Old June 7th, 2011, 06:30 PM   #1
!@#$!ing bar ends! Torch, impact screwdriver, breaker bar, etc ALL failed. :(
!@$#!ing barends, man.
I bought a pencil torch a while back (probably a year ago) with the intention of using it to install new bar ends. I bought new bar ends sometime last year and never got around to install them until recently. I bought new grips last month and finally decided it was time to take a crack at it.
First of all, the pencil torch WOULD NOT LIGHT with a match. It would blow the match right out! The wind was doing a good job of that at first so I finally decided to go inside and light it there before taking the lit torch outside to the bike, but the torch blew right out as soon as I stepped outside. Grrr... I eventually had to borrow someone's lighter and sit there lighting and relighting it on the bike. I couldn't get it to stay lit unless I ran the person's lighter empty. Eventually, there was one big "poof" of fire and the pencil torch quit working: No butane flowing at all even when attempting a refill and no way to tell if it was still holding any. I swapped it out for another one at Harbor Freight and it did the exact same thing: TWO broken pencil torches in a day!
I tried to take it off using this T-handle thing with a socket and #3 Phillips bit. I knew that it may not have gotten hot enough but I figured that as long as I stopped before it slipped, I'd be fine. It gave me plenty of leverage to ensure that it was not slipping, but it cracked the metal between each fin of the bit. I stopped and bought the micro torch at Harbor Freight instead along with a impact screwdriver set. At least this torch had a built-in lighter and it was capable of staying on in a light breeze. Using it without the impact screwdriver, I got the opposite bar end off just fine with the original T-handle tool and I found a bit included with the impact screwdriver that fit a million times better. Unfortunately, it no longer fit the cracked bolt on the other side (impact screwdriver was useless) and I ended up having to pay someone $37 to remove it.
I came into this knowing what I would need and thinking I was completely prepared and yet I still ended up having to get this taken care of by a professional for way too much money.
Now, to make things worse, my new bar ends do NOT fit! The auction said that they fit "Ninja 250R" and yet they are the kind that expand inside a hollow bar instead of the kind that thread right in to a bolt hole. The hole machined through it is too small to fit the proper sized bolt, so I can't simply buy the right sized bolt. Weren't the pre-gen bar-ends the same way?
At least I finally got my new grips installed but now I have no bar-ends. Looks like I'm going to be getting clip-ons sooner rather than later. I only hope I don't fail nearly as hard as I did at this!
Last futzed with by CZroe; June 9th, 2011 at 02:27 AM.
Old June 7th, 2011, 06:53 PM   #2
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
D*** man you are scaring me. I was going to be doing my grips and clip-ons next weekend. I was just going to use a lighter guess that won't be enough.
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old June 7th, 2011, 07:03 PM   #3
Momaru
Momaru's Avatar
Sadly, no, a standard lighter won't cut it. I used ~30 sec of focused blue flame from my propane-bottle torch to get it sufficiently hot to loosen the red loctite they use at the factory.
Czroe, about those HF pencil torches. As you've discovered, they're crap. I was given one by my father several years ago and it literally exploded in my toolbox on a hot day. Thankfully there was no spark, so it was just pieces of the torch all over the inside of the box. My dad then gave me his which he'd bought at the same time and never used. I filled it, lit it with a laboratory magnesium cup-striker and used it for about 3 minutes before one of the seals gave out and it went the way of the first one. Frankly, the only thing I even sorta trust from HF are solid pieces of metal like breaker bars or impact wrench bits.
Proud member of the Blue Army
Old June 7th, 2011, 07:05 PM   #4
bob706
bob706's Avatar
I bought one of those cheap torches at walmart that worked great. It's the kind that uses a lighter inside.
Old June 7th, 2011, 07:14 PM   #5
00NissanNinja
I hate driving...
Great more money wasted on tools that I won't use that much
Old June 7th, 2011, 07:33 PM   #6
Mad-B-Man
Motorcycle(s): 07 EX250F, Honda NCZ50 Motocompo
I don't know how different the bar ends are, but i just drilled them out on my pregen. simple as pie. you can torch the locktite directly afterwards, though i just left them since i put on lowered risers.
Mad-B-Man is offline   Reply With Quote
Old June 7th, 2011, 08:43 PM   #7
Things would've been fine if I had bought the $8 torch in the first place.
I've seen some people do it without heat using an impact screwdriver but by the time I bought one for a few bucks it was too late.
I don't even have a drill and I'm pretty wary of buying that $12 cordless one from Harbor Freight!
