Old September 11th, 2012, 07:07 AM   #1
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
another Rabies build.
il post here to all the changes and upgrades. iv ordered lots of things.
iv searched long and hard for "how to" instructions for the things i was going to do...looks like il be the one making a how to.
got the bike last month
last owner busted all the fairings and had 3yr wiring job done on it.
took the fairings off (blasphemy, i know.....
conned my buddy into buying a pregen as well. he will get all my parts i take off
i took the cover off the seat and chopped some foam out. looked like junk when i was done. so i taped the whole seat. seat had rips anyways.
relocated the plate temproaryliyyoy i dont have a chain guard to mount to
i gutted the under plastics since the rear of the frame and seat will be chopped. and i used a spring for now for the seat from lowes
used a piece of angle iron to move the taillight back since i ditched the rear grab bar
i have clip ons/mirrors/ turn signals/helmet/rear stand 08 wheel and swing arm coming in mail along with a small digital guage setup(which there will be a write up since i havent found any)
il be replacing the large front sprocket with the smaller stock one i have.
full muzzy exhaust, air pods, and a jet kit from a local shop. then il crash it hard and get another bike(happnes 99% of the time....)
The King
rabies is offline   Reply With Quote
Old September 11th, 2012, 06:07 PM   #2
Monkeytofu
I told you bro
Monkeytofu's Avatar
Sub'd always love to see these tranformations. Reupholstering your seat isn't too hard, I can scrounge up some links if you're going to do it.
Edit: Also, bigger pictures, I can't see anything!
Old September 11th, 2012, 07:54 PM   #3
rabies
rabies's Avatar
i already tried to de-pad the seat n rewrapped it. i thnk il make a cafe seat or jus rip all the cusion off the seat. friday the welder n cutting stuff will get taken out..
i use photobucket. not sure how to get biigre pictars
The King
Old September 11th, 2012, 11:48 PM   #4
Monkeytofu
I told you bro
Monkeytofu's Avatar
IMO http://imgur.com/ is far more superior than Photobucket.
You'll want to post direct images if they're not too big.
Old September 14th, 2012, 05:45 AM   #5
rabies
rabies's Avatar
i put the stock sprocket onto the bike. po had a larger highway friendly front sprocket on
and this is my buddy...
The King
Old September 17th, 2012, 07:03 AM   #6
rabies
rabies's Avatar
moved the coolant tank up
new brace before cutting frame
new seat alignment and shorter base needs a new seat.
cut it in half.
installed mirrors
installed pods
next is finish fiberglassing seating. install jet kit and exhaust.
finish sanding gas tank for repaint....flat green..
but while wiggling off the fairing tabs...this tab made a hole. easy fix
bike needs rewired.
i leave you with this disaster looking pic
The King
Old September 17th, 2012, 12:15 PM   #7
It's coming along. Interesting build so far.
Just curious here, any reason you went with individual pods instead of a single K&N R-0990 with two holes? I went with the R-0990 because it was reasonably priced on Amazon, and it looks cool imho
exhibit A:
Old September 17th, 2012, 07:11 PM   #8
rabies
rabies's Avatar
cuz the pods were $5 each WOOOOT
The King
Old September 17th, 2012, 08:13 PM   #9
Oh! Well in that case, carry on!
Old September 19th, 2012, 06:53 AM   #10
rabies
rabies's Avatar
got vortex dog bones on. a tad longer then stock and cleaner
sanded the junk tank
paint junk tank
...and matching helmet
The King
Old September 19th, 2012, 10:57 AM   #11
longer dogbones? eewwww. That lowers the rear.
Old September 19th, 2012, 10:59 AM   #12
rabies
rabies's Avatar
i know but the front will be lowered too
The King
Old September 26th, 2012, 08:28 PM   #13
rabies
rabies's Avatar
Update
Got thedlight painted n put on
cut the fender down alittle and painted it
And this came....
with ex500 spring n dogbones its bottomed out..theres no bounce at all.. o.O HMM
as it sits. still workn on the seat
The King
Old September 26th, 2012, 08:42 PM   #14
I knew you had something planned with this bike. Looking good so far.
Are you planning on doing the front end suspension conversion as well?
Old September 26th, 2012, 10:44 PM   #15
Eagle981
Motorcycle(s): 2007 Ninja 250R
Hey rabies,
Build is looking good. Diggin the OD green. Rockin a military theme?
What headlight is that? Any chance you could pm me a picture of it from riding position?
Eagle981 is offline   Reply With Quote
Old September 26th, 2012, 11:11 PM   #16
Monkeytofu
I told you bro
Monkeytofu's Avatar
Please put some kind of gas resistant clear coat on it. Wouldn't want to see a paint job ruined
Old September 27th, 2012, 10:10 AM   #17
rabies
rabies's Avatar
i would like to get either ex500 springs or some new inverted forks. wel see
ya flat green is the only thing i can do. surely not yellow lol.
the light is a universal dirtbike like. brand is Acerbis. got it for $20 on ebay used. new is $20 but you gotta wait for it to come from china.
i can get a pic later today. i have to put on the new coolant reservoir.
The King
Old September 27th, 2012, 06:21 PM   #18
rabies
rabies's Avatar
Led turn signals never workd :/
with flash
without flash. painted the back of it. hardly noticed. not that ugly
The King
Old September 27th, 2012, 09:56 PM   #19
Monkeytofu
I told you bro
Monkeytofu's Avatar
Just run the turn signals without resistors. They'll probably just run fast and while its technically against the law no one will say anything or do anything about it.
