September 28th, 2011, 09:44 AM | #1 |
cuz
Join Date: Jul 2011 Motorcycle(s): 09 ninja 250r Posts: A lot.
K&N 0990 owners
hey whats up ok im in the middle of my install but dont know if i should use the runners or just clamp the 0990 right next to the carbs and if you just shove the runners into the 0990 wont that worp them? would it be better if i just dont use the runners at all? well txs
THE GOOD LIFE |
September 28th, 2011, 09:59 AM | #2 |
You are sleeping
I clamp the filter straight to the carbs.
It has no problem fitting right on easy. The runner is another piece I didn't need just like the airbox.
<Yeah, it's a 250. LMFAO! Weaksauce |
September 28th, 2011, 10:16 AM | #3 |
No runners.
I made four small v-shaped cut-outs on the K&N filter so it could "taper down" as I tightened the clamps up. In the picture you can see the four little cut-outs on each intake side. You make them small so their edges close together when you clamp them tight on the carb intakes. |
September 28th, 2011, 10:38 AM | #4 |
I used the runners and it works great. You have to bend them a bit to get them in the filter but they spring back to shape once they are inside. Snug the clamps and your good to go.
September 28th, 2011, 11:45 AM | #5 |
Join Date: Apr 2011 Motorcycle(s): '09 250R, '13 CBR500R Posts: 709
i didn't use any runners and didn't have to make any cuts to get the filter on. but my filter does hit part of the bike frame up top. little bit of a dent, but no biggie.
Free K&N R-0990 Filter | sjc88 | Free stuff! | 10 | October 17th, 2014 05:20 PM |
Free: K&n 0990 pods | Trailerboy531 | Free stuff! | 10 | September 11th, 2013 01:45 PM |
BRAND NEW K&N R-0990 Air Filter | SMman | Motorcycle-related | 4 | January 29th, 2013 06:58 PM |
K&n 0990 filter on fi ninja | psych0hans | 2008 - 2012 Ninja 250R Tech Talk | 14 | April 19th, 2012 04:25 PM |
k&n 0990, major improvement ? | tac12345 | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 22nd, 2011 05:17 PM |