Old June 7th, 2011, 11:07 PM   #8
Domagoj
Saw them off.
You are not going to use them later, are you?
Old June 8th, 2011, 12:03 AM   #9
Originally Posted by Domagoj View Post
Saw them off.
I don't have a saw either. That said, I intended to replace them with new bar-ends so I didn't want pieces stuck inside (just how would I get rid of the stuck bolt once the head was sawed off?). Now I wonder if I can saw off the threaded piece blocking either end so I can install these bar-end intended for hollow bars.
Old June 8th, 2011, 01:45 AM   #10
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
i attacked mine right away with an impact screwdriver, without heating either side up, and managed to get them both off. i had to get my GF to hold the handlebars steady since i hammered away at it like a mofo... after working up a sweat and a rather numb hand from the hammer blows i managed to pry them off, haha...
i did it after my accident, which caused my right handlebar to bend. so i replaced them with KTC clipons.
the clipons have hollow ends, onto which i put the KTC bar end weights like you discribed, with the rubber inserts that expands after putting it into the hole, hmmm... some strong sexual similarities in that action there.
you went thought one hell of an ordeal to only find that you need to put the OEM bar end weights back on!
or you need to buy clipons, OR drill that hole out bigger, so again i think you need to give it to someone with a proper bench press drill or something, so you dont ruin the new bar end weights.
GL!
ps, or give the handlebars (after youve removed them from the bike and taken everything off) to a "specialist" and have them drill or lathe out the end part and the bolt that is in there. that is if just sawing it doesnt do the job in the 1st place...
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
wayanlam is offline   Reply With Quote
Old June 8th, 2011, 05:13 AM   #11
GL!
Yes, that statement sounds full of innuendo. The ones I have use expanding metal sleeves though (sleeves are slotted and the bolt pulls a cone-shaped nut into them causing them to flare). I can't put the bar-ends back on because I only have one left after the guy at the shop removed the other (he must've destroyed it).
Old June 8th, 2011, 06:12 AM   #12
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Propane torch, or better yet, MAPP gas torch, applied for 10 seconds more or less, on the head of the screw, that will generally soften the locktight enough to get the screw out. Once the screw is junked the options that leave a good bar end diminish significantly. If you're not worried about saving the bar end, use a 4" cutoff wheel like are often on sale at Harbor Freight for $10-15 to grind out the end of the bar end screw head. Just start making edge-wise cuts into the face of the screw. Once the screw head is gone the bar end will fall off, and you'll have the stump of the screw left sticking out the end of the bar. Hit that with the propane or MAPP torch until you see the locktite bubbling, then grab the stump with vice grips and unscrew it.
Old June 8th, 2011, 06:54 AM   #13
I was using butane torches. It would've worked great if the two butane pencil torches didn't fail to light, stay lit, or ever work again (they both completely died after a few attempts to get them to stay lit). The butane micro torch I bought after those worked fine on the remaining bar end but it was too late for the first. I don't have any kind of electrical outlet anywhere near the bike (apartment parking lot) so I can't work with powered tools unless they run on batteries. I considered Harbor Freight's 12v impact wrench but it was too expensive for something I'd likely use only once (you connect it to the vehicle's battery like jumper cables). Anyway, what you describe is exactly what they did do my bar end at the shop I took it to. It took them about 5 minutes but I had to pay 1/2 an hour of labor ($37.50). I should've retreived my grips from home and had them install those too if I was paying for that much labor!
Old June 8th, 2011, 08:06 AM   #14
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
It's not that difficult guys. No cutting, no sawing, nothing...just simply heat and twist.
All you need is the following:
Old June 8th, 2011, 08:14 AM   #15
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
I'm confused as to what happened. You paid someone to remove the bar end, but they left the screw inside? To get rid of a bolt with the head missing, you would need a drill and a bolt remover. They work well, but not having a drill will make things difficult. When I went down, I used a #3 bit that I hammered into the screw and tried to remove it. It didn't work all that well. I ended up using vise grips on the bar end itself. I got it to turn loose, which also worked the screw loose enough for me to take it out.
How big of a hole do you need in the aftermarket bar ends? If you want, you can send them to me and I'll drill them for you. Just pay the return shipping.
