Old July 15th, 2016, 10:32 AM   #1
Joshua95
Motorcycle(s): 2009 Kawasaki Ninja 250r
Which brand of battery should I go for?
So I need to replace my battery. I know that the part number of the battery I'm looking for is YTX7A-BS but which brand is good?
Joshua95 is offline   Reply With Quote
Old July 15th, 2016, 10:53 AM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Yuasa
Goin' fast on slow bikes!
Old July 15th, 2016, 11:45 AM   #3
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Are you looking for a lightweight or traditional style battery?
Old July 15th, 2016, 05:39 PM   #4
Joshua95
Not really sure but I guess just the standard that everybody use.
Old July 15th, 2016, 06:58 PM   #5
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
do some research
Old July 16th, 2016, 08:21 AM   #6
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
I've had good luck with the rebranded Deka AGM batteries that Advance Auto sells. The size that the EX500 and VN750 use end up being ~$50 after coupon code. They're not much more than the cheapest ones you can find, and you can go get them locally instead of waiting for shipping.
For whatever it's worth, they list the YTX7A-BS for the '08 and the YTX9-BS for the '09-'12. They have an ETX9 to fit that one. I'm sure someone else has better information, but I think you can swap them by just removing a spacer or something (possibly have to mod the battery box a little).
Deka's batteries are rebranded and sold under multiple names. I've seen Magna Power (what AA sells) and Big Crank listed. I wouldn't assume each and every ETX9 is a Deka, but it's quite likely if it looks identical other than the sticker.
Old July 16th, 2016, 11:03 AM   #7
Lazarus
Lazarus's Avatar
Motorcycle(s): 2008 Ninja 250
Haven't had any problems with the advanced auto battery I bought. Don't remember the price but she fires right up every time, though it's only 6 months old.
Lazarus is offline   Reply With Quote
Old July 17th, 2016, 03:50 AM   #8
juliusmichaelhonrada
Motorcycle(s): GPX250-RII
Edison cells - ability to withstand vibration, high temperatures and other physical stress , with a lifespan of 30-50years before needing replacement of... electrolyte and its good for another 30-50 years
juliusmichaelhonrada is offline   Reply With Quote
Old July 17th, 2016, 02:11 PM   #9
Ghostt
Ghostt's Avatar
Sealed gel battery, no maintenance
The one's I use,
TMS® YTX7L-BS YTX7LBS GTX7L-BS UTX7L ATV Quad Motorcycle Scooter Moped GEL Maintenance Free Battery https://www.amazon.com/dp/B0051VGEV2..._.p.IxbJQW9C0H
YTX7L-BS High Performance - Maintenance Free - Sealed iGel Motorcycle Battery https://www.amazon.com/dp/B00IUV881Y..._Cq.IxbRDKHC04
violente et ignorantia
ZX-2R BLOG
Old July 17th, 2016, 02:49 PM   #10
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
The last battery I bought was one of these for my Aprilia. Expensive, but it's crazy how light they are.
http://www.bikemaster.com/batteries/...mit=all&store=
So far no problems with reliability. Even in freezing temps my bike starts first time, every time.
Old July 17th, 2016, 02:52 PM   #11
HoneyBadgerRy
HoneyBadgerRy's Avatar
If I were to replace my battery I'd buy a shorai, but if I was strapped for cash I'd get a yuasa. Hope this helps.
I think on the pregen you need to change your rectifier if you go Shorai, but this is something you should do anyway, and someone on the forum has an easy kit to do it.
Old July 17th, 2016, 02:53 PM   #12
HoneyBadgerRy
Old July 17th, 2016, 09:06 PM   #13
InvisiBill
InvisiBill's Avatar
Different battery chemistries have different charging methods. If you're switching to something new and fancy, do some research into how it likes to be charged. The 40+ year old charging technology used on these bikes (the NewGen is a different part number, but it's the same style R/R as the PreGen) isn't the most precise. The MOSFET R/R retrofit is a little better, but its output still may not match the ideal setup for an exotic battery.
Old July 18th, 2016, 10:50 AM   #14
Joshua95
The one's I use,
If I happen to have to buy the battery online will it come fully charged?? so I don't have to do anything and just install it right away.
