Old March 20th, 2011, 05:58 PM   #1
clintalmighty
Motorcycle(s): 2008 Ninja 250r 2009 Honda CBR600RR
slipping from second into neutral...?
So my bike kinda slips from 2nd gear back into neutral occasionally. It happened three times today riding with a passenger, and they were like "wtf" and i looked like a bad rider. It doesn't happen that often when riding solo but when trying to shift super smooth and easy for the passenger, it didn't seem to catch as well. I know part of it was probably me not kicking up hard enough, but i still feel like it shouldn't happen like that. Any tips on what i should do?
clintalmighty is offline   Reply With Quote
Old March 20th, 2011, 06:00 PM   #2
sounds like you need to readjust your shift lever.
Old March 20th, 2011, 06:04 PM   #3
clintalmighty
do we have a DIY thread for that?
Old March 20th, 2011, 06:27 PM   #4
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
May not be mechanical issue. I've had that happen when I've shifted too lightly and not really gotten it into second. If you are trying to be smooth because of the passenger, you may not be getting it all the way into gear.
Smooth is with the clutch, not your foot. Shift with purpose, put your foot into it and don't be gentle from 1st to 2nd.
Old March 20th, 2011, 06:44 PM   #5
easy enough... take a look at the shift lever. there's a rod that runs from the rod to the engine. on that rod you'll see 2 lock nuts. loosen them. the one towards the engine is backward threaded so you need to loosen it in the opposite direction that you normally would loosen a nut. when loose, turn the shift rod and you see the shift lever either go up or down. adjust rod to where you want then relock the lock nuts.
from what you describe, it sounds like when you are carrying a passenger, you're sitting up farther forward than you normally are and most likely unable to shift the lever high enough to get it into second gear all the way, which leads to it slipping back out if second. adjust the lever so that when you are forward on the seat, you're able to shift the lever into second all the way/cleanly. wear the same boots/riding shoes you normally wear when making the adjustment.
some pics in this thread that may help...
http://www.ninjette.org/forums/showt...ight=extenders
Old March 21st, 2011, 12:18 AM   #6
ungluck
sleeper
ungluck's Avatar
Motorcycle(s): '10 250r, '10 690 duke
i do this and always go **** cos i always think it's the bike but really it's just me being lazy.
i would still check the lever and make sure it's in spec and adjustng if needed.
ungluck is offline   Reply With Quote
Old March 21st, 2011, 12:33 AM   #7
the reason to check the lever is to make sure it is adjusted properly for your foot size including the boots you wear. When I first got my bike, it shifted perfectly, every time. Once I bought some boots, I started to miss second gear on occasion. The extra "bulk" of the boot made the position of the lever too "small" to get under the shift lever to lift it properly into gear. A quick readjustment of the shift lever and I've never missed a shift since.
That's why they make the controls on a bike adjustable. Take the time to set them up properly to fit you.
Old March 21st, 2011, 08:29 AM   #8
Vip3rV333
Vip3rV333's Avatar
Name: 01010010 01101111 01101101 01100001 01101110
Motorcycle(s): 08 Ninja 250r
Its pretty much what everyone said. When I first got the bike I would just try to "click it up or down" and it would sometimes just drop into neutral. I was so worried that the transmission was bad or something but after a little research I figured it was me and not the bike. Like Floyd said, "Shift with purpose". I then gave a conscious effort to shift harder and now its just second nature. Hasn't happened sense.
I suppose I/you could try and adjust it so you need less foot moment distance to shift.
Vip3rV333 is offline   Reply With Quote
Old March 21st, 2011, 08:43 AM   #9
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Stop riding fat chicks (your bike doesn't like it).
P.S. I mean on your bike!
300 Slipping out of 2nd and into neutral anacron 2013 - 2017 Ninja 300 Tech Talk 38 June 7th, 2016 09:36 AM
Clutch slipping - False Neutral....? sopranos 2008 - 2012 Ninja 250R Tech Talk 6 November 16th, 2011 04:31 PM
Slipping? OGjackafidy 2008 - 2012 Ninja 250R Tech Talk 5 September 21st, 2011 10:25 AM
{HELP} Clutch Slipping sprtonyy 2008 - 2012 Ninja 250R Tech Talk 20 April 21st, 2010 05:42 PM
back tire slipping/clutch slipping???? help? richierich781 2008 - 2012 Ninja 250R Tech Talk 17 June 19th, 2009 07:13 AM
