Old February 21st, 2011, 06:16 AM   #1
KURT
Resident Old Guy
KURT's Avatar
Motorcycle(s): sold
Clip-ons Installed, now Clearance Issues
Just like when I put aftermarket bars, on my 650R, the bodywork on the 250 interferes with the clip-ons. Everything works and functions, but the cables rub against the fairing at full lock.
Has anyone come up with a way to limit steering travel, such as building up the steering stops?
KURT is offline   Reply With Quote
Old February 21st, 2011, 06:47 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I drilled a small hole in the lower fork clamp steering stop where it hits the frame.and then screwed in a small screw. That limited the steering .I don't even notice it . But it will make oparking harder.
Old February 21st, 2011, 07:03 AM   #3
KURT
Resident Old Guy
KURT's Avatar
Motorcycle(s): sold
Originally Posted by Racer x View Post
I drilled a small hole in the lower fork clamp steering stop where it hits the frame.and then screwed in a small screw. That limited the steering .I don't even notice it . But it will make parking harder.
Thanks Eric, I'll look into that.
I have similar issues with my own bike. But since I'm the rider, I just try to not steer the bike to full lock. This one is my wife's, so for convenience, I want to make a fix for the problem.
Old February 21st, 2011, 07:57 AM   #4
dubojr1
dubojr1's Avatar
What brand clip-ons did you use?
Old February 21st, 2011, 11:12 AM   #5
want1sobad
Ninjette CPT
want1sobad's Avatar
Motorcycle(s): Black 08 250r
jd, he has a pair of shinto's from me kurt - pm randomwalk101 (john tran). he has a pair of shinto clip-ons installed with no clearance issues if i recall.
want1sobad is offline   Reply With Quote
Old February 21st, 2011, 03:59 PM   #6
dyeforever
dyeforever's Avatar
Motorcycle(s): 04 250r(sold), 09 250r(sold), 07 CRF450x, 07 sv650(sold)
i also had clearance issues with my shito clipons. there is a very small window where the clipons will clear everything but barely.
dyeforever is offline   Reply With Quote
Old February 21st, 2011, 08:55 PM   #7
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
Kurt, you could also try and cable-tie everything together to yield a much stiffer bunch of cables, and create a wider arch with this stiffer bunch of cable, and maybe get away from the rubbing....
I'm personally not a fan of limiting the steering...
Old February 21st, 2011, 09:24 PM   #8
nexus
ninjee two-fiddie
nexus's Avatar
I had clearance issues with the shinto clipons as well. After adjusting and tweaking for a week, I just gave up and mounted them above the triple-tree. My fairings were getting scratched and i didn't want to adjust the bar angle any higher than horizontal.
nexus is offline   Reply With Quote
Old February 21st, 2011, 09:57 PM   #9
dyeforever
dyeforever's Avatar
my throttle cables, wires hit my fairings and my brake line hit my koso gauge. i thought that how.
I will post a video tomorrow.
Old February 22nd, 2011, 06:53 AM   #10
KURT
Resident Old Guy
KURT's Avatar
Motorcycle(s): sold
I moved the break line a few degrees, and messed with the cables some. It's just the last bit of turn each way, that's the problem.
To the left, if I limit the turning to the 'locked' position, I'd be fine. I'm going to look into bonding a washer to the turn stop, or tapping in a screw, the way Eric did.
Old February 22nd, 2011, 10:19 PM   #11
dyeforever
dyeforever's Avatar
Driven Clip-ons Installed Redgeneral 2008 - 2012 Ninja 250R Tech Talk 16 May 1st, 2015 05:47 AM
Ebay clip ons installed Lucagst 2008 - 2012 Ninja 250R Tech Talk 11 March 31st, 2014 07:01 PM
driven clip ons sorta clearance issue kush452 2008 - 2012 Ninja 250R Farkles 1 March 22nd, 2013 02:42 AM
woodcraft clip ons installed NHrider19 2008 - 2012 Ninja 250R Tech Talk 1 August 5th, 2012 02:10 PM
Removing upper triple to get Shinto clip-ons installed adouglas 2008 - 2012 Ninja 250R Tech Talk 10 October 15th, 2010 12:43 AM
