Old September 7th, 2009, 08:16 PM   #1
boyonfire
Motorcycle(s): 07 ninja 250
so.. ninja lowsided... questions about fixes!!
The damage: scratched fairing, shift lever bent awkwardly, (both) handle bar inserts bent toward the gas tank, and the signal light got ripped right off.
The result: The shift lever makes it super hard to my foot to get under it and shift, and the bar inserts pinch my fingers when I turn.
The solution? Being cheap and a student, is it possible to bend the handle bar inserts and the shift lever back to their original positions without further damaging them? I hope I don't have to replace them
boyonfire is offline   Reply With Quote
Old September 7th, 2009, 08:29 PM   #2
The shift lever can possibly be straightened out. remove it from the bike and use a vice and a hammer carefully pound it back into shape, depending on how badly bent it is.
pics would help.
Old September 7th, 2009, 10:05 PM   #3
boyonfire
I will try that kkim. And as far as pics go, my ninja is at a friend's house across the bay bridge, and my knee is injured. I will try to post some up asap.
How about straightening the handlebars too?
Does anyone know if I could use these as replacements? http://www.motorcycle-superstore.com...ement-Bar.aspx
Old September 7th, 2009, 10:08 PM   #4
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
Not for stock replacement,but if you had clip-ons sure.
Old September 8th, 2009, 12:02 AM   #5
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
Look on ebay. For pregens, there's a ton of used replacement parts available for much cheaper than new parts. Check it out, you might get lucky. Good luck on the fix, and heal up soon!
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old September 8th, 2009, 06:46 AM   #6
smcbride11
smcbride11's Avatar
Motorcycle(s): '95 BMW K75
Like Kelly mentions, the shifter's an easy fix. You may need to use a pipe to help leverage it to bend it back, but it's not a big deal.
The stock handlebars and turn signal cost about $80 and $40 respectively, and they're quick replacements. The fairing you can likely live with.
smcbride11 is offline   Reply With Quote
Old September 8th, 2009, 02:27 PM   #7
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
I second ebay as a source for parts. I hope the knee heals up soon - look for my oops thread if you need someone to commiserate with
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Any temp fixes for scuffed marks? IF13 2008 - 2012 Ninja 250R Farkles 2 September 4th, 2013 09:45 PM
So I just lowsided my ninja 250r :( Richardcheung !%@*#$%!)@#&!%@ I crashed! 45 November 21st, 2012 02:31 PM
Small shallow dent on tank v. Fixes? edxmon 2008 - 2012 Ninja 250R Farkles 7 March 26th, 2012 02:16 PM
Lowsided my freshly converted efi ninja k12.usmc !%@*#$%!)@#&!%@ I crashed! 35 November 17th, 2011 05:32 PM
[motorcycle.com] - Kawasaki Fixes ZX-10R Problem Ninjette Newsbot Motorcycling News 0 December 30th, 2010 03:40 PM
