December 1st, 2015, 11:30 AM | #1 |
[motorcycle.com] - 2015-2016 Polaris Slingshot Recalled for Headlight Failures
Polaris is recalling 2015-2016 Slingshot models because of a problem with their headlights. The recall affects all versions including the base Slingshot, the Slingshot SL and Slingshot SL LE produced up until late October this year. According to documents released by the National Highway Traffic Safety Administration, the Slingshot’s headlights may cut out while the vehicle is in operation. Initially, the headlights may intermittently flash off and on, but if the problem is not corrected, the headlight circuit may get damaged, completely disabling the headlights. Polaris has identified two problems that combine to create the headlight failure. In high temperatures under the hood, the amperage rating for the headlight circuit may become marginal. As well, the female terminal pin may reach higher than normal temperatures. These two issues can cause the headlight relay to fail, leading to damaged wiring. Headlight issues were first reported to Polaris in July 2015, with more reports coming in during the ensuing months. Polaris initiated an investigation in October which resulted in the decision to conduct a recall. Polaris Slingshot dealers will replace the original relay circuit with a new circuit that uses two relays. Slingshots produced after Oct. 27, 2015, already have the dual-relay circuit installed. The recall campaign affects 9,182 units in the U.S. [Source: NHTSA] 2015-2016 Polaris Slingshot Recalled for Headlight Failures appeared first on Motorcycle.com News. Click here for full story...
[motorcycle-usa.com] - Polaris Issues 2015 Slingshot Recall | Ninjette Newsbot | Motorcycling News | 0 | January 27th, 2015 11:50 PM |
[motorcyclistonline] - Polaris Introduces the Slingshot for 2015 | Ninjette Newsbot | Motorcycling News | 0 | August 5th, 2014 09:10 AM |
[cyclenews.com] - First Look: 2015 Polaris Slingshot | Ninjette Newsbot | Motorcycling News | 0 | July 29th, 2014 08:50 AM |
[motorcycle-usa.com] - 2015 Polaris Slingshot First Ride Review | Ninjette Newsbot | Motorcycling News | 0 | July 28th, 2014 07:40 AM |
[motorcycle.com] - 2015 Polaris Slingshot Review – First Ride/Drive + Video | Ninjette Newsbot | Motorcycling News | 0 | July 27th, 2014 08:10 PM |
