Old October 31st, 2014, 05:50 AM   #1
garth285
KAWASAKI GURU
garth285's Avatar
Has anyone measured the ACTUAL compression ratio?
Just like the title states has anyone actually measured the combustion chamber and piston, etc. of the 08-12 250r to find out the actual compression ratio?
Old October 31st, 2014, 06:24 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
No
For me it changed from stock after the head is polished.
To do it You need a cc measuring set up. And a third grader with a calculator to do the math. A Thread on how would be great. I would be interested to see what they are.
Worlds fastest 250 ninja
Old October 31st, 2014, 06:42 AM   #3
garth285
KAWASAKI GURU
garth285's Avatar
I've done it on some other bikes before I just didnt want to tear into this engine :-/ but I do have a spare so yeah thats good.
Racer X I may have some up with a VERY cost effective way to lower our compression :-)
Old October 31st, 2014, 06:53 AM   #4
kxpower?
kxpower?'s Avatar
Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000
Sub'd
Oh god the bikes are multiplying!!!
kxpower? is offline   Reply With Quote
Old October 31st, 2014, 07:06 AM   #5
Brother Michigan
Motorcycle(s): 2013 Ninja 300
You should be able to measure the compression ratio with a simple compression gauge. You know what atmospheric pressure is to a pretty good degree, so screw in the gauge, measure the greatest pressure, and take a ratio of the two. Make sure to close your petcock or disconnect the injectors beforehand. Do it a few times and you can build up an idea of the uncertainties inherent in the gauge you're using.
DISCLAIMER: I generally have no idea what I'm talking about.
Old October 31st, 2014, 07:27 AM   #6
kxpower?
kxpower?'s Avatar
It's not quite that simple but there's a way to measure the combustion chamber volume by measuring how much liquid the head + the piston dish volume or - the piston dome volume, plus volume added by the head gasket. From there it's just
CR=(displacement + CCV)/CCV
A lot of (auto) road racing bodies set a max compression ratio, they have this burette looking thing at the shop my brother co-ops in that they use to meter the water into the combustion chamber.
Old October 31st, 2014, 07:36 AM   #7
Brother Michigan
It's not perfect, but treating the air like an ideal gas and assuming isothermal compression (not really reasonable assumptions, but probably enough to get you to within a few percent), the ratio of compressed to uncompressed pressures does give the compression ratio.
Old October 31st, 2014, 07:44 AM   #8
garth285
KAWASAKI GURU
garth285's Avatar
That might be able to give you a ball park reading but I'm looking for 100% accurate measurements....
I just might have to do this myself but I've done it before its really not that bad although I forget how I measured the piston side....
Plexiglass with a hole in it, grease around the combustion chamber and a syringe with water.
I just looked online and they do the same thing with the piston but with the piston in the hole.
Old October 31st, 2014, 08:25 AM   #9
on the 40cc bikes we put sillicone down the spark plug hole at tdc and then disassemble, remove and weigh it to calculate a volume, then you can do basic math for the rest of the cylinder
Old October 31st, 2014, 08:26 AM   #10
garth285
KAWASAKI GURU
garth285's Avatar
I sent out some eamils to JE and Wiesco hoping they would be willing to give me atleats the Piston Dome Volume but I doubt they would lol.
Old October 31st, 2014, 09:24 AM   #11
garth285
KAWASAKI GURU
garth285's Avatar
@Racer x Do you think 8.5 or 9.0 :1 ratios will be to low for these turds and the VZ21 turbo?
Old October 31st, 2014, 09:27 AM   #12
Racer x
Racer x's Avatar
I wish I could say. I am going to start with 12.5 to 1 and polish the piston tips to remove sharp edges and the same with the head. This should be 11.8-12 to 1. I don't know how much you need to spin the turbo. But I know if the engine has less than 125 psi compresson it will not start.
Old October 31st, 2014, 09:36 AM   #13
garth285
KAWASAKI GURU
garth285's Avatar
10-4 well I Wiesco got back to me and sent me this:
Hello Shawn,
Thanks for the inquiry. Our 40062M06200 is 12.5:1 CR, with a
+3.1cc dome. We do not offer a low compression piston for the Ninja
250, but we could look at custom building this for you. We would have
to place an order for a minimum of 12 pistons and rough pricing would be
$157ea, (rings, pin, and clips all included). If you are interested in
having parts built, please give me a call at 800-321-1364 x3109 and we
can go over more of the details.
