Old April 6th, 2014, 07:40 AM   #1
bikehor
Motorcycle(s): 2010 Triumph STR, 2008 Ninja 250r, 2007 VRSCDX
2008 Ninja 250r Cafe Racer Inspired Conversion
Greetings all. I have been a long time lurker and figured it was about time to make my first post.
We've had a killer winter up here in the great white north, but it afforded me the opportunity to complete this project, so I figured I would share the process.
First of all I removed all the fairings, panels, fender, lights, gauges, passenger pegs, seats, etc. (nearly 40lbs worth)
I wanted to go for a cafe racer look, so the seat/tail section was the first place to start. My only constraint was that I didn't want to permanently modify the bike. (i.e. no cutting the frame)
This makes the cafe-look a bit of a challenge due to the high slope of the ninja's tail section. I needed to figure out how to make it appear flat/horizontal.
I first did a cardboard model of what I wanted just to get a feel for the scale of things.
After googling a bit I decided that fiberglass was going to be the easiest DIY method of fabricating the parts I needed. Before I started this project I had never worked with fiberglass before. It's as messy as smelly as it looks, but it's also fairly inexpensive and forgiving of mistakes. (Which turns out to be a good thing as you will soon see)
I bought a bunch of those florist foam blocks that they use to stick flowers into at weddings and such. It carves really easily and is cheap.
I taped up my carved shape (positive mold) with painters tape and then coated it with car wax (used as a releasing agent for the polyester resin)
I brushed the polyester resin over the positive and then added fiberglass mat to cover the entire shape. Let that set up for a bit and repeated the process. (20-30 mins)
Once everything set up well (over-night) I pulled the positive out.
Then a fair bit of sanding and filling and sanding and filling...
Cut/shape to fit and look the way I wanted.
Primed with fiberglass primer/filler
Primed with black primer.
Given that this was my first go at this stuff, I decided to go the rattle-can route for painting. If I didn't like the look it wouldn't be a big loss. And if it came out well I can get it done properly later.
As it turns out, I'm glad I went this route, because I didn't like the way it looked (too much like a mailbox on the back of my bike) so I decided to cut it up and reshape it a bit.
It totally sucked to trash the first version, but I learned a lot along the way.
After reading a bit on the web, I decided that it would be easier to take the modified version and make a negative mold and do a fiberglass pour instead of carving/wrapping another positive. I basically cut a 2 inch section out of the middle of the back-rest and molded a bump-out that would help support the tail-light as well as give it a more curved appearance.
This was easier than the first round and definitely my preferred way to go for complex shapes. Just burlap and plaster over the original. Basically it's what paleontologists do when getting dinosaur bones back to the museum. But this mold is damned heavy.
The nice thing about pouring the first layer is that it is much smoother, therefore a lot less sanding
Then, as before, I cut/shaped it to fit and look the way I wanted., primed with fiberglass primer/filler, and primed with black primer. You might notice the tail-light is the stock one. I cut the hole and made the bump-out specifically to fit. This comes into play later.
I was much happier with this attempt. So I decided to paint up the tail section and add some of the stripes I had envisioned. I stuck with black and aluminum as my color scheme.
Because I wanted to use all of the stock wiring, but do away with as much stuff as possible, I replaced the rear tail-light with an integrated brake/tail-light turn-signal. This is a plug and play replacement for the stock tail-light.
Up close.
Here it is all mounted up. You probably noticed a bit of work on the front end. While I was doing the tail section, I ordered a large 7in headlight with turn-signals and the Koso RX-2 plug and play gauges.
The Koso plug and play kit made the installation super easy.
Now I needed to tackle the front fender. I saw on this forum where someone simply wrapped the front tire with fiberglass and voila. It looked like a good idea, so I gave it a go.
I covered the section of the tire I wanted to mold to with painters tape. Then I coated the tape with car wax. I then brushed on a thick layer of resin. This time I used fiberglass cloth instead of mat for my first layer. This makes it very smooth.
Then I added a second layer of fiberglass mat for strength and final layer of fiberglass cloth.
I popped the fender off the wheel and it's now ready for cutting, sanding, priming, etc.
Rough cut
Cut to shape, sanded and filled.
Primer/Filler
Black Primer
Final paint.
Now I needed some mounting hardware. I took an old-style metal coat hangar and bent it to fit inside the fender. I needed to get a rough shape and get the distances to the mounting holes on the front forks correct.
I ended up using a couple of shelf hangars. I cut them to a rough length and shape.
Once I got one to fit nicely I just duplicated it with the second. Once everything looked good I painted them up.
Here they are mounted on the fender.
