Old November 1st, 2011, 10:27 AM   #1
JLinde1339
Fighterer in Training
JLinde1339's Avatar
Motorcycle(s): 2001 Ninja 250R
Front Axle Castle Nut
Anyone know the size of socket needed to remove this? 17mm is too small, and 24mm (which I got for the rear) is too big. I'm guessing 22mm? Can anyone confirm?
Posted via Mobile Device
JLinde1339 is offline   Reply With Quote
Old November 1st, 2011, 11:03 AM   #2
exploring/carolina
exploring/carolina's Avatar
Yep, it's a 22MM.
exploring/carolina is offline   Reply With Quote
Old November 1st, 2011, 11:38 AM   #3
JLinde1339
JLinde1339's Avatar
Sweet. Thx. That'll save me a few trips.
Old November 23rd, 2011, 08:12 AM   #4
JLinde1339
JLinde1339's Avatar
Back on this again. Anybody know how to get this nut off? Tried pb blaster that doesn't work. Was thinking of trying a torch to heat it, but afraid that might melt the speedo gears. Any suggestions? Its on there good, and I've already twisted my breakerbar trying...
Old November 26th, 2011, 11:53 PM   #5
modemagic
modemagic's Avatar
Motorcycle(s): 2000 Ninja 250
Impact gun works well.
modemagic is offline   Reply With Quote
Old November 27th, 2011, 03:25 PM   #6
Skippii
Milkshake Drinker
Skippii's Avatar
Yeah, remove the cotter pin first.
Seriously, get a better breaker bar. I've never, ever seen a breaker bar bend. There's no excuse for that.
A blowtorch might work well, shouldn't damage the speedo, but you really shouldn't have to use anything but a breaker bar and a cheater bar.
In fact, you shouldn't even need anything besides a ratchet, or even the cheap 22mm wrench in the 250's tool kit. The whole point of a Castle nut is that there's no need or advantage to torquing it tightly--the cotter pin will prevent the nut from moving at all.
...Which, unfortunately, means that some idiot at one point in time probably lost the cotter pin and just put a bit of red loctite (permanent/requires heat to release) on the nut. In which case a blowtorch is the only way you're getting that bolt off.
Otherwise, a Hand Truck/Dolly handle works well for really stubborn bolts...
"What a sweetheart."- ninja_sleeper to me
Old December 9th, 2011, 01:02 PM   #7
JLinde1339
JLinde1339's Avatar
Well, I finally got it off the other night. It was on there wicked tight. I cleaned off the engine grime and was done earlier than expected so I said why not give it another shot. Since the drive of my 4" breakerbar was already twisted, I grabbed my old ratchet (that doesn't really ratchet anymore) and just layed on it. It finally budged a little. So I really laced into it and after about 20 minutes and nearly throwing my back out, I got it off. Wasn't any loctite in there, but that sucker was cranked down tight. Bruised the meat of my hand, even tho I had my riding gloves and a shop towel wrapped around the ratchet.
Sadly, my bike didn't come with any of those farkles like a "tool kit", or "manual". LOL. Just another wonderful inheritance from a PO. LOL
Old December 9th, 2011, 01:17 PM   #8
Skippii
Milkshake Drinker
Skippii's Avatar
That's no way to talk about your wife!!!!
Er...sorry. Glad to hear you got it removed!
Old December 9th, 2011, 01:23 PM   #9
JLinde1339
JLinde1339's Avatar
The EX-wife you mean. That's someone else's problem now, not mine. XD
Stock Rear Axle Nut Wrench + Extension indr 2008 - 2012 Ninja 250R Tech Talk 8 January 23rd, 2011 02:57 PM
Hitch Pin for rear Axle nut? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 3 July 6th, 2009 08:30 AM
axle nut torque? nate-bama 1986 - 2007 Ninja 250R Tech Talk 10 July 3rd, 2009 08:22 AM
Rear Axle Nut Rawr 2008 - 2012 Ninja 250R Tech Talk 16 May 22nd, 2009 08:40 AM
Front Axle Nut Flashmonkey 1986 - 2007 Ninja 250R Tech Talk 6 May 9th, 2009 10:57 PM