The www.ModMy250.com guy
Old June 8th, 2011, 09:20 AM   #16
ricochet08
ricochet08's Avatar
Motorcycle(s): 2007 ninja ex500, 2010 Ninja 250r, 2004 zzr600, 2003 CBR600rr, 2013 Ninja 300...in that order :D
i still need to replace my handle bar, couldn't get that damn screw off to save my life.
then again, i didn't have a torch :P
ricochet08 is offline   Reply With Quote
Old June 8th, 2011, 12:41 PM   #17
blink
Always.
blink's Avatar
Motorcycle(s): '08 Ninja 250, '05 GSX-R600
may I suggest axe body spray and a lighter? =p
just kidding! goodluck tho!
blink is offline   Reply With Quote
Old June 8th, 2011, 01:40 PM   #18
Havok
Internet Slut
Havok's Avatar
Motorcycle(s): 04 FZ1, 07 FZ6
#3 bit and ratchet driver took mine off easy as pie not sure if i got lucky or not. Some seem harder then others it looks like.
Havok is offline   Reply With Quote
Old June 8th, 2011, 01:44 PM   #19
austexjg
austexjg's Avatar
Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r
I ruined the left side screw before I thought about loctite - still have not solved the problem, but I do have the replacement screw if I ever get around to fixing it.
austexjg is offline   Reply With Quote
Old June 8th, 2011, 01:52 PM   #20
Penguin250
Penguin250's Avatar
Motorcycle(s): 2011 White Ninja 250R, 2010 Galaxy Blue Colorshift Ninja 250R
Yea, I guess I got lucky like Jeff. Was going the torch it route, but was using a heat gun rather than a torch and figured I may melt the rubber on the grips with it so I stopped. Grabbed a 12" socket driver with 1/4" bit to hold a #3 philips head bit and a rubber mallet. Used one hand to hold the bit in the screw and beat the hell out of the end of the driver with the mallet until I heard a loud crack and then just unscrewed the screw. Same with the other side.
Penguin250 is offline   Reply With Quote
Old June 9th, 2011, 02:28 AM   #21
My whole point was that I KNEW that and prepared yet failed anyway.
No, they removed them completely. It was a hypothetical situation as if I had sawed it off myself. Thanks for the offer on adapting the bar ends, but I have my eye on some clip-ons that will likely make that unecessary soon (we'll see).
You see the T-handle thing I was using? WAAAY more torque than a ratchet!
Old June 9th, 2011, 04:29 AM   #22
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
30 seconds? I torched mine with a propane torch for about 2 minutes a piece and then used a screwdriver to twist them out.
Old July 22nd, 2011, 12:10 PM   #23
Shaol1n Monk
shaol1n ninja stuntman
Shaol1n Monk's Avatar
Motorcycle(s): 2006 Yamaha YZF R6 Anniversary "Yoshiko" 2007 Honda CBR600RR "Katsumi"(SOLD) 2010 Ninja ZX-2R "JADE" (RIP)
i used a pencil torch, heated for a couple minutes, banged the screw w a screwdriver and hammer a few times and tried unscrewing and they wouldnt budge. i dont have a phillips head socket for my wrenches so instead i gripped the screwdriver with a pair of pliers for torque and the screw started moving on the first twist. it came out pretty easy after that.
YOSHIKO 06 R6 Flushmount signals,Comp Werkes fender elim,GYTR Carbon Fiber Exhaust,Gold Shorty Levers,Shogun Frame Sliders,custom carbon fiber tank pad,white powder coated wheels,Dunlop Q2 tires
Shaol1n Monk is offline   Reply With Quote
Old July 22nd, 2011, 12:32 PM   #24
Was it the Harbor Freight one that would not stay lit for me?
Old July 22nd, 2011, 02:38 PM   #25
DarC
DUCEATR
DarC's Avatar
Motorcycle(s): RVT1000R
I just used a Berzomatic pencil torch and a screwdriver...
2001 SP1 RC51- #62 -Akrapovic Ti, PCIII, Colin Edward's first baby tooth, Honda Racing sticker, some Japanese doods best attempt at Engrish scribbled on my engine block, little touch of soul.
DarC is offline   Reply With Quote
Old July 22nd, 2011, 02:54 PM   #26
I failed at that too...
When I was installing my lowered risers, I ran into the same problem you did, even using an actual blowtorch. I just ended up using a 1/4 inch bit and drilling the heads off the bolts. much less frustrating. Kkim's got a DIY on here for installing the bar ends into the WC bars, so I might do that to get rid of the vibrations. If you're doing clipons, I'd just suggest skipping that whole heating step and drilling the heads off
Old July 22nd, 2011, 03:12 PM   #27
Shaol1n Monk
i used a bernzomatic pencil torch also, it was $10 at home depot
Old July 23rd, 2011, 03:17 PM   #28
BlueEx2
I actually took mine off yesterday, bought a butane torch at harbor freight for $7 and and impact screwdriver for $5. Heated up the screw, used #3 phillip and smack and twist a few times and it came right off. Without heat the screw didn't move at all. Gotta love harbor freight
BlueEx2 is offline   Reply With Quote
Old July 23rd, 2011, 06:50 PM   #29
Love AND hate. The orange or black one work fine. The pencil torch was total fail and cause the problem in my original post.