Old September 27th, 2012, 09:59 PM   #20
Question time: what's the bottle?
Old September 28th, 2012, 05:53 AM   #21
rabies
rabies's Avatar
i tried the turn signals without the resister. same thing. they didnt work.
the bottle is the coolant reservoir
The King
Old September 28th, 2012, 02:05 PM   #22
Eagle981
How are you planning on covering the tops of your forks?
Old September 28th, 2012, 07:00 PM   #23
rabies
rabies's Avatar
i dont plan on it. why?
The King
Old September 28th, 2012, 11:55 PM   #24
Eagle981
Just confirming: there are clip-on's on your bike, correct?
And wouldn't leaving the tops of the forks exposed cause problems down the road?
Old September 29th, 2012, 06:52 AM   #25
rabies
rabies's Avatar
not that i know off. forks will b switched out soon for inverted forks
The King
Old September 29th, 2012, 03:09 PM   #26
vanman69
Motorcycle(s): zzr250 gt650r zxr250 ninja 300
what kind do you plan on using?
vanman69 is offline   Reply With Quote
Old September 30th, 2012, 06:56 AM   #27
rabies
rabies's Avatar
forks? gsxr600. they r inverted n a cool gold color. but are 50mm up top so dif trees n stuff hav to be used. some researing to do of course is what il hav to do.
got the jet kit in. used the larger jets. adjusted the mixture n it idles n runs now.
i threw away the kickstand sensor so it would die aftr trying to drive off. realized becuase it was unplugged. so i jus connected the 2 ends together n ditched the sensor.
i jus hav to get the seat done n tuck some wires n its done
The King
Old October 6th, 2012, 03:42 PM   #28
rabies
rabies's Avatar
got the seat done.
put a smaller bottle on the bike. right side. up higher
is this too much preload on an ex500 spring?
made a liscense plate chain guard bracket thingy
ghetto but it works
had cut a passenger bracket awhile ago that was ugly.
i used one of the newgen dog bones to make a new bracket.
put it in a vice and hammerd it
boss
The King
Old October 6th, 2012, 03:49 PM   #29
rabies
rabies's Avatar
made an adjustable kickstand since i cut it short and ended up raising the bike way up
made a mess of wiring piddling with things
was trying to tuck wires and make it cleaner
i bolted the fusebox to the battery box along with the voltage regulator and relay
curious to see the inside of teh fuse box
rear brake fluid reservoir delete kit mod thingy from curvygril.com 8mm hose. but i had to heat it up and expand the ends. it was kinda small
then i did this...
The King
Last futzed with by rabies; October 6th, 2012 at 08:02 PM.
Old October 6th, 2012, 03:50 PM   #30
Radiator shrouds in the making?
Old October 6th, 2012, 03:55 PM   #31
rabies
rabies's Avatar
^yuuuup
i finished them and painted them already. my back is killing me so i came inside to lay down on ice. later il take pics of them on. looks pretty rad like an 80s mad max bike
The King
Old October 6th, 2012, 08:03 PM   #32
rabies
rabies's Avatar
my B52 wings
The King
Old October 6th, 2012, 08:15 PM   #33
Coolbpf
Limp Noodle
Coolbpf's Avatar
Motorcycle(s): 2006 Ninja 250, Fastest Red money can buy
This bike... Is awesome.
Coolbpf is offline   Reply With Quote
Old October 6th, 2012, 09:43 PM   #34
Monkeytofu
I told you bro
Monkeytofu's Avatar
I have one glaring issue with this thread: The pictures are too damn small
The bike looks great so far and your skill shows, but please give us bigger pictures of your bike at some point.
Old October 7th, 2012, 05:40 PM   #35
cerberusrex25
Accesories Guru
cerberusrex25's Avatar
Motorcycle(s): '99 EX250(Cafe/fighter project)
Are you going to modify the belly pan? It would be awesome if you did. I love what you've done so far, amazing job.
cerberusrex25 is offline   Reply With Quote
Old October 7th, 2012, 08:12 PM   #36
rabies
rabies's Avatar
thanx fellas. i might do a belly pan. i still have the stock one.
im registering on imgur.com right now for better bigger pics. i can barely see them too lol
The King
Old October 7th, 2012, 08:15 PM   #37
rabies
rabies's Avatar
imgur test
http://imgur.com/rP8xn
The King
Old October 7th, 2012, 09:03 PM   #38
yay full size pictures!
How loud is that puppy?
Old October 7th, 2012, 09:19 PM   #39
rabies
rabies's Avatar
purrdy loud. its a oversized piping with straight through muffler. sounds good but loiud. almost like a dirtbike though until you are really into it
The King
Old October 7th, 2012, 10:34 PM   #40
Eagle981
Is your seat cover scrap from old ACUs?
Dyno build swarfman64 Off-Topic 32 January 2nd, 2016 04:19 AM
Guevara - reaubideux - rabies - blackninja8 Panda Buyer/Seller Feedback: Good 0 January 29th, 2013 09:45 AM
90 build up justin_ninja 1986 - 2007 Ninja 250R Tech Talk 4 January 12th, 2013 03:53 PM
2009 SE Build Betlog Pictures 8 July 21st, 2010 09:59 PM
