pads,
Grunge Brush.
Water Hose.
WD-40
I was going to do that and buy a grunge brush, - the WD 40, but i do not think it will work. Same with adding water to it and cause more oxidation.
How about rotors?
I know I feel terrible for her - I neglected her. Can you recommend a chain / sprockets? Also do I get them from local dealer or online?
www.SafetyPaws.org
Old July 17th, 2013, 02:35 PM   #7
Dark
Simple kind of man
Dark's Avatar
You can get them local or online.
I have always ran the higher end DID chains (ERV3) which may be out of your budget. Any model DID, EK, Renthal chain should be fine and colored chains tend to resist rush a bit better due to the coating.
Cheap sprocket replacements would be JT or Sunstar, look for steel since they will last longer than aluminum.
Old July 18th, 2013, 06:29 PM   #8
mgentz
Board Member
Did non oring if you're good. Erv3 if you're ok. No bike if you're bad.
Yes to new pads.
Old July 18th, 2013, 06:50 PM   #9
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Vesrah FTW.
menikmati is offline   Reply With Quote
Old July 19th, 2013, 03:08 PM   #10
SafetyPaws
SafetyPaws's Avatar
I am on a budget - but i have kind of always leaned toward the best or higher quality for my ninjette so i do not mind spending extra money for value (reasonable of course). I am not tracking but just my DD, need something extremely reliable with good performance, anything to recommend on that note?
Also - what is benefit of changing teeth on sprocket, found this in wiki but not to helpful for 08-12 / does not explain anything.
Yes to new pads.
how do i know if i am good or ok? i understand the bad =]
Originally Posted by menikmati View Post
Vesrah FTW.
Ok so Vesrah pads is by popular vote - any others? Also how about the rotors?
Also would i have to replace the o-rings too, how can i check if they are good? (just if they are torn or ripped?
Appreciate the feedback so far, thanks.
www.SafetyPaws.org
Old July 19th, 2013, 11:38 PM   #11
Dark
Simple kind of man
Dark's Avatar
Here are some to point you in the right direction.
$160 - EK chain, pitbull sprockets. http://stores.sportbiketrackgear.com...l.bok?no=14120
$229 - DID chain, pitbull sprockets. http://stores.sportbiketrackgear.com...l.bok?no=14118
As for gearing, short gearing (smaller sprocket in the front and/or larger in the rear) will accelerate faster but have a slower top speed, you will also see higher rpm while highway cruising. It's the opposite for taller gearing. Folks that commute on the highway usually opt for slightly taller gearing to keep the revs lower while cruising. I would suggest stock gearing if you are fine with the stock gearing you have been using.
Old July 20th, 2013, 02:23 AM   #12
vince_2149
vince_2149's Avatar
Motorcycle(s): 2012 Ninja 250
I just replaced my chain a few days ago. I went with motomummy to get an RK gold chain and some Driven sprockets. Ran me $185 for that combo plus a chain tool since I wanted to do it myself.
https://www.motomummy.com/chain-kits...st-technology/
I couldn't have been happier with the quality of parts. I expect many, many miles out of this kit. I also went with a 15t front sprocket and love it. Can't really tell a difference in acceleration but in cruising RPM there's a noticeable difference.
vince_2149 is offline   Reply With Quote
Old July 20th, 2013, 04:27 AM   #13
Whiskey
The pads have to bed in to give optimal braking, so deforming to the grooves on the rotor is normal, the pads don't go to the edge so there is a section that will be the original width, then a scrubbed in section from pad contact.
I'd just do the rear, replace them with fresh pads (not the ones from the front as someone else suggested) as fresh pads will just have to bed in to the rotor's shape, not wear off the grooves that fit the front before wearing in grooves to fit the back
Service limit on the rotors is 4.5mm thick, measure it at a few points (measure in the notches, you'll have a thicker rim around the edge where the pads don't make contact)
Bleeding the brakes is to remove air bubbles, brake fluid can't be compressed, so it transmits the force from the lever to the caliper. Bubbles can be compressed, so some of the force exerted at the lever goes to compressing the air bubbles rather than moving the piston and applying the brakes. No bubbles = better brakes.
As it's a daily driver I'd fit something like this Scottoiler to lube the chain while its running, I've a DID non O ring chain with 16,000+ miles on it and a ton of adjustment left.
The sprockets look ok, there's no hooking on the teeth, mine's at 26,6xx miles and still has the original steel sprockets in good condition.
Last futzed with by Whiskey; August 3rd, 2013 at 10:24 AM. Reason: Different service limit on front & rear discs
Old July 21st, 2013, 11:35 AM   #14
Runeknight95
Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only
WD-40 can be used to clean but not as a lube, it doesn't last that long. Ignore those who say its bad for chains they haven't read the research.