Where did you buy your butane?
Old July 23rd, 2011, 08:48 PM   #30
00NissanNinja
I hate driving...
I bought this:
http://www.bernzomatic.com/PRODUCTS/...3/Default.aspx
Plus butane fuel:
At Home Depot. Worked great for getting the bar ends of just had to wrench the ends a bit to get the screws started.
Old July 23rd, 2011, 09:09 PM   #31
Shaol1n Monk
I bought this:
Plus butane fuel:
same torch i used, worked great
Old July 24th, 2011, 05:16 AM   #32
BlueEx2
Yeah I got the orange one and got my butane at advance auto.
Old July 24th, 2011, 08:31 AM   #33
JoeLansing
JoeLansing's Avatar
Motorcycle(s): Green 2011 SE 52yo Geezer
I got this big beasty impact driver for $8 at Harbor Freight:
This impact wrench was $39 with coupon. No compressor needed.
- Joe
JoeLansing is offline   Reply With Quote
Old July 24th, 2011, 08:55 AM   #34
nickadolph
Motorcycle(s): ninja 250
I took a deep socket that would fit over the butt end of my screw driver and used a breaker bar. Easy peazy lemon squeezy.
nickadolph is offline   Reply With Quote
Old July 24th, 2011, 09:35 AM   #35
I did not have a leverage problem. The bolt heads were simply not capable of conducting the amount of torque required without simply tearing up. Perhaps mine had more Loctite. *shrug* I'm just saying that it isn't going to work for everyone.
Old July 24th, 2011, 04:02 PM   #36
Buffalony
Buffalony's Avatar
Great cheap electric drill.
http://www.harborfreight.com/power-t...rill-3670.html
I used a electric heat gun from harbor freight to get my ends off. they're only 10-12 bucks and worked perfect. better than screwing around with those dinky mini torches. used the heat gun to put on my headlight protector and removed some wall paper with it too
Old July 24th, 2011, 04:14 PM   #37
I have that too but I have no way to power it anywhere near my motorcycle (no garage; apartment parking lot). Mini torch was $2 and no one ever said that a heat gun was hot enough, so it seemed like the obvious solution. Also, did you have the accessory kit with the attachments or did you melt your grips and such?
Old July 24th, 2011, 04:28 PM   #38
Suave
Suave's Avatar
I was googling a solution to this problem and this is its answer, http://www.youtube.com/watch?v=z34JYwNGFtw ... idk if it is gonna work
"Hey man, I'm not tryin' to start nothin'. But... i wouldn't take that"
Suave is offline   Reply With Quote
Old July 24th, 2011, 04:30 PM   #39
leed
leed's Avatar
Motorcycle(s): Time will tell
I used a portable electric impact screwdriver (a DeWalt to be specific) along side a PH3 and they came out like butter.
Old July 24th, 2011, 04:37 PM   #40
Buffalony
Buffalony's Avatar
The heat gun has a switch that allows you to set it at two different temps. the sucker gets pretty hot.http://www.harborfreight.com/power-t...112-96289.html
No attachments came with this one. they werent needed though. It didnt damage my grips at all. Instead of aiming inline with the bar I aimed it 90 degrees to the barend so only the end was grabbing the heat. I used an impact driver as well, but it didnt take much with the heat gun on it.
The parking lot situation kinda sucks. Extension cord? Or maybe a friends house. propane torch was another good idea. if that screw head is too damaged you might have to drill it out. You could get an extractor bit too. If you end up drilling, start with a larger bit to clean up the gnarled up head, then go into the bolt with a smaller bit.
Bar Ends skilletmo 2008 - 2012 Ninja 250R Tech Talk 8 March 8th, 2013 11:17 PM
bar ends skikman 1986 - 2007 Ninja 250R Tech Talk 8 January 7th, 2013 06:15 AM
Bar ends james250ninja 2008 - 2012 Ninja 250R Tech Talk 8 October 22nd, 2011 08:54 PM
ZX-R bar ends Shaol1n Monk 2008 - 2012 Ninja 250R Farkles 14 July 29th, 2011 12:30 PM
bar ends james250ninja 1986 - 2007 Ninja 250R Tech Talk 13 April 22nd, 2010 04:06 AM
