Old April 24th, 2021, 09:48 PM   #1
Motas
Motorcycle(s): Ninja 300 ABS
Unhappy Bad Coil connector?
Hi everyone, hoping to get some advice on what to do next. I'll recap my issue from the begin, this is from my Reddit post last month:
Bike has 35,000km/21,000miles
I've been riding for about 40 minutes on the high way around 9k rpm before i feel a sudden loss of power where keeping over 90kmh/55mph it struggled.
I noticed it had a deeper exhaust tone and idled lower. In neutral any revs and it was on the crisp of stalling when the idles came back down.
Around 4-6k rpm it would stutter badly, complete loss of power and i would need to shift into at-least 6th gear to go 50kmh/32mph.
Any throttle more than 25% and it stutter and accelerates slow. 6th gear is the best where it would only stutter 4-6k rpm and then be fine unless more than 25% throttle is applied.
Here's what I think it could be:
Bad Gas
Running on single cylinder/cylinder misfire
Bad clutch
Over heating causing limp mode?
I'm thinking it's likely to be a cylinder misfire based on the symptoms and am hoping to hear where I should start? I think spark plugs would be the easiest?
In short, the bike feels like it's in limp mode.
Later I took it out to the gas station and it rode fine on 2 cylinders for the first ~7 minutes. After the bike warmed up was when it the cylinder misfired and the same symptoms started. This confirmed to my that it's likely the coils.
Since then my buddy and I swapped out the stick coils and spark plugs with replacements. First thing we did was test the new coils outside of the engine grounded against it to see if there's spark. There was on both cylinders. One of the old spark plugs was black and burnt so I was further convinced we've resolved the issue. With the new plugs in and new coils inserted in, we cracked the bike and it ran fine for about 30 seconds before the idle became rough again and the engine light was thrown (couldn't get a code out of it this time, I turned it off then key to the on position-- ODO B and held down the left button and no code pops up) and the right header was cold.
Where i'm at now is we tested the coil spark plug and coil grounded against the engine. There's spark from the left cylinder, not from the right. Could this be a wiring issue? What would be my next steps to trouble shoot the wiring and where does it even run to? Are there any other parts in between that I can try to troubleshoot or replace?
Would really appreciate suggestions. All I can really think to do is take apart the bike and follow the wiring for the right coil connector with a volt meter to see why there's no power but want to make sure i'm on the right track.
Motas is offline   Reply With Quote
Old April 24th, 2021, 09:50 PM   #2
Motas
Bad Coil connector??
Bad Gas
Bad clutch
Bad Coil connector?? Motas 2013 - 2017 Ninja 300 Tech Talk 0 April 24th, 2021 09:50 PM
Kawasaki ZX Ignition Coil Pack/ coil over plugs (CoPs) modification. Ghostt 1986 - 2007 Ninja 250R Tech Talk 44 June 10th, 2019 03:48 PM
Bad driver & bad rider. Guess who gets hurt... akima Videos 27 July 12th, 2013 12:26 AM
Lane splitting.... bad bad bad oblivion007 Videos 29 May 8th, 2012 11:42 AM
Left Turn Signal - Bad Connector g21-30 2008 - 2012 Ninja 250R Tech Talk 6 December 31st, 2008 12:32 PM