I use maxima chain cleaner because its so easy though, http://www.amazon.com/Maxima-Clean-U...+chain+cleaner or http://www.amazon.com/Maxima-Chain-U...+chain+cleaner
I prefer the dupont chain saver as the lube though, http://www.amazon.com/DuPont-Teflon-...nt+chain+saver.
Follow the directions for cleaning with the maxima, yes you do add water to rinse the degreaser off
-buy a grunge brush http://www.amazon.com/Simple-Solutio...eywords=grunge
-buy a chain tool ~50 bucks, and you can do your own chains
-You can change gearing(sprockets) and what not but that's going to decrease your gas mileage, (possible defeating the purpose of your 250?)
-They recommended good chains already, the sprockets may not even need to be changed if you're looking to save money
As for the brakes, your front should of worn before the rear so that's just bad riding.
-replace the ones that are low not both, if you need to save $$
-I love my vesrah on my bikes but they are used for track as well so it may be overkill for you. Im not sure of how long they last compared to galfer or oem's
Runeknight95 is offline   Reply With Quote
Old July 28th, 2013, 11:04 AM   #15
SafetyPaws
SafetyPaws's Avatar
Thanks for the links and gearing explanation, much appreciated. I think i will stick with stock gearing for now.
thanks for link as well, whats the difference you noticed in the cruising RPM, maybe 45 mph (i think 4500 in 6th) speeds and freeway speeds at 70 mph (im around 9500 in 6th), 80 (10500 in 6th) mph?
Service limit on the rotors is 4mm thick, measure it at a few points (measure in the notches, you'll have a thicker rim around the edge where the pads don't make contact)
Thanks for Info as well - i have to find a micrometer or caliper to measure inside. I think I will be fine with stock rotors and sprockets for now.
Yar, the rear brakes were from my first year of riding and noobing it up. I now predominately use both brakes simultaneously and or occasionally just the front.
Have a link for the chain tool you used?
Thanks all for all the input, this is what I am looking to purchase.
Green EK MVXZ Series 520 Chain - anyone have any experience with the coating on these - will they eventually chip off and look nasty?
Rear brakes, nothing fancy
Green front brake line
Green Rear brake line
Also a better cover instead of the small tarp i am using for when I cannot store her in the garage.
I also plan on getting the grunge chain cleaner tool.
How about brake fluid - or does that matter at all?
www.SafetyPaws.org
Old July 28th, 2013, 12:35 PM   #16
Runeknight95
it was 60 bucks
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
ive done about 4 chains with it no issues
motion pros tool is 7 dollar more, id prolly get that if i could do it over again
brake fluid is every 3-5 years nothing to do with the pad replacement, you may need to take off the resevoir cap to compress the pistons im not sure. (pistons expand and fluid gets lower as the brake pads wear out
Old July 28th, 2013, 03:03 PM   #17
Whiskey
Carbone Lorraine are pretty good,
You're changing the lines, you'll have to change the fluid. Any DOT4 should be fine. I'd go with a reputable brand, a small bottle should do both & won't cost much.
Old July 28th, 2013, 03:27 PM   #18
Runeknight95
he didnt say he was changing the lines?
Old July 28th, 2013, 04:53 PM   #19
Whiskey
Yes he did
Old July 28th, 2013, 04:54 PM   #20
Runeknight95
Yes he did
Then hes guna need sum fluid! haha
Old August 3rd, 2013, 10:16 AM   #21
SafetyPaws
SafetyPaws's Avatar
thanks for the response / feed back - I will try and get these in the next few days and install em.
www.SafetyPaws.org
Old August 3rd, 2013, 10:23 AM   #22
Whiskey
@SafetyPaws I just noticed in my service manual that the service limit for the rear disc is 4.5mm, not 4 as I had said before (the front is 4)
Old August 3rd, 2013, 10:32 AM   #23
SafetyPaws
SafetyPaws's Avatar
What page is that on, drive chain + brakes is 115-127 for my manual, it mentioned pads mesurements and fluid but not the dics.
www.SafetyPaws.org
Old August 3rd, 2013, 10:50 AM   #24
SafetyPaws
SafetyPaws's Avatar
any brand preference for brake fluid or it doesnt really matter? Manual just says heavy duty dot 4.
