Old October 8th, 2023, 05:43 AM   #1
Julian mustofa
Motorcycle(s): Ninja 250R
Shifting 2nd 3rd gear stone hard (08-12 ninja 250R)
Hi all i’ve been noticing my shifting sometimes was stone hard. It only on 2nd 3rd gear. I change with new engine oil. Shifting issue still remains. And also sometimes the shifting work but with rough sound. Do i need to adjust the clutch bite point? Or it have bad transmission inside the engine?
I just bought the bike 2 weeks ago. It only has 11000miles. The bike reasonably good condition
Julian mustofa is offline   Reply With Quote
Old October 8th, 2023, 06:09 AM   #2
Is the shift linkage free to move, not bent, and lubricated?
Old October 8th, 2023, 06:50 AM   #3
Julian mustofa
In perfect condition. This happen only in certain gear. Not all.
Old October 8th, 2023, 07:31 AM   #4
Yes, I understand, but sometimes the slightly different amounts of lever travel needed for different gears causes a problem to be worse in some gears than others. We recently had a guy here with a shift problem only going into 6th, I think it was.
Old October 8th, 2023, 09:24 AM   #5
Julian mustofa
I’am pretty sure its not that in my case
Because
When i shift to the 2nd/3rd gear and then it stuck rock hard
-i try to reving a bit =doesn’t work
-release clutch lever and pull it again with a bit reving =it works but feel rough
-this is not happens on the low rpm (2-3k)
-using higher rpm sometimes works with (again) rough feel
-i can’t say how exactly rpm it happens because my tachometer currenly not working at this moment. Roughly guess (4-6k)
Nickypoo's 2nd and 3rd track day. nickjpass Ninjettes At Speed 11 July 14th, 2015 09:21 PM
Dropping into N after shifting to 2nd. Mountain Dew 2008 - 2012 Ninja 250R Tech Talk 21 August 27th, 2012 10:46 AM
2011 Ninja 250R Strange Gear Shifting Greyfox General Motorcycling Discussion 3 January 30th, 2012 07:13 AM
[motorcyclistonline] - Hopkins 2nd And 3rd At Croft BSB Ninjette Newsbot Motorcycling News 0 May 16th, 2011 09:50 PM
Clutch is slipping when I accelerate hard in 2nd or 3rd bliket 2008 - 2012 Ninja 250R Tech Talk 22 January 18th, 2011 04:02 PM
