April 17th, 2014, 12:18 AM | #1 |
Join Date: Apr 2014 Motorcycle(s): '08 Ninja 250 Posts: 132
Getting around to replacing my forks this weekend. What should I know? Tips?
Finally getting around to replacing my bent forks. A friend is helping me who has done it many times before, that I trust.
I've searched around on the internet and it doesn't seem too difficult. One of my main questions that I have that I can find the answer to is, how much of the fork should be showing from the upper triple? If my question makes sense. Like the ends of the forks don't sit flush through the triple, so what's the length of fork that should be showing? Any other tips would be appreciated as well. Edit: And OF COURSE I find the answer right after posting. 12mm. |
April 17th, 2014, 12:29 AM | #2 |
MOTM - Jan '18, Sep '13
According to the service manual, 12mm. I think the most important thing would be to make sure it sticks out the same distance as the other side though.
April 17th, 2014, 12:34 AM | #3 |
April 17th, 2014, 12:48 AM | #4 |
I'm pretty sure that just ties in with fork alignment. I didn't really do anything specific when I took out my forks beyond eyeballing it though, mostly because I didn't really think about it and also because I removed the forks and lower triple as one unit so they should've stayed in-line. Haven't had anything go wrong yet. I'm sure someone more knowledgeable will chime in.
Replacing Forks | TheOneCleanHippy | 1986 - 2007 Ninja 250R Tech Talk | 6 | August 11th, 2013 06:51 PM |
Replacing the petcock | Navigon | 2008 - 2012 Ninja 250R Tech Talk | 1 | February 3rd, 2013 07:33 PM |
replacing oil in forks help | skilletmo | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 6th, 2012 06:41 PM |
Does tire need replacing? | Ranor | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 2nd, 2012 11:26 AM |
Replacing the airbox? | Ninjabunny | General Motorcycling Discussion | 1 | February 19th, 2009 09:07 PM |