Old October 31st, 2014, 09:51 AM   #14
garth285
KAWASAKI GURU
garth285's Avatar
OK @Racer x here is what I was thinking for lowering the compression.. Obviously we know we can get a set of custom pistons made which that will be a nice $1,900. We can also run a spacer under the cylinder as well a .080" spacer should lower it by about 1.5-2 points I believe but wed probably need adjustable cam gears.
How about this idea..... Ninja 300 rods? They are about 2.8mm shorter, I did some rough calculations and I think it might drop the compression to much, like down to 7-7.5:1... so if we ran the 300 rods with 12.5-13.0:1 pistons it might bring it up to the 8.5-9.0:1 ratio we'd be looking for without having to run block spacers and such?
Benefits - Newer (possibly stronger) rods, little thicker on the small end and youd get a forged piston with it.
Sorry all you N/A guys I'm trying to think of ideas for the turbo setup :-p
Old October 31st, 2014, 09:54 AM   #15
garth285
KAWASAKI GURU
garth285's Avatar
Know what else I just thought of, looking at the ninja 300 piston, they moved the pin location UP which means the piston would actually sit lower in the block.... HMMMMMM
Old October 31st, 2014, 10:25 AM   #16
Racer x
Racer x's Avatar
I would not do the 300 rods myself. I have Carillo rods and love them. And if you go with custom Pistons. I have a good friend ,John Noonan at Wossner that can make custom Pistons. And he knows land speed racing.
If you want to go with thicker gaskets. Thick copper is good. Head gaskets.com has the pattern already and I have the gaskets. Ask to speak to Mordy Dunst.
The cam timing would have to be adjusted for the taller head distance.
Old October 31st, 2014, 11:11 AM   #17
That is generally regarded as close to optimum.
Here's some interesting reading on the subject - http://www.xcceleration.com/cr-boost%20101.htm
Old October 31st, 2014, 11:18 AM   #18
Racer x
Racer x's Avatar
My plan because I am running at high altitude is high compresson low boost. And that chart says 11 to one with 7.5 lb of boost is about 17 to 1 and that is what I want. And why j have Carillo rods
Old October 31st, 2014, 11:21 AM   #19
kxpower?
kxpower?'s Avatar
This thread prompted me to pretty-up a spreadsheet I put together when I put up this thread https://www.ninjette.org/forums/show...ht=compression. If anyone is interested I'll attach the live spreadsheet
Looks like (and this is assuming the new gen bore/stroke/CR is the same as the pregen) you need about 60 thousandths (1.5 mm) to get to a 9:1 CR. So about half what the 300 rods would get you. So if you can put your hands on a 0.060" gasket to run under the cylinder you'll be there.
Although like Racerx points out, we have no idea whether it will start, etc at a 9:1 CR. What do the turbo 'Busa guys run for CR?
I'm wanting to go the other way, by shaving .0125" off the block it will put the CR right at 13.5:1.
Old October 31st, 2014, 11:50 AM   #20
garth285
KAWASAKI GURU
garth285's Avatar
Yeah I cant justify the cost of Carrillo's with these engines being so cheap ya know.
As of now I'm going to stay with stock compression and head studs and E85. But I was considering with the spare engine doing a lower compression and more boost.
I might pick up some 300 engine parts for cheap and measure everything out and see what combinations I could use.
The 300 has 10.6:1 compression so those pistons might drop it to much with the piston dome and the pin relocation
Old October 31st, 2014, 11:59 AM   #21
garth285
KAWASAKI GURU
garth285's Avatar
@kxpower? the 08-12 250's have 11.6:1 compression just as an FYI
Also can you modify that sheet you posted or no?
Old October 31st, 2014, 01:02 PM   #22
kxpower?
kxpower?'s Avatar
Yeah sure can. Same bore and stroke?
Old October 31st, 2014, 01:04 PM   #23
kxpower?
kxpower?'s Avatar
Crap laptop battery is dead it'll have to wait till after trick or treating.
Old October 31st, 2014, 01:05 PM   #24
garth285
KAWASAKI GURU
garth285's Avatar
yup, how did you figure that CC Volume?
Old October 31st, 2014, 01:06 PM   #25
garth285
KAWASAKI GURU
garth285's Avatar
No rush, same here!!! lol
Old October 31st, 2014, 01:08 PM   #26
kxpower?
kxpower?'s Avatar
(Displacement + CCV)/CCV = CR, I don't remember how but you just solve for CCV.
Old October 31st, 2014, 01:11 PM   #27
garth285
KAWASAKI GURU
garth285's Avatar
OK I got ya, so that should 15.55cc's should be the piston volume and combustion chamber volume.... hmmm very interesting!
