Old November 6th, 2016, 02:54 PM   #1
acook3323
Motorcycle(s): 2005 ninja 250
One cylinder not firing
Hey guys I have a 2005 ninja 250 the California model with 6600 miles on it. I'm struggling getting the bike started. It has new plugs that have spark,timing has been checked and is good, cleaned carbs, and replaced battery, seems to have good compression from both cylinders. When I unplug the boot from the left side plug it starts and idles rough but I have no throttle response at all. When both plug boots are on it struggles to start up and seems to backfire. Has anyone had this issue or have any advice? Thanks
acook3323 is offline   Reply With Quote
Old November 6th, 2016, 05:01 PM   #2
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Just for fun, try switching the plug wires.
Welome to the board.
Old November 6th, 2016, 05:24 PM   #3
acook3323
Thanks! Done that same result unfortunately.
Old November 6th, 2016, 05:29 PM   #4
Originally Posted by acook3323 View Post
.......... timing has been checked and is good.........
Welcome, Adam !!!
Do you refer to the timing of the valves?
Old November 6th, 2016, 05:31 PM   #5
acook3323
Pulled cylinder head cover off checked cam timing marks and chain links and everything met spec
Old November 6th, 2016, 05:35 PM   #6
Did you verified the gap of each valve was within specs?
Old November 6th, 2016, 05:39 PM   #7
acook3323
Haven't as I don't really know how to do it because ive never had to do it! Is it simple to do?
Old November 6th, 2016, 05:53 PM   #8
It is something that should be done every 6000 miles.
It is easy if you have a shaded place to work and some basic tools.
This is how to:
http://faq.ninja250.org/wiki/How_do_..._the_valves%3F
http://n4mwd.blogspot.com/2013/06/ov...ts-during.html
Backfiring may be caused, among other things, by some loose electrical connector in the ignition circuit:
http://faq.ninja250.org/wiki/Wiring_...s_%26_diagrams
Having no throttle response at all sounds like broken diaphragms of the carbs or incorrectly installed needles:
http://faq.ninja250.org/wiki/How_do_...n_the_carbs%3F
Old November 6th, 2016, 06:00 PM   #9
acook3323
Thanks for your help. We will see how it goes! Fingers crossed!
Old November 6th, 2016, 06:03 PM   #10
You are welcome
A bonus:
https://www.ninjette.org/forums/showthread.php?t=151139
Those are basic things to check, just to achieve at least combustion inside the chambers: air, fuel, compression and a healthy reliable spark.
Old November 6th, 2016, 06:05 PM   #11
acook3323
So with the now throttle response I pulled the diaphragms out and the spring on that side was bent and kind of screwed up could that be the issue there?
Old November 6th, 2016, 06:11 PM   #12
It could be.
Those diaphragms are activated by the vacuum of the engine and move those tapered needles up and down, which allows more or less fuel into the stream of air being drawn into the cylinders.
This is how the CV (constant velocity) carburetors work:
Cylinder 2 Misfiring / Not firing / Unpredictable juliusmichaelhonrada 1986 - 2007 Ninja 250R Tech Talk 41 July 23rd, 2016 05:42 AM
'10 Ninja 250 Not Firing on One Cylinder... fallerd 2008 - 2012 Ninja 250R Tech Talk 9 October 22nd, 2014 09:51 PM
HELP 03 ex250 left cylinder not firing MistahT 1986 - 2007 Ninja 250R Tech Talk 19 October 22nd, 2013 06:20 PM
back firing rabies 1986 - 2007 Ninja 250R Tech Talk 9 November 23rd, 2012 04:02 PM
