Old August 15th, 2012, 01:05 AM   #1
waffles666
Motorcycle(s): Ninja 250R 2011
Ninja 250 stalling on hard breaking
Hi Guys, I have been having trouble with my bike recently it is a 2011 ninja 250 and has done about 7000KM.
In the last couple of weeks when I break hard the engine will cut out, it will do this when the tank is full or empty and if the choke is on or not. It appears to happen more frequently when the bike has been ridden for less than 10 min.
I don't have an experience fixing bikes but have always been willing to pull things apart and learn, anyone have a clue as to what could be going on?
waffles666 is offline   Reply With Quote
Old August 15th, 2012, 01:27 AM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Oil?
AFM #676
Supersports are for n00bs
Old August 15th, 2012, 01:44 AM   #3
fatestkid
fatestkid's Avatar
Motorcycle(s): ninja 250
Does it idle fine when in neutral?
Posted via Mobile Device
fatestkid is offline   Reply With Quote
Old August 15th, 2012, 01:48 AM   #4
waffles666
I just had a quick look, it's all full and was changed 1K ago at the 6K service.
Old August 15th, 2012, 01:57 AM   #5
waffles666
It's a little bit "lumpy" but always has been this way, tried setting idle speed from 1,500-1,750 with no love.
Old August 15th, 2012, 06:18 AM   #6
waffles666
Odd got an email with a post but no post appeared on the forum...
From DaBlue1
---Quote (Originally by waffles666)---
---End Quote---
A lumpy idle @ 1500-1700 is an indication that there's either a fuel or air problem. After the bike is warmed properly does it run OK or does it still cut out?
Do you blip the throttle to keep the engine from cutting off until it's properly warmed/ridden for more than 10 minutes?
Do you pull in the clutch early or late under heavy breaking? Why all the heavy braking?
Is your air filter clean or snorkel blocked?
Any mods to the carbs?
After some more testing tonight the problem seems to go away after 15+ min of riding, blipping the throttle doesn't stop the bike cutting out, clutch is always all the way in (early) before I break hard. The heavy breaking is because my morning commute is down a road with free flowing but heavy traffic and it's very common to get cut off, and I'm not talking emergency breaking just heavier than normal. I don't have any mods, how do I check if the snorkel is blocked? Where is it?
Old August 15th, 2012, 06:27 AM   #7
azimmer11
azimmer11's Avatar
You need to disengage the clutch when you come to a stop.
azimmer11 is offline   Reply With Quote
Old August 15th, 2012, 07:07 AM   #8
dubojr1
dubojr1's Avatar
So light braking is fine?
Pull the air filter and verify the airbox is empty/clean. Check the filter while your there. Reference the photo's here for snorkel location and air filter removal.
http://www.ninjette.org/forums/showthread.php?t=10090
Old August 15th, 2012, 07:14 AM   #9
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
What part of the bike are you "breaking" when the engine stops?
Old August 15th, 2012, 09:22 AM   #10
DaBlue1
DaBlue1's Avatar
Set your idle speed to 1500 after the bike is fully warmed. With the choke fully on, the idle speed should increase close to 3k while warming up.
Old August 15th, 2012, 08:01 PM   #11
waffles666
I'm using the front break and a little of the rear.
Just pulled it out and the airbox and snorkel are both empty and the filter looks near new, probably replaced at last service. I assume the clear oil the filter is covered with is normal?
Idle speed is bang on what you are describing. I returned it to these settings a couple of days ago because I normally run it at about a 1,750 idle is this bad for the motor?
Old August 15th, 2012, 08:05 PM   #12
lgk
is it hard to push the bike with the clutch pulled, and in 1st gear.
if so you might need to adjust the clutch cable.
Old August 15th, 2012, 08:54 PM   #13
waffles666
I think you might be on to something the bike is definitely harder to roll when in first than in neutral. I have tried adjusting at the clutch lever but no matter how short or long I make that screw it's definitely still dragging, tried down near the clutch also and now I like the way the clutch is setup but still same issue.
The other thing I have noticed is after it stalls the engine is hard to start and sounds like it has been flooded...
Old August 16th, 2012, 04:44 AM   #14
dubojr1
dubojr1's Avatar
Has this bike set up for any time period? It's starting to sound like a dirty carb. issue.
Ninja 250 bogging/stalling issue avp957 2008 - 2012 Ninja 250R Tech Talk 11 June 23rd, 2014 11:45 AM
1993 ninja 250 front end dive when breaking tdog7812 1986 - 2007 Ninja 250R Tech Talk 2 December 21st, 2012 11:24 PM
Ninja 250 stalling Image5050 2008 - 2012 Ninja 250R Tech Talk 11 July 16th, 2012 04:12 PM
ninja 250 stalling at stop signs bikerchick Riding Skills 15 June 25th, 2012 09:52 AM
2009 250 ninja stalling after startup and when trying to pick up from a stop tungzta 2008 - 2012 Ninja 250R Tech Talk 10 November 26th, 2010 01:41 PM