Old October 31st, 2014, 02:06 PM   #28
Racer x
Racer x's Avatar
The rods are not that much stock compresson is good but not stock Pistons.
Old October 31st, 2014, 02:16 PM   #29
Racer x
Racer x's Avatar
This is some photos of the gaskets. The copper one is .040 abot four times the thickness of stock.
Old October 31st, 2014, 02:18 PM   #30
Racer x
Racer x's Avatar
More pictures
Old October 31st, 2014, 03:50 PM   #31
micoulisninja
modaholic junkie
2,9mm to be exact...
the 300 rods are indeed stronger and beefier at top end...using a couple of forged on top of them would be ideal...
I had told you that when you first presented your idea but you had rejected it as being expensive for your project...
the cheap version would be to keep stock rods and get a 300 aluminum block and pistons....the serious drawback is that the pistons are cast but on the other hand you have much lighter pistons and pins (about 10 grams less reciprocating weight on each cylinder), flat crown and better heat dissipation....
don't make it too powerful Shawn !! I am jealous already....
PS: it is really easy to make stock cam sprockets adjustable...
Old October 31st, 2014, 04:37 PM   #32
garth285
KAWASAKI GURU
garth285's Avatar
I must have missed that!
What I was trying to see is if I Could use just one part for the project like the rods or the pistons, sort of a drop in and go kinda deal, the rods would have been the best... maybe I Should start looking at other bikes rod dimensions to find out what would work.
Old October 31st, 2014, 04:49 PM   #33
Racer x
Racer x's Avatar
Forged Pistons are pretty important. J had no trouble smashing holes in forged Pistons and compressing ring lands. I would hate to see what would happen with cast Pistons.
The stock rods are good to 120 hp according to some people I have talked to.
Old October 31st, 2014, 04:50 PM   #34
garth285
KAWASAKI GURU
garth285's Avatar
Was that on nitrous?
Old October 31st, 2014, 09:35 PM   #35
Racer x
Racer x's Avatar
With my old system. The new syst does not do damage like that
Old October 31st, 2014, 11:06 PM   #36
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
7:1 - 96psi
8:1 - 117psi
9:1 - 139psi
10:1 - 161psi
11:1 - 184psi
12:1 - 208psi
You allow 60% ve at cranking speed
ninja250r81 is offline   Reply With Quote
Old November 1st, 2014, 02:04 AM   #37
micoulisninja
modaholic junkie
try the ZX-6R rods years '98-'04....
the '00 gen definetely is compatible in terms of top end since the piston pin is the exact same as for the 250 !!
I' d appreciate some feedback on your findings since I might end up doing sth like that myself...don't forget to weigh them too !!
Old November 1st, 2014, 05:40 AM   #38
DaBlue1
DaBlue1's Avatar
Has anyone looked at reducing the flywheel weight for a slight HP gain?
http://www.xlitemoto.com/products_de...b3a9dd432.html
Old November 1st, 2014, 09:41 AM   #39
kxpower?
kxpower?'s Avatar
Here is the actual spreadsheet so others can fool around with it. I put in 11.6 for the stock CR and did a goal-seek to set the new CR at 9:1. As you can see you need to add about 0.050".
So go from 0.010" head gasket to 0.040" copper, and a 0.020" (maybe get copper made too?) cylinder block to crankcase seal and you're there.
Old November 1st, 2014, 01:00 PM   #40
garth285
KAWASAKI GURU
garth285's Avatar
Thank you sir! Yeah I think I need to scrap this 300 rod idea, if they were maybe only 1mm shorter it would work but yeah to much.
I'm gunna stick to stock stuff for now!
@Racer x I dont doubt nitrous did that to those pistons! Nitrous is a lot harder on pistons than boost.
13.5:1 compression ratio kits Swann 2008 - 2012 Ninja 250R Tech Talk 46 October 9th, 2020 04:43 PM
[motogp.com] - Measured Marquez conquers elements in Assen Ninjette Newsbot Motorcycling News 0 June 28th, 2014 08:30 AM
[superbikeplanet.com] - Beta Testing, With An Actual Betamax Ninjette Newsbot Motorcycling News 0 September 14th, 2012 02:30 AM
Should have measured twice Renner General Motorcycling Discussion 15 June 19th, 2012 06:54 AM
Gear Ratio illrational 2008 - 2012 Ninja 250R Tech Talk 2 August 19th, 2010 09:47 AM