And here is the fender mounted on the bike.
Finally I needed to get the seat done. This was the one thing I couldn't DIY so I figured I would just call an upholstery shop. Turns out there aren't too many who do custom motorcycle seats. There is another cafe racer project here by Ivanrules (a beautiful job) where he does a seat pan that the upholsterer can work with, and which makes the seat easily removable. I decided to go that route as well.
I basically followed the exact same procedure I did with the front fender. Cloth, then mat, then cloth again.
Cut and trimmed.
I have the seat pan overhang a bit in the front so the seat will be nice and tight against the tank.
Here's what I got back from the upholsterer.
And here's how she looks all together.
So, there she is. Thanks to the site members for all the cool projects and ideas that were such an inspiration. I still need to get something interesting for the coolant overflow tank. If mother nature cooperates I might be able to take her out on her maiden voyage this week.
bikehor is offline   Reply With Quote
Old April 6th, 2014, 08:05 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Wow. That is nice.
Worlds fastest 250 ninja
Old April 6th, 2014, 08:38 AM   #3
I like!
Old April 6th, 2014, 12:37 PM   #4
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Very nice and well done, I do think it would look better with a shorter tail
Old April 6th, 2014, 02:41 PM   #5
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Very nice! Lots of work into that. You keeping the stock tank?
Old April 6th, 2014, 02:46 PM   #6
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
looks a little long on the rear end but other than that it looks very nice, I like it.
Old April 6th, 2014, 02:46 PM   #7
chugs
Schönen Tag noch
chugs's Avatar
Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica
Nice work.
chugs is offline   Reply With Quote
Old April 6th, 2014, 03:21 PM   #8
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
that looks good.
TEAM ALFALFA
www.apexassassins.com
Old April 6th, 2014, 03:48 PM   #9
capt_bugaloo
motorcycle rider
capt_bugaloo's Avatar
Thumbs up
I'd like to see some photos of it out in the sun!
Old April 6th, 2014, 05:33 PM   #10
bikehor
Thanks for all the positive responses.
With regard to the tail section looking a little long, I agree. However, given the constraint I gave myself, (that I couldn't permanently modify the bike) I had to work with the frame as is. That cowl section is as short as it can be. The frame rails for the tail section run to the upper back of the cowl. (the yellow line) and the seat-back's bottom edge is against the frame rail. (the yellow circle) I could have angled the entire thing much more severely and would have been able to shorten it a fair bit, but then it wouldn't have had the cafe look I was going for. It was a trade off. The upside is that if I ever decide to put the passenger pegs back on, I could throw a little saddle cushion on the cowl and because it's mounted to the frame rail there I could carry a pillion.
Old April 6th, 2014, 05:38 PM   #11
bikehor
Thanks! It was a great winter project. As for the stock tank... for now I'm keeping it. I didn't cut the tabs or anything (again, no permanent mods - I can actually put the entire bike back to stock in an hour or two.)
But, if I could find a cool looking tank that is more cafe style I'd definitely swap this one out. I'm not sure I'm ready to try to make a tank out of fiberglass. (although I've read about others who have done it.)
Old April 6th, 2014, 05:43 PM   #12
bikehor
Will do. But you'll have to have a chat with mother nature, she's been an evil bitch this winter/spring.
Actually, I'll be taking her out tomorrow, so I'll snap a couple more pics.
Old April 7th, 2014, 06:11 PM   #13
bikehor
Here you go. We finally got some great weather today. Had a nice little scoot (70 mi) for her maiden voyage. I swear the bike was faster. (just like that first ride after you wash it. ) The seat was super comfortable. It's more comfy than the Sargent or Sundowner on my other bikes.
Old April 7th, 2014, 07:15 PM   #14
Ninja Bob
Certified Slacker
Ninja Bob's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R SE
Thumbs up
Fantastic!
Ninja Bob is offline   Reply With Quote
Cafe Racer Project - 04 Ninja 250R Butch General Motorcycling Discussion 58 June 17th, 2015 03:49 PM
[motorcycle.com] - Fandango, The Cafe Racer-Inspired Jacket From Spidi Ninjette Newsbot Motorcycling News 0 April 2nd, 2015 04:30 PM
Hello from Indonesia! NINJA 250r Modern Cafe Racer munandar New Members 23 August 6th, 2014 11:43 PM
Indonesian NINJA 250r Modern Cafe Racer II munandar Pictures 25 February 4th, 2012 11:21 PM
NINJA 250r Modern Cafe Racer ... Your comments are highly appreciated munandar Pictures 38 July 11th, 2011 07:45 PM
