Old April 24th, 2015, 11:50 AM   #1
Proteus
Daily Ninjette Rider
Proteus's Avatar
Motorcycle(s): 2012 Ninja 250R, 2015 Vespa GTS 300 IE Super, 1989 Honda Elite 80 (SOLD)
Brake light issues
Yesterday when I started my bike up I noticed that the brake light was constantly on, nothing happened when I pulled/stepped on either lever. I found a thread on here that talked about the brake light sensor, and mine was barely screwed in. I threaded it all the way down, and my brake light resumed normal operation with the hand lever. But now it won't do anything in response to the foot pedal. If I thread it almost all the way out it responds to the foot pedal, which is why I imagine it was threaded out that far (I just had new tires put on).
Is the sensor supposed to be threaded in all the way? Right now the only way the pedal affects the light is if it's barely threaded on, which makes it easy to loosen just a bit and go to always-on again.
Check out my music at http://www.proteusmusic.com
Proteus is offline   Reply With Quote
Old April 24th, 2015, 11:53 AM   #2
Ghostt
Ghostt's Avatar
Rear sensor needs to be adjusting, just have a go at it .
violente et ignorantia
ZX-2R BLOG
Old April 24th, 2015, 12:23 PM   #3
Proteus
Proteus's Avatar
Is it supposed to be threaded all the way in?
Old April 24th, 2015, 12:33 PM   #4
Ghostt
Ghostt's Avatar
That's how you adjust it, in or out depending on how you like it, some adjust it to come on with just barely touching it, or more pedal
ZX-2R BLOG
Old April 24th, 2015, 01:06 PM   #5
Proteus
Proteus's Avatar
Thanks, I'll give it a spin.
Old April 24th, 2015, 02:31 PM   #6
DaBlue1
DaBlue1's Avatar
Have a look...https://www.ninjette.org/forums/show...15&postcount=6
Old April 24th, 2015, 04:06 PM   #7
Proteus
Proteus's Avatar
Just played around with it and got it adjusted correctly. Thanks!
rear brake issues mikromo 2008 - 2012 Ninja 250R Tech Talk 7 October 2nd, 2013 09:51 AM
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL coelgrim 2008 - 2012 Ninja 250R Tech Talk 16 March 11th, 2013 05:10 PM
Brake Issues SSANGHA 2008 - 2012 Ninja 250R Tech Talk 9 November 5th, 2012 09:49 PM
License Plate Light- legal issues, wiring help spencerkro 2008 - 2012 Ninja 250R Farkles 6 March 20th, 2011 09:43 PM
Rear Tail-Light issues! ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 14 September 9th, 2009 06:59 AM
