Old March 26th, 2015, 09:29 AM   #1
Hatter
Motorcycle(s): 250r
2009 Bogs Between 3500-4000 RPM
So recently fires up my 250 (2009, 11k miles). This is project bike I inherited and it hasn't been started in several months at least.
She starts and idles ok, but as soon as I hit 3500 it bogs downs until I get over 4500 rpm, at which point it accelerates normally. It's the same RPM range every time. I suspect the carb needs a good cleaning, but I want to see if anyone else has a definite answer. I have a can of SeaFoam in the garage I'm going to try as well, have had good luck with that
Suggestions?
Hatter is offline   Reply With Quote
Old March 26th, 2015, 09:32 AM   #2
FBR_BDavis
It could be a mixture of things, figuratively and literally..
Stale gas could cause issues, but I doubt it would only happen at a particular RPM.. The carbs could definitely need cleaning.. I'm no expert by any means, but some extra info might help those who are..
What year is the bike?? How many miles are on it?? Where was the bike stored prior to you firing it back up??
FBR_BDavis is offline   Reply With Quote
Old March 26th, 2015, 09:39 AM   #3
Hatter
Motorcycle(s): 250r
The tank was drained before storage and I used new gas. The Bike been stored in a non-climate controlled storage facility.
it was a 2009 250 with about 11k miles
EDIT: I started it today and its giving me all sorts of issues including dying giving it gas....Annoyingly enough, I think I'm just gonna have to clean the carbs and report back after that. The main jet is probably clogged
Last futzed with by Hatter; March 26th, 2015 at 12:08 PM.
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
Bike bogs down at 9K stubshaft 2008 - 2012 Ninja 250R Tech Talk 7 May 5th, 2014 05:41 PM
Bogs down when accelerating, max 5-7k RPM Jeffro2749 1986 - 2007 Ninja 250R Tech Talk 17 August 25th, 2013 09:03 AM
2009 Ninja 250r - Culpeper, Virginia ($3500 obo) Live2ride Motorcycle-related 2 June 8th, 2012 09:44 AM
02 Runs rough below ~3500 RPM SV_Hadder 1986 - 2007 Ninja 250R Tech Talk 27 December 25th, 2011 11:33 PM
