September 5th, 2014, 10:03 PM | #1 |
65MPH Tops 2007 Ex250
Hi, I just purchased an 07 EX250 any for some odd reason Trying to redline as much as I can im unable to get the bike faster than 65MPH (Less than 70 Downhill) Im running full throttle the whole time revving as high as possible before shifting. (We've changed the spark plugs, checked air filter, gas filter..) I've divided a bottle of seafoam into my last two fillups using Premium gas. Mechanics said that we can try putting new jets on, but asking if anyone else has any ideas.. Until 4th Gear maybe third i can redline, after than it drops to 11k Limit Then shifting reaches 9-10k limit then 8k.
September 5th, 2014, 11:33 PM | #2 |
Join Date: Sep 2013 Motorcycle(s): 2006 Ninja 250 Posts: 47
Did you check compression?
September 6th, 2014, 10:11 AM | #3 |
I'm unable to check the compression :/
September 6th, 2014, 02:34 PM | #4 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
Check the throttle cable and throttle mechanism on the side of your carbs. Does your bike have any kind of mods? Mileage and how long has been since a valve adjustment?
September 6th, 2014, 05:56 PM | #5 |
Welcome, Tracy !!!
The brakes are dragging, your chain is bad or the torque that your engine develops is lower than normal. Please, change you mechanic, don't change any jets and read this: https://www.ninjette.org/forums/showthread.php?t=194109
September 6th, 2014, 05:58 PM | #6 |
Brakes, yea that is possibility. I got a 10 spot that it is something simple like that.
September 7th, 2014, 07:27 AM | #7 |
Are both pipes the same temp? What do the plugs look like?
Any chance there's something under the seat blocking the air to the snorkel? Does it need choke to start? Drain the floatbowls and look at the fuel that comes out. Is the tank rust-free? Run Regular (87) gas without ethanol. Only use Premium if you can't get anything lower without ethanol. |
September 7th, 2014, 11:41 AM | #8 |
sammich maker
MOTM - Apr '15
Just an FYI, our bikes do better on the recommended octane. My likes 89 (recommended) more than 92 or 93.
I would also check the gearing. Some people play with sprocket sizes to fit their needs. It won't make a huge difference but it will make some. Start with the small stuff. |
Motorcyclist hits deer at 65mph, gets finger scratched | Desmoluci | Videos | 20 | November 7th, 2014 02:05 PM |
First try on a 65mph highway | AmyF | Ride Reports | 6 | July 13th, 2014 12:01 PM |
parting 2007 ex250 | kycycles | Motorcycle-related | 26 | June 29th, 2013 07:25 AM |
Traveling 65mph, what is your rpm? | venmichaels | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 4th, 2011 04:28 AM |
Best way to get to 65mph really fast? | Soujyu | Riding Skills | 51 | May 21st, 2010 06:47 PM |