Old July 18th, 2016, 10:53 AM   #15
Ghostt
Ghostt's Avatar
Mostly, but I've always charged them first before using them, just to be sure, and a long time ago it's what we did, to avoid damage to the battery, or some other reasons.
I'm old, and don't remember
ZX-2R BLOG
Old July 18th, 2016, 10:56 AM   #16
Joshua95
And you use that battery tender to charged them right?
Old July 18th, 2016, 11:24 AM   #17
Do you have a battery tender? It can be used to make sure that the battery is fully up to speed before you install it.
Old July 18th, 2016, 11:49 AM   #18
Ghostt
Ghostt's Avatar
Yup
ZX-2R BLOG
Old July 19th, 2016, 05:44 PM   #19
Joshua95
I do not have one, but I will get it.
Old July 20th, 2016, 05:46 PM   #20
UFOmoplata
UFOmoplata's Avatar
Motorcycle(s): 2007 Hoodrat 250
I'm using a Ballistic 4-cell battery. Weighs less than a pound and so far had no trouble charging and starting the bike. It was about $100. Reasoning instead of trying to squeeze horsepower out of the small engine, best bet would be to lighten the bike as much as possible.
"Brah, you can't be looking like that on a 250, brah. You gotta mod a 250, brah. It's like the hachi-roku of bikes."
UFOmoplata is offline   Reply With Quote
Old July 22nd, 2016, 08:49 AM   #21
bruce71198
bruce71198's Avatar
The 7A in your battery part number indicates its a 7 amp/hour battery. The rest of the letters designate things like terminal location, case size, material used and such. I have 6 bikes right now with the lithium batteries from Batteries Plus in them all with good results. I believe that you can get these with a higher Amp/hour rating in the same size case but I would have to double check. They are more expensive ($130 ish) but these things weigh less than the box they come in!
Old July 22nd, 2016, 09:05 AM   #22
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
^^ got a part # or pic of the ones from B+
Old July 27th, 2016, 06:18 PM   #23
Joshua95
My bike is 09 and they tell me that YTX9-BS can fit. So I decided to buy Yuasa YTX9-BS.
Old July 27th, 2016, 06:23 PM   #24
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
I just put this one in my 250. I had to remove the foam at the bottom of the battery box and also remove the plastic cover on the battery that holds those relays. It's a snug fit after that but squeezes in there.
Major plus is that it you don't have to fill it and it's cheap too. We'll see how it holds up.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old July 29th, 2016, 05:45 PM   #25
Joshua95
You bought it online? Do you have to charge it before you put on your bike? This one doesn't look like you have to put the acid yourself.
Old July 29th, 2016, 05:48 PM   #26
ForceofWill
Got it right off amazon. It comes sealed up and ready to go, it was nearly fully charged when I got it but I threw it on the charger for the night anyway.
Old August 1st, 2016, 08:53 PM   #27
Joshua95
Gotcha and what battery tender would you suggest me to buy? preferably the one that just plug and play and cheap.
Old August 1st, 2016, 09:24 PM   #28
ForceofWill
I have a little battery tender brand tender which is fine for maintaining charge and it gives you a plug to wire to the battery to make it easier. I also have an automatic Schumacher charger/maintainer that's more of a beast and charges faster but it cost more. Both you can probably get at Walmart.
Old August 2nd, 2016, 08:42 AM   #29
InvisiBill
InvisiBill's Avatar
https://www.tractorsupply.com/tsc/pr...maintainer-15a is what I use. $25, 1.5A, and it includes a lead to connect permanently to the battery posts as well as a set of alligator clips.
Old August 3rd, 2016, 04:49 PM   #30
Joshua95
That one looks good and pretty cheap. I'm ordering it now thank you.
Brand New Battery? what to do? itslocfoo 1986 - 2007 Ninja 250R Tech Talk 19 May 28th, 2014 11:40 AM
FS: Battery Tender 021-0128 Battery Tender Plus 12V Battery Charger (Automotive) tagg Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
FS: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger (Automotive) ta Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
Is the OEM battery brand YUASA? Mine wasn't, dying after 2 years ock1 2008 - 2012 Ninja 250R Tech Talk 1 November 5th, 2012 12:01 AM
