November 3rd, 2015, 08:01 PM | #1 |
gokartmozart
Join Date: Nov 2015 Motorcycle(s): 250 ninja ,it's realy a ninja motor on a scratch built alum chassis (avatar is my old kart) Posts: 22
coast enrichener, among other things
just registered about 1 hour ago , and could not get much info off another kaw forum . hope more knowledgeable people dwell here, my new kart project is a 250 ninja on an alum chassis built for clay oval racing . my question is, the vacuum hoses coming from the carbs ,one supplies vacuum to the fuel petcock ,ok so far . the other supplies the coast enrichener --- do these vacuum taps provide a pulse or a constant vacuum??? reason for asking, a fuel pump is required to overcome centrifugal force affecting fuel delivery,choices are electric or vacuum pulse. I could go either way here , but the simplest looks like the mikuni pulse type . don't want to look stupid but i'm not able to run engine right now to test vacuum, also need to pull carbs for cleaning in the ultrasonic tank
November 3rd, 2015, 08:07 PM | #2 | |
The vacuum signal is always pulsating, in proportion to the rpm's. Each time one of the pistons is in the admission stroke, the vacuum tubes feel a peak.
November 7th, 2015, 11:37 AM | #3 |
Think about it for a second. The vacuum in each carb is made by air flowing through the the venturi section of the carb. The pressure drop (or vacuum, as it's referred to) happens as air flows through a section of necking diameter followed by expansion again. Speed increases in the smaller diameter section, and pressure drops because of that. It's the same theory that allows airplanes to fly.
Now that we know why it's caused, look at how air flows. Every time a valve opens and the piston goes down, air is drawn into the head, through the carbs. So we can assume that the vacuum will be full of pulses, since it's being created by a piston moving air in strokes. If you have a vacuum gauge, you should be able to hook it up and read this, although the pulses will be quick and likely make reading the gauge difficult. The other way you can validate this visually is by syncing your carbs using the two bottle method. http://faq.ninja250.org/wiki/How_do_...-bottle_method Eventually, you'll see pulses of water vapor showing up in the bottles that corresponds to the speed of the engine firing. |
November 7th, 2015, 01:08 PM | #4 | |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
November 7th, 2015, 01:15 PM | #5 |
ChocolateMilk Addict
Join Date: Mar 2015 Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock" Posts: 329
Very true, throw a 250 2smoker in there and that kart might damn well take off into the sky.
< ATGATT > Sweat you can wipe off, Road rash you can't. Burn Rubber, not your Soul. |
November 7th, 2015, 01:19 PM | #6 |
November 7th, 2015, 04:40 PM | #7 |
Again, Very true. I didn't consider classification, my badddd.
November 7th, 2015, 06:19 PM | #8 |
gokartmozart
OPEN/UNLIMITED class
First of all, I don't like 2-smokers much , ever race behind one? ...and they sound funny. Not putting down their HP/weight ,just prefer a 4-stroke
November 29th, 2015, 05:49 PM | #9 | |
Join Date: Aug 2015 Motorcycle(s): 05 Ninja 250, 04 KTM 625 SMC, 01 Xc250 Posts: A lot.
As a die hard two stroke racer since I was a kid, I don't understand what's to not like, and I think four strokes are the ones to sound funny. Rotary and two stroke motors sound cool. |
December 1st, 2015, 05:46 AM | #10 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
Kind of like if a lawnmower and a chainsaw had children.
December 1st, 2015, 06:57 AM | #11 |
To me, a single cylinder four stroke sounds like an old man farting, and a single cylinder two stroke sounds like a high tuned racing machine.
Because Unregistered sucks at riding. |
December 1st, 2015, 03:37 PM | #12 |
gokartmozart
2 smoker ring ding
No debate... some people like fords , some chevys. I'll stick with my 4 strokers , just like the one you're riding now.
Will legalized marijuana remove roadrash scars ? |
December 1st, 2015, 05:00 PM | #13 |
The Ultimate Antique Bike Endurance Event: Coast to coast on 95 years old motorcycles | Motofool | General Motorcycling Discussion | 2 | April 24th, 2013 01:14 PM |
[motorcyclistonline] - Kane Friesen Takes the Vulcan Vaquero Coast-to-Coast | Ninjette Newsbot | Motorcycling News | 0 | October 28th, 2011 02:10 PM |
[topix.net] - Kane Friesen Takes the Vulcan Vaquero Coast-to-Coast | Ninjette Newsbot | Motorcycling News | 0 | October 28th, 2011 02:10 PM |
[topix.net] - High gas prices are boosting sales of scooters coast to coast | Ninjette Newsbot | Motorcycling News | 0 | June 13th, 2011 09:00 PM |
[topix.net] - Coast to coast motorcycle enthusiasts raise money for children's charit | Ninjette Newsbot | Motorcycling News | 0 | May 4th, 2010 06:00 AM |
