March 30th, 2010, 08:34 AM | #1 |
Join Date: Feb 2010 Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1 Posts: 133
Easy Wolo/Stebel airhorn mount
I needed a better horn than the Road Runner's "meep..meep" so I carefully constructed a bracket to use a Wolo BadBoy airhorn (or Stebel Nautilus, they're virtually the same unit, probably made in the same factory). I used an existing bolt and a flange that had a 5mm thread hole so no drilling needed. I don't know if anything is bolted to that unused hole from the factory (maybe Cal emissions stuff? if anyone knows, please inform me) but it was available on my '08. I ran a 14ga. wire fused back at the battery and pulled the old horn wires to route over to the new horn relay. I've made a jig where I can mass produce these, send a PM if interested. Standard units will be black, this one is red for pictures, unless you like red. Comes with the 5mm screw.
Cell phone talkers beware, you will hear me now! Last futzed with by kevlar250; April 1st, 2010 at 10:52 PM. |
March 30th, 2010, 08:38 AM | #2 |
Join Date: May 2009 Motorcycle(s): 2015 V-Star 950 Tourer (Deep Blue) Posts: 570
I've been meaning to install an airhorn... Hmmmm
March 30th, 2010, 08:46 AM | #3 |
Neat installation!
March 30th, 2010, 11:54 AM | #4 |
Ugh, I want one of these brackets on my 09'
April 13th, 2010, 04:54 PM | #5 |
I finally got a half-hour together to install the mount.
Fits great... like it was made for the purpose. Because, well, it was. I decided to just go simple and bought a plug-and-play wiring kit for the Stebel Nautilus, which is the same horn as the Bad Boy. It truly is plug-and-play. As far as the horn goes, well, the bike sounds like a 250. A FRAKKIN' F250! Has anyone seen my socks? They got blown off and I can't find 'em. |
April 13th, 2010, 05:20 PM | #6 |
MOTM - Mar '13, Jun '14
Forget the horn. The truck is nice, hope it's a diesel.
April 13th, 2010, 05:31 PM | #7 |
April 13th, 2010, 05:53 PM | #8 |
Sorry, not into humongous vehicles the size of city blocks.
I drive a Honda Fit and ride a 250. If I needed one for work, then sure. But I don't. I like using the right tool for the job. |
April 13th, 2010, 08:43 PM | #9 |
Fit a few ninjas in this one |
April 14th, 2010, 01:17 AM | #10 |
Loud HORNS save lives also!
Wolo or Stebel airhorn bracket now available for the pregen! | kevlar250 | 1986 - 2007 Ninja 250R Farkles | 4 | April 13th, 2012 10:21 PM |
[twisted throttle] - Harley-Davidson Low-rider '95 with Stebel Nautilus airhorn insta | Ninjette Newsbot | Motorcycling News | 0 | March 7th, 2012 07:10 AM |
[twisted throttle] - Harley-Davidson Low-rider '95 with Stebel Nautilus airhorn insta | Ninjette Newsbot | Motorcycling News | 0 | March 1st, 2012 10:20 AM |
Installed Stebel Nautilus air horn, a.k.a. Wolo "Bad Boy" horn | FrugalNinja250 | 1986 - 2007 Ninja 250R Farkles | 8 | June 23rd, 2011 05:37 AM |
DIY Installing Wolo Badboy / Stebel Nautilus Horn | kevlarorc | 2008 - 2012 Ninja 250R Farkles | 7 | November 9th, 2010 06:21 AM |