www.SafetyPaws.org
Old August 3rd, 2013, 03:44 PM   #25
Whiskey
Section 12-16 Brakes
Brake disc wear inspection
My PDF copy of the carbed manual says its on 275, 366 in the EFI manual
Old August 4th, 2013, 04:35 PM   #26
quarterliter
Motorcycle(s): 2004 Ninja 250
I'm not sure if already stated but my suggestion is: DID X Ring chain, I like my sun star sprockets (made in japan) and vesrah sintered pads
Old August 4th, 2013, 05:48 PM   #27
quarterliter
Motul DOT 5.1 for brake fluid
Old August 4th, 2013, 07:48 PM   #28
Runeknight95
just 4.1 at least I like the ATE blue becuase you can tell when the yellow **** is flushed out amazon = 10 bucks for 500ml
Old August 9th, 2013, 04:30 PM   #29
skilletmo
InfoWhore
skilletmo's Avatar
Motorcycle(s): 2008 Ninja 250 StreetFighter ~~~~ 2005 KTM 450 EXC
Didnt want to start a new thread, but i just put some new brake pads on, the sintered HH EBC brake pads and they feel kind of stiff, i bedded them in by following the start stop instructions. Its normal to feel that way correct? Like it doesn't have much stopping power in the beginning untill it kind of breaks in... right? Just want to make sure.
Im going to install the ss brake lines soon, the ones from the group buy (apex). and post it on my project thread!
Everyone, go buy a dirtbike hurry
skilletmo is offline   Reply With Quote
Old August 13th, 2013, 05:16 PM   #30
SafetyPaws
SafetyPaws's Avatar
I will let you know in a few days how my feel, anyone else experience this?
The speiglar lines come with free brake fluid from STG.
Here is link to the rear rotor that i am replacing with the rear pads. EBC XC-Series Contour . Anyone use this in the past, they said EBC were one of best in world. Hope they are right.
www.SafetyPaws.org
Old August 13th, 2013, 06:19 PM   #31
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Keep in mind you're going to have to cut off some links from that chain before installation as it is longer than the OEM chain.
Old August 13th, 2013, 08:12 PM   #32
SafetyPaws
SafetyPaws's Avatar
Krap thought they were the same size 520x120? Hmm how many do you think I would have to remove?
I know that it should have about an inch of pull when tightened according to the manual but didnt think i would have to remove a lot, figured one or two with the master.
www.SafetyPaws.org
Old August 13th, 2013, 08:15 PM   #33
tfkrocks
tfkrocks's Avatar
OEM is 106 links.
Old August 15th, 2013, 01:58 PM   #34
Whiskey
I've started bedding one of those rotors in on the front, seems to be decent, but I've only put about 40 miles on it. if the weather is agreeable I'll probably put another few hundred on it before hitting the mountains this weekend.
Old August 15th, 2013, 02:13 PM   #35
Whiskey
Yes, it's not got much surface area in contact until the pads bed in, so you won't have as much stopping power.
Once the grooves on the disc are imprinted onto the pads you'll have full the full friction surface available & it'll stop the bike much quicker.
Old August 19th, 2013, 07:38 PM   #36
SafetyPaws
SafetyPaws's Avatar
OEM is 106 links.
Is it easy to remove the extra links?
Thats why i decided to change the rear rotor. Think that would be waste of pads and not as safe until they bed in - especially since they are the rear brakes.
www.SafetyPaws.org
Old August 19th, 2013, 08:16 PM   #37
tfkrocks
tfkrocks's Avatar
If you have a dremel yeah.
Old August 19th, 2013, 09:42 PM   #38
Bob2010
Bob2010's Avatar
Edit nvm
2010 Red Ninja 250
2009 Black Ninja 250
Old August 20th, 2013, 03:02 PM   #39
Whiskey
Only got another 150 or so miles on the bike over the weekend, EBC disc seems to be a good one
Old October 12th, 2013, 09:20 PM   #40
SafetyPaws
SafetyPaws's Avatar
Alright - have another questions, I have all the materials required (well almost need to buy some 271 Red loctite threadlocker for rear rotor but that's a simple trip to the home depot) - is there a video or DIY that shows how to install the new chain instead of just removing it as well as removing the links previously mentioned. Am I really supposed to use a dremel and cut off the links from a new chain?
Would it be best to find a local dealer to remove the links to the proper 106 links?
Edit: had to save up for some stands; now its getting kold but need to do this before the winter and gets really kold!
www.SafetyPaws.org
Cant find brake bolt connecting brake pads. Trubin General Motorcycling Discussion 6 June 3rd, 2014 05:35 PM
Replacing brake pads and brake fluid Bones85 2008 - 2012 Ninja 250R Tech Talk 4 April 28th, 2013 06:25 PM
Good chain and brake pads. blades8306 General Motorcycling Discussion 16 August 2nd, 2012 09:59 PM
Opinions on a gold chain joe_morris 2008 - 2012 Ninja 250R Tech Talk 25 January 20th, 2012 02:09 PM
brake/ tire opinions executor 2008 - 2012 Ninja 250R Tech Talk 41 July 29th, 2009 02:30 PM
